Fitting a different sized scooter wheel, need bright ideas
Gazdaman
I did a trackday!!!
PostPosted: 18:55 - 06 Feb 2011    Post subject: Fitting a different sized scooter wheel, need bright ideas Reply with quote
So anyway, I bought a Yamaha Aerox 50cc. It has a 13" rear wheel, which makes rear tyre choice almost nil for nobbly tyres.
It's a 3 stud rear wheel, so I bought a Peugeot Speedfight rear wheel, which is also 3 stud, and 12". Fantastic I thought!
Of course the PCD was wrong. So I bought the disc and hub assembly from a speedfight, which should fit over the splines of the final drive on the 'ped.
Here's the kicker, different sized splines.
Now I've looked at the various parts in the final drive and they look completely different. So does anyone have any bright ideas? I've thought about chopping up the two splined shafts and welding the Speedfight one on the end of the Aerox one. But then I'll have an issue that the new end will be bigger than the hole in the crank case, so it'll never be removable. And of course welding it perfectly straight and true will be almost impossible.
The other possibility is fabricating some sort of adapter plate to adapt the PCD, but will obviously space the wheel out slightly.
Sigh.
Gaz
PostPosted: 19:08 - 06 Feb 2011    Post subject: Re: Fitting a different sized scooter wheel, need bright ide Reply with quote
Get your welder out and add the swing arm of your pit bike on to back of the main swing arm?
You can then add an auxiliary sprocket and chain drive to the current setup.
Anything to assit the competition in a sportsmanly fashion! Wink
You'll also have the added benefit of reduced wheelies and better stability!
Err, more seriously... could you you not weld or otherwise attach some new studs to the original hub?
Pedd
PostPosted: 19:09 - 06 Feb 2011    Post subject: Reply with quote
can you not just re-drill the aerox hub new add studs??
edit: G posted same but quicker doh
Dont Click HERE
Current modes of transport = 125 superdream (in bits atm), 1978 GS750 chop, bandit 600(main one), 1982 bmw r100rs,
cx500 trike (hey its fun) oh and the car to ferry the missus and dogs around Smile
Jamie S
PostPosted: 19:12 - 06 Feb 2011    Post subject: Reply with quote
What the hell are you going to be doing with an aerox that means it needs nobbly tyres .... Laughing
PostPosted: 19:18 - 06 Feb 2011    Post subject: Reply with quote
Probably this - https://geesvids.blip.tv/file/3661917/
To be honest, knobbly tyres aren't entirely essential - unless it rains, apparently!
nsr_J22_FOXEYE
PostPosted: 19:47 - 06 Feb 2011    Post subject: Reply with quote
That video is amazing, I wish a track was open to do something like that with 3rd class bikes Very Happy
Never Ride Faster Than Your Angel Can Fly
PostPosted: 20:17 - 06 Feb 2011    Post subject: Reply with quote
Well, you've got some pretentious - those were at least 5th class at best! Erm, unless you mean some sort of scooter racing class?
Anyway, that was us last year. Should hopefully be on this year too - RAF wittering, £60 per team to enter for 6 hours 'race' + 1 hour practice/shakedown.
Max 90cc 4 stroke, 50cc 2 stroke, no clutch levers or competition engines allowed.
Gazdaman
I did a trackday!!!
PostPosted: 20:24 - 06 Feb 2011    Post subject: Reply with quote
I would be tempted to drill/tap new studs, the only issue is that the PCD of the two wheels is very similar, and the design means it's not solid the whole way round.
I'm thinking I wonder how hard it'd be to make a splined 'washer'. So the inside of the washer fits over the smaller shaft, and the outside of the washer is splined to fit the inside of the bigger hub thing.
I guess it probably wouldn't be cheap to get machined though.
Only other thing is I get a disk machined up that's a 10mm spacer. With bolts of the original PCD, and also drilled for the other PCD.
But as said above, the trouble is it'll push the wheel out by 10mm.
cb1rocket
PostPosted: 20:33 - 06 Feb 2011    Post subject: Reply with quote
is the offset of both wheels the same then? You might find that with a spacer your get away without the wheel being off center? perhaps...
PostPosted: 20:34 - 06 Feb 2011    Post subject: Reply with quote
Judging by your performance last time, you'll crash in the practice and 'adjust' half the modifications anyway Razz.
Not sure if overall I'd worry that much about it being 10mm out - suspect it's an issue for tarmac more, more as we've seen, running knobblies at the limit of grip on tarmac isn't really ideal anyway Smile.
Digitalize
PostPosted: 20:47 - 06 Feb 2011    Post subject: Reply with quote
Sell the Aerox and buy a Speedfight?
Of course, that would be too easy Wink
1998 CB600F Hornet
Gazdaman
I did a trackday!!!
PostPosted: 20:49 - 06 Feb 2011    Post subject: Reply with quote
The thought has crossed my mind, this ped only cost me £60. And everything else on it appears good.
Plus the entire front end is being replaced, so whatever bike it is, it won't end up looking like whatever it started off as.
I suspect I'll end up getting a PCD adapter plate made up.
Gaz
PostPosted: 20:54 - 06 Feb 2011    Post subject: Reply with quote
Or.... Sell the Aerox.
*Do some research.*
Buy a suitable bike.
Not that I've done much before buying the one I'll probably be using - but then it was on the way back from selling a C90 and cost about the same Smile.
Gazdaman
I did a trackday!!!
PostPosted: 20:58 - 06 Feb 2011    Post subject: Reply with quote
I doubt I could sell the Aerox for much at the moment since it's in a squillion pieces spread all over my garage.
Once this rear wheel issue is worked out, and once I've fitted an awesome front end it'll be a quality 'ped.
I think I might keep my eyes out for a spares or repair Speedfight to bastardise for parts.
Now if anyone knows someone who could fabricate me a PCD adapter for cheapness, I would be mucho appreciative!
Gaz
GREENI3
PostPosted: 21:12 - 06 Feb 2011    Post subject: Reply with quote
That aerox must have been messed up quite badly for 60 quid Laughing
Gazdaman
I did a trackday!!!
PostPosted: 21:18 - 06 Feb 2011    Post subject: Reply with quote
It was pretty good actually! 10k miles. 1998 reg. Bit crusty in places, no MOT or tax, coolant leak, fork seals completely shagged.
https://www.gaz-racing.co.uk/images/vehicle_1275.JPG
It now looks like this:
https://www.gaz-racing.co.uk/images/vehicle_1308.JPG
plus a set of shelves full of parts.
Gaz
GREENI3
PostPosted: 21:27 - 06 Feb 2011    Post subject: Reply with quote
What condition is that frame in?
So what exactly are you planning on doing with it?
Gazdaman
I did a trackday!!!
PostPosted: 21:29 - 06 Feb 2011    Post subject: Reply with quote
Frame's nigh on perfect. I just intend on cutting off any unused brackets, bracing up the 'step through' part for a bit of added strength (read unnecessary tart factor).
It's going to be used for Moped Mayhem events this year, hopefully.
Gaz
GREENI3
PostPosted: 21:36 - 06 Feb 2011    Post subject: Reply with quote
So how can you take part in one of these events?
Seems like a bloody laugh after watching that video. Laughing
Gazdaman
I did a trackday!!!
PostPosted: 22:05 - 06 Feb 2011    Post subject: Reply with quote
I forget, G sorted it for me last year.
https://www.extremetrifle.com/2/mopedmayhem2_faqs.php
This link has been useful in the past, and even better it has a photo of both G and Bendy at Lydden on the front page.
£60, suitable bike. 6 hours of utter hell, but it's absolutely fantastic fun. After about 3 hours you wonder what the hell you've let yourself in for.
There's a bit of an article about the prep of my ped here:
https://www.gaz-racing.co.uk/content.php?page=viewarticle.php&article_id=148
Gaz
GREENI3
PostPosted: 22:10 - 06 Feb 2011    Post subject: Reply with quote
Cheers Gaz, might look into it. Smile
cb1rocket
PostPosted: 23:26 - 06 Feb 2011    Post subject: Reply with quote
PCD = Pitch Circle Diameter
And the adapter is to modify the PCD
cb1rocket
PostPosted: 23:32 - 06 Feb 2011    Post subject: Reply with quote
an example
https://cgi.ebay.co.uk/PCD-Wheel-Adaptors-5x100-5x112-VW-Merc-Golf-A3-Leon-/150557072605?pt=LH_DefaultDomain_3&hash=item230de69cdd
yes i know its car specific
cb1rocket
PostPosted: 23:44 - 06 Feb 2011    Post subject: Reply with quote
could help with a cad drawing to send to the laser cutters if needs be. Thumbs Up
binge
Emo Kiddy
PostPosted: 23:49 - 06 Feb 2011    Post subject: Reply with quote
If the PCD is so similar, cant you drill the bolt holes slightly bigger in the speedfight wheel?
Failing that, as has already been said, check to see if the offset is the same on the wheels.
If it is then get a PCD plate made up. If it's 10mm thick, just get 10mm skimmed off of the speedfight wheel. Simple. Laughing
The last post was made 15 years, 145 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 126.94 Kb
