| huskie69 |
 huskie69 Spanner Monkey
 Posted: 10:08 - 12 Jan 2011 Post subject: Chains... |
As some of you may have read, I'm the proud owner of a Skyjet SJ125. I could fill an entire book with the list of problems it has but I've managed to keep on top of them since I've had it and it's only let me down about 20 times at the most
During my weekend maintenance regime (I give it about 2-3 hours of TLC every weekend!) I noticed the chain was beginning to get slack again. I adjusted the tensioner nuts on the swingarm (it had already been done a few weeks ago) but one of the nuts just turns and doesn't seem to be doing anything - what is it actually doing? I could be completely wrong but I have an idea that the bolt is screwed into the rear axle, the position of the axle is then determined by tightening/untightening the nut on this bolt - am I close? What could cause it to fail?
Anyway, I went to my nearest bike mechanic this morning to see if he could remove a link for me. He said it was actually illegal and that I should really get a new chain (makes sense I suppose as the chain has expanded so much it's likely to jump teeth). He can get one and fit it for £35 - £20 chain and £15 labour. To me, that's not a bad price after reading other people quotes for labour on this site and it saves me the hassle. It's booked in for this afternoon, but is he likely to run into problems with the tension adjuster or is it just my lack of understanding on how the mechanism works? ____________________ '10 Skyjet SJ125-23 - Crashed > '09 YBR 125 > '53 Suzuki SV650 - Died > 2010 Suzuki VanVan 125 > '87 Yamaha FZ750 Sold > VTR 1000 FireStorm - Sold > Honda CB1000R |
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
 Posted: 10:26 - 12 Jan 2011 Post subject: Re: Chains... |
| huskie69 wrote: | As some of you may have read, I'm the proud owner of a Skyjet SJ125. I could fill an entire book with the list of problems it has but I've managed to keep on top of them since I've had it and it's only let me down about 20 times at the most
Anyway, I went to my nearest bike mechanic this morning to see if he could remove a link for me. He said it was actually illegal and that I should really get a new chain (makes sense I suppose as the chain has expanded so much it's likely to jump teeth). He can get one and fit it for £35 - £20 chain and £15 labour. To me, that's not a bad price after reading other people quotes for labour on this site and it saves me the hassle. It's booked in for this afternoon, but is he likely to run into problems with the tension adjuster or is it just my lack of understanding on how the mechanism works? |
If you are sure that one of the tensioner nuts doesn't do anything then it may cause a problem. Your understanding of how the tensioner works seems pretty accurate although they don't normally screw into the axle itself, normally just into a guide around it (yours very well could screw into the axle). If the tensioner bolt/nut has stripped then turning it wouldn't do anything. If this is the case then you can still adjust the chain etc but it will be trickier as you cannot use the adjusters.
In short, I'm sure I'd be able to do it so he can too, best bet is to warn him before, he may want to fix the problem at your expense and might moan a lot though.
Otherwise the price is very reasonable .
Note: I'm not convinced that the law actually stipulates it is illegal to remove links, best not to anyway though. |
| huskie69 |
 Posted: 10:32 - 12 Jan 2011 Post subject: |
Thanks, I'll warn him before he starts working on it - don't want to piss him off as the other bike mechs around here are useless (they all seem more interested in trying to sell helmet polish and tube caps instead of proper stuff like actual tools!) and this guy seems like a decent bloke. ____________________ '10 Skyjet SJ125-23 - Crashed > '09 YBR 125 > '53 Suzuki SV650 - Died > 2010 Suzuki VanVan 125 > '87 Yamaha FZ750 Sold > VTR 1000 FireStorm - Sold > Honda CB1000R |
| huskie69 |
 Posted: 11:21 - 12 Jan 2011 Post subject: |
Oh - and what should I be using for lube? I put it on the rear stand every night, turn the wheel and spray the whole chain in GT85 as I use it for my engineless bikes. Is there something better available? ____________________ '10 Skyjet SJ125-23 - Crashed > '09 YBR 125 > '53 Suzuki SV650 - Died > 2010 Suzuki VanVan 125 > '87 Yamaha FZ750 Sold > VTR 1000 FireStorm - Sold > Honda CB1000R |
| DrDonnyBrago |
 Posted: 11:32 - 12 Jan 2011 Post subject: |
| huskie69 wrote: | Oh - and what should I be using for lube? I put it on the rear stand every night, turn the wheel and spray the whole chain in GT85 as I use it for my engineless bikes. Is there something better available? |
Wouldn't use GT85, it's too thin to work properly and would likely just wash off any remaining lube.
You want a thicker oil so it stays on the chain. There are hundreds of purpose made chain sprays, oils, waxes etc that will cost a small fortune over the life of your riding career.
I however do as follows:
If the chain is dirty, or every 500 miles or so, clean the chain using paraffin (buy it from Homebase and B+Q - sold as lamp fuel - £5 for 4L), this is cheap and gets the crud off really well. Apply it with a p[aintbrush and a small pot, work the dirt out untilt eh chain looks clean, wipe it off with a rag or get the hose on it and wash it off. Let the chain dry and it is ready for lube.
For lube you can use any of the pricey sprays or like me, the cheapest engine oil you can find in whatever grade you can lay your hands on, it can even be used oil if you like (used oil makes your bike dirtier though). Using another paint brush, give the chain a good coating of engine oil on both sides of the chain, wipe the excess off with a rag and you are good to go.
I dont like chain waxes and spray oils, makes too much ju8nk stick to the chain, engine oil is fine but can fling off the chain a bit. |
| huskie69 |
 Posted: 11:50 - 12 Jan 2011 Post subject: |
Nice one. I had actually wondered if GT85 was too thin as it doesn't really seem to be doing much - probably goes a way to explaining why I've had chain problems
I've got a kettenmax chain cleaner and use lamp oil to give it a clean every other week - works quite well and saves a bit of back ache!
I did consider using engine oil instead but as I'd never seen it sold in shops as chain oil (everything's in spray cans), I though there was a reason against it - if it's just due to it being a bit dirty, then bugger it - I'd rather have some dirt on my bike and save myself a bit of money in chain maintenance.
When I get my proper bike, a scottoiler will be top of the list of things to get. ____________________ '10 Skyjet SJ125-23 - Crashed > '09 YBR 125 > '53 Suzuki SV650 - Died > 2010 Suzuki VanVan 125 > '87 Yamaha FZ750 Sold > VTR 1000 FireStorm - Sold > Honda CB1000R |
| mysterious_rider |
 mysterious_rider World Chat Champion
| Mark65 |
 Mark65 World Chat Champion
| huskie69 |
 Posted: 12:07 - 12 Jan 2011 Post subject: |
| huskie69 |
 Posted: 12:12 - 12 Jan 2011 Post subject: |
Thanks for posting a pic Mark.
Someone should be writing a book for bike mechanic novices with pics like this so we can understand the concept of how it all works. I didn't know how an engine worked til I got my bike!
any takers?!!! ____________________ '10 Skyjet SJ125-23 - Crashed > '09 YBR 125 > '53 Suzuki SV650 - Died > 2010 Suzuki VanVan 125 > '87 Yamaha FZ750 Sold > VTR 1000 FireStorm - Sold > Honda CB1000R |
| Mark65 |
 Posted: 12:34 - 12 Jan 2011 Post subject: |
We all have the learning curve to visit now and then , i myself have picked up a lot of knowledge on these forums and thats what people are here for to help each other and post porn , now do you really need the new chain or just adjusters?.
Mark ____________________ 07 Yamaha YBR125, 07 Honda CG125 , 15 CBR300R (Chocolate Crank, Deaded), 16 CB500FA, 19 Honda Forza 300, 70 Suzuki SV650 |
| huskie69 |
 Posted: 12:41 - 12 Jan 2011 Post subject: |
These forums do provide about 90% of information I need, and I'm glad everyone's so helpful (and patient!)
Looks like both chain and tensioners need replacing - the tensioners have adjusted as far as they can.
If I get a new chain fitted - I'm pretty confident it won't be anywhere near as poor quality as the original plus the mechanic will do a better job than I could. ____________________ '10 Skyjet SJ125-23 - Crashed > '09 YBR 125 > '53 Suzuki SV650 - Died > 2010 Suzuki VanVan 125 > '87 Yamaha FZ750 Sold > VTR 1000 FireStorm - Sold > Honda CB1000R |
| DrDonnyBrago |
| DrDonnyBrago |
| mysterious_rider |
| Mark65 |
 Posted: 14:14 - 12 Jan 2011 Post subject: |
| DonnyBrago wrote: | | huskie69 wrote: | These forums do provide about 90% of information I need, and I'm glad everyone's so helpful (and patient!)
If I get a new chain fitted - I'm pretty confident it won't be anywhere near as poor quality as the original plus the mechanic will do a better job than I could. |
Fitting a chain is VERY easy mate, especially with a smaller bike where you can use a split link. Look into the price of a chain and sprocket kit on ebay etc, if the chain is worn the sprockets are probably knackered too; it is good practice to replace the whole lot as a set. If you buy your own, look out for a DID chain, they are good and quite reasonably priced. |
+1, I did my first over xmas, very straight forward, although the side float on the front sprocket is a bit disconcerting but its normal.
I tried an Afam C+S kit , x ring chain with gold plates, mainly as every one used did i thought i could let others know what a diff make is like at a similair price.
| fiery tupp |
 fiery tupp Trackday Trickster
 Posted: 15:20 - 12 Jan 2011 Post subject: |
I thought that too - but I went to 3 other bike shops in the area, all with a similar response - and none of them sell chain/link removal tools as there's not enough demand for them :S!!!
We used to us , a hammer a masonry nail & a small socket to remove links on small bikes , filing the end of pins & knocking through one at a time . A little crude but it worked in emergencies  ____________________ If you can't fix it with a hammer , use your head .
| nightshaddow |
 nightshaddow Nearly there...
| mysterious_rider |
 Posted: 18:01 - 12 Jan 2011 Post subject: |
are the bolts replacable? Get them replaced if you can.
if not, what will work is, where the nut has threaded put a larger nut over it (to act as a washer) and so it tightens further up the bolt, rather than trying to tighten on the threaded part. Just obviously don't overtighten. And only adjust with the axle nut loose. |
| nightshaddow |
 Posted: 18:15 - 12 Jan 2011 Post subject: |
with a bit of work yes they are welded in but if you need to replace it will be easy enough to replace them ____________________ "WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE Its chinese OFFICER."
Current rides CB 125 TDE(the next project) NS125RK ( now on the road ) CB125TDC (soon to be project 17) melody ( the nephews ) |
| Glenben92 |
 Glenben92 Nearly there...
 Posted: 18:59 - 12 Jan 2011 Post subject: |
Am I the only person who thinks £20 will definitely be a non o-ring chain and will last about a minute? ____________________ 57 Huoniao HN125-8 - , 97 Kawasaki GPZ500S -
99 Yamaha FZS 600 -
Mod 2 Passed - 01/10/2010 |
| Mark65 |
| Mark65 |
 Posted: 22:41 - 12 Jan 2011 Post subject: |
Prolly clean a lot of that of with a drill and wire wheel , then paint, or replace if cheap enough. ____________________ 07 Yamaha YBR125, 07 Honda CG125 , 15 CBR300R (Chocolate Crank, Deaded), 16 CB500FA, 19 Honda Forza 300, 70 Suzuki SV650 |
The last post was made 15 years, 256 days ago. Instead of replying here, would creating a new thread be more useful? |
