Compression testing-valves or piston rings???
rob_scott92
PostPosted: 14:41 - 17 Jan 2011    Post subject: Compression testing-valves or piston rings??? Reply with quote
Hey guys,
my uncle got me a compression tester for christmas (proper gift Laughing )
I'm going to give it a go today but i'm not really sure on how to tell if its the valves or the rings that are worn.
I did hear a while back that if you put some oil in the cylinder, and the compression increased, that would mean that its the rings that are at fault.
Can anyone confirm/expand on that at all?
Cheers Thumbs Up
First bike: 1982 Suzuki Gs 125 'The beast MK1' Wink > 1988 Honda Cb 350's' FOR SPORT! (Good ol' oil burner!) > 2001 Suzuki Sv 650 's' Made it out of the 80's! > 1997 Honda Cbr 600f :p
PostPosted: 14:44 - 17 Jan 2011    Post subject: Reply with quote
What I was told is pop a little 2 stroke down the bore, if compression increases then its the rings.
What happened to my mates GX125 was a slag... lack of compression so we popped some 2t down there... compression was the same!
Ended up being a cracked valve seat.
Barry_M2
PostPosted: 14:46 - 17 Jan 2011    Post subject: Reply with quote
You need a leakdown tester to pin point where a problem is really. This blows air into the cylinder from a compressor rather than using the piston to supply the pressure.
Yes, dropping in a little oil will show a higher reading. You could check what the actual PSI should be from the Maunal, then compare the before and after figures!
I use a leakdown tester, superb piece of equipment! Wink Thumbs Up
ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
rob_scott92
PostPosted: 14:58 - 17 Jan 2011    Post subject: Reply with quote
Aye i've got the manual so i've got a figure to work towards.
I assume normal engine oil will do? Obviously it being 4t i dont have any 2 smoke oil lying around Laughing
will just a little oil be enough?
i'll have to find a funnel or something so i dont get oil on the spark threads Rolling Eyes
rob_scott92
PostPosted: 15:08 - 17 Jan 2011    Post subject: Reply with quote
Actually, whilst on the subject;
Parts for this bike are either impossible to find, or are just too dam expensive!
If, say, it were the piston that was knackered, or the valves. Are these parts 'bike specific'???
Surely there are standard sizes, or do most bikes have different shapes to them. Obviously i know you cant tak a piston from a 125 and use it in a gixxer thou' Laughing But more along the lines of a superdream 250/400 into my 350? The engines are very similar i believe.
Same with valves too.
Anyone know? Laughing
EDIT: actually thats silly, 400 pistons will be too big, 250 too small Embarassed
Point is, can you buy pistons/valves based on size rather than bike model
rob_scott92
PostPosted: 17:28 - 17 Jan 2011    Post subject: Reply with quote
right ok, i've just checked the compression levels now.
Compression 'should' be 12kg/cm(2).
I'm currently getting a reading of 9.5kg/cm(2) on the left cylinder, and 9kg/cm(2) on the right.
Thats probably fair enough really, over 23 years and nearly 50,000 miles worth of use. I suppose it could've been much worse than that Very Happy
Unfortunately i cant find anything to get the oil into the cylinders with, the funnel i have is too big and i dont want to get oil in the threads. So that'll have to wait untill later.
i know i can get some 0.50mm oversize pistons from david silvers, not sure about the rings though. Then after that i'd have to find gaskets too Rolling Eyes
Cant wait till i get some money and i might actually be able to do something with this! Laughing
rob_scott92
PostPosted: 17:52 - 17 Jan 2011    Post subject: Reply with quote
rob yarrr wrote:
all that sport performance has been worn away Laughing
I hope thats not a bit of sarcasm Rob! Shocked
I think it works out to around 40 PSI lower than what it should be! It is more worrying if you think of it like that.
CHR15 wrote:
also, the fact your bike uses more oil than fuel would suggest its more than likely rings.
Aye, thats actually best case scenario i suppose. It is funny that whenever i go anywhere i'm more worried about running out of oil than fuel Laughing
I did think something along the lines of a teaspoon, although the way the hole is angled it'd probably still get on the thread. I'll give it a shot though Wink
rob_scott92
PostPosted: 19:18 - 17 Jan 2011    Post subject: Reply with quote
Right, so i've compiled a wee price list. Not as bad as i thought if i've got everything down i'd need ofcourse Rolling Eyes
* Pistons 0.50mm oversize from david silvers (the only size they have), not sure if rings are included. £15 each
*Cylinder head gasket. £25.21 Shocked
*Cylinder (Base) gasket. £6.46
*Valve stem oil seals IN. £1.31 x 4 = £5.24
*Valve stem oil seals EX. £1.99 x 2 = £3.98
May aswell replace while i'm in there
Total cost = £70.89
Hopefully it'll be close to that, but if a rebore/hone is required, how much is that likely to cost?
A new cam chain on ebay is around £50, might be worth doing that at the same time i suppose.
Anyone think i've missed much out Laughing
rob_scott92
PostPosted: 19:31 - 17 Jan 2011    Post subject: Reply with quote
already got some, well, my uncles got some Laughing
Also got the tool to go with it Mr. Green
0l0dom0l0
PostPosted: 20:04 - 17 Jan 2011    Post subject: Reply with quote
I would consider doing the cam chain but that would be dependent on the condition of the old one obviously. It might cost you £50 now, but its going to cost you £75 next time you do it as you will need a new head gasket... so in reality its only costing you £25 for the cam chain if you do it this time round.
cb1rocket
PostPosted: 21:31 - 17 Jan 2011    Post subject: Reply with quote
everything from david silver spares is plus VAT! Shocked
Wozza
PostPosted: 14:17 - 18 Jan 2011    Post subject: Reply with quote
Did you warm the engine before testing compression? As I believe this may give a higher reading.
rob_scott92
PostPosted: 19:29 - 18 Jan 2011    Post subject: Reply with quote
Yeah, i suppose i could've had it warmer but then i wouldn't be able to get the dam plugs out for it being too hot.
I left it with the choke on for a while and waited for the revs to increase, at which point i turned the choke off so it idled at the usual revs.
I may try it again tomorrow to test it with oil in the bores, so i'll take it out for a few mins before i check it this time Wink
Robby
Dirty Old Man
PostPosted: 02:09 - 19 Jan 2011    Post subject: Reply with quote
A pattern gasket set from David Silvers will contain all of the gaskets and the valve stem seals.
It is rare for piston rings to wear out on a standard Japanese 4 stroke engine, it's the sort of thing that is more common on highly tuned 4 strokes, and a service item on two strokes.
Strip it and measure before you start buying parts. If the ring end gap is ok and the bore looks ok, then the rings are probably fine - clean the ring grooves on the pistons before putting them back on it after the end gap check.
Valves could have a bit of carbon built up on the back, stopping them from making a good seal. A clean up and regrind will sort this. Leaking valve stem seals can make it burn oil.
rob_scott92
PostPosted: 16:01 - 19 Jan 2011    Post subject: Reply with quote
I've e-mailed david silvers before asking about gaskets, they said they no longer stock them Sad
Even honda dont stock some of the gaskets, left hand engine casing gasket for one Rolling Eyes Although thats not really an essential gasket, gasket paste is fine for that.
Obviously i wont be able to order any pistons or rings before i know what size pistons are in there anyway. but i will have to get the gaskets first just so i know that i'll be able to put the thing back together.
All this ofcourse, depends on wether i can get a job/electrical epprecticeship sometime soon Mad As i'm still at college thats proving difficult Rolling Eyes
rob_scott92
PostPosted: 19:28 - 19 Jan 2011    Post subject: Reply with quote
Aye cheers Chris , i may take you up on that whenever i do decide to do it. Although i have got my uncle to guide me, i dont really have any workshop to speak of. But thanks for the offer anyway, i could always nip your way to see how the turbo's getting on Twisted Evil
rob_scott92
PostPosted: 16:29 - 21 Jan 2011    Post subject: Reply with quote
just a quick update for those who may be interested;
Just went and checked with some oil down the bores, and both cylinders gained approx around 15 psi each (still another 25 to go). I didn't put much oil in though so i suppose if i'd have put a bit more in it would've made it round the whole of the pistons for a better seal.
So basically what i'm thinking now is that the valve seats might be slightly worn and/stem seals aswell. seeing as they would be replced at the same time (Whenever that will be Rolling Eyes ) i'm hoping it wont be too much of a problem. As long as the valves arent knackered I dont think it'd be too much more expensive Wink
Cheers for the info guys, been helpful Thumbs Up
The last post was made 15 years, 168 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.59 - MySQL Queries: 13 - Page Size: 114.63 Kb
