What the part called?
B
PostPosted: 12:09 - 20 Feb 2011    Post subject: What the part called? Reply with quote
so i took my bike to the mechanics because the throttle was stuck (it didnt snap back like it should) so i took it to my nearest mechanics and they said its something to do with the entire throttle thing that they need to replace my bike has been in the mechinics for over a week(they said they would have the part yesterday) but then they said they wont get the throttle part till next week.. I wanted to know what is this part called? so ill be able to try find it my self..
I would call the mechanics to see what part is called but is not open on sundays.
and apparently the part is around 25-35 pounds/ so all together ill have to pay from 95-75 pounds for the service is that right?
Gilera DNA 50.
PostPosted: 12:24 - 20 Feb 2011    Post subject: Reply with quote
It's probably the throttle cable that needs to be replaced.
It's the throttle return spring in the carb that pulls it closed but I've never seen or heard of one breaking. If the throttle doesn't snap shut, it's usually because the throttle cable has become damaged and is sticking.
I'd imagine a DNA has a long throttle cable with an awkward routing to get to a rear mounted engine so your prices don't sound too far off the mark. They probably have to dismantle half the plastics to get at it which takes a lot of time. Otherwise it's a 5 minute job to change a throttle cable by itself.
Avora
PostPosted: 12:25 - 20 Feb 2011    Post subject: Reply with quote
Sounds like crap to me...in the carb, (if its your DNA) your throttle slide will have got stuck, or got some crap in it...or broken the woodruff key or something along them lines. I'd have just pulled the slide out myself, its unlikely any new part is needed. But its a bike shop you've taken it to, so they are more than likely replacing parts because they can.
Kawasaki AR125 B8 - Getting ready for a summer time soon!
B
PostPosted: 12:27 - 20 Feb 2011    Post subject: Reply with quote
I bought a cable off gileraspares took it to the mechanics and they opened the throttle twist open and then they said the cable is not the problem so they return my new cable back?
Gilera DNA 50.
Paxovasa
PostPosted: 12:28 - 20 Feb 2011    Post subject: Reply with quote
The twist grip?
Motorcycle throttle assembly (that's what I call it).
B
PostPosted: 12:30 - 20 Feb 2011    Post subject: Reply with quote
they said its something where the throttle cable holds? hm
Gilera DNA 50.
Scotsman37
PostPosted: 13:08 - 20 Feb 2011    Post subject: Reply with quote
Did they say it was at throttle twist grip end or at the carb end as that is where the cable ends are held in place?
https://www.gileraspares.co.uk/SPARES/IMAGES/110108/82730r.jpg
https://www.gileraspares.co.uk/SparesGilera/epcImages/DNA50/T34.jpg
B
PostPosted: 13:14 - 20 Feb 2011    Post subject: Reply with quote
they didnt mention anything abou the carb
bit strange maybe is the entire right hand throttle twist?
Gilera DNA 50.
Scotsman37
PostPosted: 13:21 - 20 Feb 2011    Post subject: Reply with quote
Maybe it's the spring which if I am correct forces the thottle to the off position when you release the throttle or possibly within the twist grip where it holds the cable end in place has has worn through
https://flexistentialist.org/gallery_photos/derestriction/8carb.sized.jpg
B
PostPosted: 14:14 - 20 Feb 2011    Post subject: Reply with quote
must be the spring then hmm
is the price fair?
Gilera DNA 50.
PostPosted: 14:19 - 20 Feb 2011    Post subject: Reply with quote
Could also be a worn out throttle slider in the carb sticking on the sides.
You're basically paying them for the part and about an hours labour. Not an unreasonable price. That's what you pay to have stuff done at a shop.
Or have you dropped it at some point? The twist grip mechanism is plastic and I've seen them break underneath the grip.
Scotsman37
PostPosted: 14:30 - 20 Feb 2011    Post subject: Reply with quote
As Stinkwheel stated labour cost is reasonable 1 hours work by mechanic, but till there is clarification to exactly what part is needed replaced we don't know what they have quoted is reasonable priced or not?
Where you got cable also sells that spring if it is that needs replaced!
Best thing to do is state to them that you wanted to be contacted before work goes ahead, as it's only a quote at this stage and as you said the throttle doesn't spring back as it should.
Ask for a detailed explanation of what the mechanic is wanting to do to the bike to fix it and if they are vague and not clear with an answer then they could be fleecing you for a lot of money when it's a job you could do instead buy only buying the part for it if it's easily fixed!
B
PostPosted: 14:55 - 20 Feb 2011    Post subject: Reply with quote
I tried looking through www.gileraspares.co.uk no luck..
Gilera DNA 50.
Scotsman37
PostPosted: 15:34 - 20 Feb 2011    Post subject: Reply with quote
They clearly mark the parts!
https://www.oemparts.eu/default.asp
Gilaraspares/Piaggiospares/Symspares is crap at marking the parts on their list as can be seen via this link and I am worried that a company has to advertise under so many names why not not just say AJ Sutton Spares.
https://www.gileraspares.co.uk/spares/modelImage.asp?modelID=1023
The last post was made 15 years, 133 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 83.26 Kb
