| rob_scott92 |
 rob_scott92 Could Be A Chat Bot
 Posted: 14:41 - 17 Jan 2011 Post subject: Compression testing-valves or piston rings??? |
Hey guys,
my uncle got me a compression tester for christmas (proper gift )
I'm going to give it a go today but i'm not really sure on how to tell if its the valves or the rings that are worn.
I did hear a while back that if you put some oil in the cylinder, and the compression increased, that would mean that its the rings that are at fault.
Can anyone confirm/expand on that at all?
Cheers  ____________________ First bike: 1982 Suzuki Gs 125 'The beast MK1' > 1988 Honda Cb 350's' FOR SPORT! (Good ol' oil burner!) > 2001 Suzuki Sv 650 's' Made it out of the 80's! > 1997 Honda Cbr 600f :p |
| P.addy |
 P.addy Red Rocket
| Barry_M2 |
 Barry_M2 World Chat Champion
 Posted: 14:46 - 17 Jan 2011 Post subject: |
You need a leakdown tester to pin point where a problem is really. This blows air into the cylinder from a compressor rather than using the piston to supply the pressure.
Yes, dropping in a little oil will show a higher reading. You could check what the actual PSI should be from the Maunal, then compare the before and after figures!
I use a leakdown tester, superb piece of equipment!  ____________________ ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
https://www.bikechatforums.com/profile.php?mode=viewprofile&u=4332 |
| rob_scott92 |
 Posted: 14:58 - 17 Jan 2011 Post subject: |
Aye i've got the manual so i've got a figure to work towards.
I assume normal engine oil will do? Obviously it being 4t i dont have any 2 smoke oil lying around
will just a little oil be enough?
i'll have to find a funnel or something so i dont get oil on the spark threads  ____________________ First bike: 1982 Suzuki Gs 125 'The beast MK1' > 1988 Honda Cb 350's' FOR SPORT! (Good ol' oil burner!) > 2001 Suzuki Sv 650 's' Made it out of the 80's! > 1997 Honda Cbr 600f :p |
| N cee thirty |
 N cee thirty Banned
| rob_scott92 |
 Posted: 15:08 - 17 Jan 2011 Post subject: |
Actually, whilst on the subject;
Parts for this bike are either impossible to find, or are just too dam expensive!
If, say, it were the piston that was knackered, or the valves. Are these parts 'bike specific'???
Surely there are standard sizes, or do most bikes have different shapes to them. Obviously i know you cant tak a piston from a 125 and use it in a gixxer thou' But more along the lines of a superdream 250/400 into my 350? The engines are very similar i believe.
Same with valves too.
Anyone know?
EDIT: actually thats silly, 400 pistons will be too big, 250 too small
Point is, can you buy pistons/valves based on size rather than bike model ____________________ First bike: 1982 Suzuki Gs 125 'The beast MK1' > 1988 Honda Cb 350's' FOR SPORT! (Good ol' oil burner!) > 2001 Suzuki Sv 650 's' Made it out of the 80's! > 1997 Honda Cbr 600f :p |
| rob_scott92 |
 Posted: 17:28 - 17 Jan 2011 Post subject: |
right ok, i've just checked the compression levels now.
Compression 'should' be 12kg/cm(2).
I'm currently getting a reading of 9.5kg/cm(2) on the left cylinder, and 9kg/cm(2) on the right.
Thats probably fair enough really, over 23 years and nearly 50,000 miles worth of use. I suppose it could've been much worse than that
Unfortunately i cant find anything to get the oil into the cylinders with, the funnel i have is too big and i dont want to get oil in the threads. So that'll have to wait untill later.
i know i can get some 0.50mm oversize pistons from david silvers, not sure about the rings though. Then after that i'd have to find gaskets too
Cant wait till i get some money and i might actually be able to do something with this!  ____________________ First bike: 1982 Suzuki Gs 125 'The beast MK1' > 1988 Honda Cb 350's' FOR SPORT! (Good ol' oil burner!) > 2001 Suzuki Sv 650 's' Made it out of the 80's! > 1997 Honda Cbr 600f :p |
| N cee thirty |
 N cee thirty Banned
 Posted: 17:34 - 17 Jan 2011 Post subject: |
lol just converted them to psi and there a fair way down if i'm right,all that sport performance has been worn away  ____________________ '00 Aprilia RS50 > '92 Honda CG > '99 Yamaha Fazer > '91 Yamaha RXS > '79 Suzuki X5 > 01' Honda Cg > 07' Honda Cg > 82' Kawasaki Z200 > suzuki gsxr 400 gk73a > honda vfr 400 NC30 Mod 2 Passed 09/06/2011
Jewlio Iglesias wrote: I actually did vote BNP once |
| rob_scott92 |
 Posted: 17:52 - 17 Jan 2011 Post subject: |
| rob_scott92 |
 Posted: 19:18 - 17 Jan 2011 Post subject: |
Right, so i've compiled a wee price list. Not as bad as i thought if i've got everything down i'd need ofcourse
* Pistons 0.50mm oversize from david silvers (the only size they have), not sure if rings are included. £15 each
*Cylinder head gasket. £25.21
*Cylinder (Base) gasket. £6.46
*Valve stem oil seals IN. £1.31 x 4 = £5.24
*Valve stem oil seals EX. £1.99 x 2 = £3.98
May aswell replace while i'm in there
Total cost = £70.89
Hopefully it'll be close to that, but if a rebore/hone is required, how much is that likely to cost?
A new cam chain on ebay is around £50, might be worth doing that at the same time i suppose.
Anyone think i've missed much out  ____________________ First bike: 1982 Suzuki Gs 125 'The beast MK1' > 1988 Honda Cb 350's' FOR SPORT! (Good ol' oil burner!) > 2001 Suzuki Sv 650 's' Made it out of the 80's! > 1997 Honda Cbr 600f :p |
| N cee thirty |
 N cee thirty Banned
 Posted: 19:25 - 17 Jan 2011 Post subject: |
valve grinding paste  ____________________ '00 Aprilia RS50 > '92 Honda CG > '99 Yamaha Fazer > '91 Yamaha RXS > '79 Suzuki X5 > 01' Honda Cg > 07' Honda Cg > 82' Kawasaki Z200 > suzuki gsxr 400 gk73a > honda vfr 400 NC30 Mod 2 Passed 09/06/2011
| rob_scott92 |
 Posted: 19:31 - 17 Jan 2011 Post subject: |
already got some, well, my uncles got some
Also got the tool to go with it  ____________________ First bike: 1982 Suzuki Gs 125 'The beast MK1' > 1988 Honda Cb 350's' FOR SPORT! (Good ol' oil burner!) > 2001 Suzuki Sv 650 's' Made it out of the 80's! > 1997 Honda Cbr 600f :p |
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
| cb1rocket |
 cb1rocket World Chat Champion
 Posted: 21:31 - 17 Jan 2011 Post subject: |
everything from david silver spares is plus VAT!  |
| Wozza |
 Wozza Brolly Dolly
| rob_scott92 |
 Posted: 19:29 - 18 Jan 2011 Post subject: |
Yeah, i suppose i could've had it warmer but then i wouldn't be able to get the dam plugs out for it being too hot.
I left it with the choke on for a while and waited for the revs to increase, at which point i turned the choke off so it idled at the usual revs.
I may try it again tomorrow to test it with oil in the bores, so i'll take it out for a few mins before i check it this time  ____________________ First bike: 1982 Suzuki Gs 125 'The beast MK1' > 1988 Honda Cb 350's' FOR SPORT! (Good ol' oil burner!) > 2001 Suzuki Sv 650 's' Made it out of the 80's! > 1997 Honda Cbr 600f :p |
| Robby |
 Robby Dirty Old Man
| rob_scott92 |
 Posted: 16:01 - 19 Jan 2011 Post subject: |
I've e-mailed david silvers before asking about gaskets, they said they no longer stock them
Even honda dont stock some of the gaskets, left hand engine casing gasket for one Although thats not really an essential gasket, gasket paste is fine for that.
Obviously i wont be able to order any pistons or rings before i know what size pistons are in there anyway. but i will have to get the gaskets first just so i know that i'll be able to put the thing back together.
All this ofcourse, depends on wether i can get a job/electrical epprecticeship sometime soon As i'm still at college thats proving difficult  ____________________ First bike: 1982 Suzuki Gs 125 'The beast MK1' > 1988 Honda Cb 350's' FOR SPORT! (Good ol' oil burner!) > 2001 Suzuki Sv 650 's' Made it out of the 80's! > 1997 Honda Cbr 600f :p |
| rob_scott92 |
 Posted: 19:28 - 19 Jan 2011 Post subject: |
Aye cheers Chris , i may take you up on that whenever i do decide to do it. Although i have got my uncle to guide me, i dont really have any workshop to speak of. But thanks for the offer anyway, i could always nip your way to see how the turbo's getting on  ____________________ First bike: 1982 Suzuki Gs 125 'The beast MK1' > 1988 Honda Cb 350's' FOR SPORT! (Good ol' oil burner!) > 2001 Suzuki Sv 650 's' Made it out of the 80's! > 1997 Honda Cbr 600f :p |
| rob_scott92 |
 Posted: 16:29 - 21 Jan 2011 Post subject: |
just a quick update for those who may be interested;
Just went and checked with some oil down the bores, and both cylinders gained approx around 15 psi each (still another 25 to go). I didn't put much oil in though so i suppose if i'd have put a bit more in it would've made it round the whole of the pistons for a better seal.
So basically what i'm thinking now is that the valve seats might be slightly worn and/stem seals aswell. seeing as they would be replced at the same time (Whenever that will be ) i'm hoping it wont be too much of a problem. As long as the valves arent knackered I dont think it'd be too much more expensive
Cheers for the info guys, been helpful  ____________________ First bike: 1982 Suzuki Gs 125 'The beast MK1' > 1988 Honda Cb 350's' FOR SPORT! (Good ol' oil burner!) > 2001 Suzuki Sv 650 's' Made it out of the 80's! > 1997 Honda Cbr 600f :p |
The last post was made 15 years, 171 days ago. Instead of replying here, would creating a new thread be more useful? |
