GIVI notice(Max 3kg, 120km/h)
kawashima
PostPosted: 13:11 - 14 Feb 2011    Post subject: GIVI notice(Max 3kg, 120km/h) Reply with quote
Today I found notice message in the GIVI top case.
3kg : Maximum loading capacity per case
Max 120km/H : Maximum speed at full load
I think these limits are too conservative than actual use.
Are these defense by GIVI against lawsuit heaven USA do you think?
(like McDonald coffee case)
https://i21.photobucket.com/albums/b295/kawashima_/Givi-.jpg
own:2020 Serow 250
ncrn
PostPosted: 13:19 - 14 Feb 2011    Post subject: Reply with quote
I've exceed both limits several times with my case and I've never had any issue with it opening/making me crash. I think the limits are there as a precaution as the weight does hang behind the rear wheel which causes the bike to handle differently.
As long as you aren't stupid with the case (i.e. don't carry 40kg in the case when doing 200mp/h) you should be fine really.
crazyjoyce
PostPosted: 13:21 - 14 Feb 2011    Post subject: Reply with quote
ive had at least 15kg's in mine at ~100mph, no problems
Paxovasa
It is them covering their arse's.
PostPosted: 13:26 - 14 Feb 2011    Post subject: Reply with quote
Probably mainly covering themselves, but overloaded cases can certainly provoke handling problems.
kawashima
That makes sense! Precaution. I agree with you. My bikes were relatively heavy, that may be why I didn't feel the difference so huge.
Thanks.
own:2020 Serow 250
kawashima
PostPosted: 13:39 - 14 Feb 2011    Post subject: Reply with quote
I noticed that their 30 litre and 52 litre top cases had both 3kg max limit. They must be coverting themselves. Thanks.
own:2020 Serow 250
PostPosted: 13:57 - 14 Feb 2011    Post subject: Reply with quote
My givi box has a mounting lug missing which has been replaced by a R clip and a Cable tie. I have had easily 4 times that weight in my box and have touched 140 with it. They are fine.
PostPosted: 18:02 - 14 Feb 2011    Post subject: Reply with quote
Kickstart wrote:
...but overloaded cases can certainly provoke handling problems.
Or unsecured loads.
My scariest ride was carrying a 6kg frozen turkey in my topbox. It was interesting to say the least Laughing
PostPosted: 18:15 - 14 Feb 2011    Post subject: Reply with quote
Cruel enough taking a turkey on the bike. You could have at least kept it warm.
Thing the worse load I carried on a bike was a pair of drive shafts for the car with the hubs attached. Although have carried 125 2 stroke engines a few times.
neil.
PostPosted: 11:49 - 15 Feb 2011    Post subject: Reply with quote
I once carried a roof-top UHF TV aerial on the back of my bike. Must have looked quite strange to passers-by! Mr. Green
Gerrard
PostPosted: 12:21 - 15 Feb 2011    Post subject: Reply with quote
I've carried more weight than there limit suggests and its been fine..
Honda Blackbird the great all rounder.
Chillin near Malaga.
Marco Simoncelli 58
PostPosted: 12:31 - 15 Feb 2011    Post subject: Reply with quote
The limiting factor will be the security of the rack, not the box. Since they don't know what sort of cheap arse piece of monkey-steel you've got sellotaped to the bike, they'll err on the side of ridiculous underestimation.
kawashima
PostPosted: 13:37 - 15 Feb 2011    Post subject: Reply with quote
That must be a good reason!
But I noticed that not only Monolock series, but also Monokey series are limited to 3kg max.
own:2020 Serow 250
PostPosted: 19:18 - 15 Feb 2011    Post subject: Reply with quote
Aye, the rack is effectively acting like a lever - stick a 3kg weight on the end of it and start vibrating it up and down and if the mounting points are weak it'll soon shear off.
That being said, I happily carry all my camping gear in my topbox and bounce around B roads with no problems Smile
The last post was made 15 years, 222 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 89.01 Kb
