| Gazdaman |
 Gazdaman I did a trackday!!!
 Posted: 18:55 - 06 Feb 2011 Post subject: Fitting a different sized scooter wheel, need bright ideas |
So anyway, I bought a Yamaha Aerox 50cc. It has a 13" rear wheel, which makes rear tyre choice almost nil for nobbly tyres.
It's a 3 stud rear wheel, so I bought a Peugeot Speedfight rear wheel, which is also 3 stud, and 12". Fantastic I thought!
Of course the PCD was wrong. So I bought the disc and hub assembly from a speedfight, which should fit over the splines of the final drive on the 'ped.
Here's the kicker, different sized splines.
Now I've looked at the various parts in the final drive and they look completely different. So does anyone have any bright ideas? I've thought about chopping up the two splined shafts and welding the Speedfight one on the end of the Aerox one. But then I'll have an issue that the new end will be bigger than the hole in the crank case, so it'll never be removable. And of course welding it perfectly straight and true will be almost impossible.
The other possibility is fabricating some sort of adapter plate to adapt the PCD, but will obviously space the wheel out slightly.
Sigh.
Gaz |
| G |
 G The Voice of Reason
 Posted: 19:08 - 06 Feb 2011 Post subject: Re: Fitting a different sized scooter wheel, need bright ide |
Get your welder out and add the swing arm of your pit bike on to back of the main swing arm?
You can then add an auxiliary sprocket and chain drive to the current setup.
Anything to assit the competition in a sportsmanly fashion!
You'll also have the added benefit of reduced wheelies and better stability!
Err, more seriously... could you you not weld or otherwise attach some new studs to the original hub? |
| Pedd |
 Pedd World Chat Champion
 Posted: 19:09 - 06 Feb 2011 Post subject: |
can you not just re-drill the aerox hub new add studs??
edit: G posted same but quicker doh ____________________ Dont Click HERE
Current modes of transport = 125 superdream (in bits atm), 1978 GS750 chop, bandit 600(main one), 1982 bmw r100rs,
cx500 trike (hey its fun) oh and the car to ferry the missus and dogs around  |
| Jamie S |
 Jamie S World Chat Champion
 Posted: 19:12 - 06 Feb 2011 Post subject: |
What the hell are you going to be doing with an aerox that means it needs nobbly tyres ....  |
| G |
| nsr_J22_FOXEYE |
 nsr_J22_FOXEYE Scooby Slapper
 Posted: 19:47 - 06 Feb 2011 Post subject: |
That video is amazing, I wish a track was open to do something like that with 3rd class bikes  ____________________ Never Ride Faster Than Your Angel Can Fly |
| G |
| Gazdaman |
| cb1rocket |
 cb1rocket World Chat Champion
| G |
 Posted: 20:34 - 06 Feb 2011 Post subject: |
Judging by your performance last time, you'll crash in the practice and 'adjust' half the modifications anyway .
Not sure if overall I'd worry that much about it being 10mm out - suspect it's an issue for tarmac more, more as we've seen, running knobblies at the limit of grip on tarmac isn't really ideal anyway . |
| Digitalize |
 Digitalize Nearly there...
 Posted: 20:47 - 06 Feb 2011 Post subject: |
Sell the Aerox and buy a Speedfight?
Of course, that would be too easy  ____________________ 1998 CB600F Hornet |
| Gazdaman |
| G |
| Gazdaman |
| GREENI3 |
 GREENI3 World Chat Champion
 Posted: 21:12 - 06 Feb 2011 Post subject: |
That aerox must have been messed up quite badly for 60 quid
| Gazdaman |
| GREENI3 |
| Gazdaman |
| GREENI3 |
 Posted: 21:36 - 06 Feb 2011 Post subject: |
So how can you take part in one of these events?
Seems like a bloody laugh after watching that video.  |
| Gazdaman |
| GREENI3 |
 Posted: 22:10 - 06 Feb 2011 Post subject: |
Cheers Gaz, might look into it.  |
| cb1rocket |
| cb1rocket |
 Posted: 23:32 - 06 Feb 2011 Post subject: |
| cb1rocket |
 Posted: 23:44 - 06 Feb 2011 Post subject: |
could help with a cad drawing to send to the laser cutters if needs be.  |
| binge |
 binge Emo Kiddy
 Posted: 23:49 - 06 Feb 2011 Post subject: |
If the PCD is so similar, cant you drill the bolt holes slightly bigger in the speedfight wheel?
Failing that, as has already been said, check to see if the offset is the same on the wheels.
If it is then get a PCD plate made up. If it's 10mm thick, just get 10mm skimmed off of the speedfight wheel. Simple.  |
The last post was made 15 years, 144 days ago. Instead of replying here, would creating a new thread be more useful? |
