Range limitations of Scart connections
sickpup
Old Timer
PostPosted: 22:55 - 16 Mar 2011    Post subject: Range limitations of Scart connections Reply with quote
Are there any limitations on the length of a scart cable or how many plugs are connected in line to it?
Frost
PostPosted: 23:32 - 16 Mar 2011    Post subject: Reply with quote
10 - 15 meters without amplification.
Fortuna
PostPosted: 03:10 - 17 Mar 2011    Post subject: Reply with quote
True....
but I have seen them go a a lot further unamplified. The standard errs massively on the side of caution.
USB is the same, the standard says 5 metres and ideally 3 yet I've seen it work well at up to 50!
Pernig
PostPosted: 23:37 - 17 Mar 2011    Post subject: Reply with quote
About 2cm when it falls out of the back of your TV because the connector is so heavy.
H100 Breaking for spares
The View Askew
PostPosted: 01:26 - 18 Mar 2011    Post subject: Reply with quote
Bend all the pins very slightly away from each other, will grip like a limpet.
kawakid
PostPosted: 00:44 - 20 Mar 2011    Post subject: Reply with quote
Scart? Technology has moved on my friend.
I've a twin and a 4.
colin1
Captain Safety
PostPosted: 04:13 - 20 Mar 2011    Post subject: Reply with quote
Its not always necessary to go for the latest technology.
PostPosted: 14:47 - 20 Mar 2011    Post subject: Reply with quote
I'm still using scart in my 24inch CRT TV.
It beats the picture on any HD TV close up when you are watching SD.
blurredman
PostPosted: 15:37 - 20 Mar 2011    Post subject: Reply with quote
I'm still using SCART on my VCR
PostPosted: 15:39 - 20 Mar 2011    Post subject: Reply with quote
On your what? Laughing
The View Askew
PostPosted: 17:23 - 20 Mar 2011    Post subject: Reply with quote
This is true, except for some upscaled DVD.
sickpup
Old Timer
PostPosted: 17:59 - 20 Mar 2011    Post subject: Reply with quote
Really?
How would you suggest wiring up a CCTV system that uses scart connections then?
I may sadly have to go wireless for part of it due to cable run sizes it would seem.
PostPosted: 22:04 - 20 Mar 2011    Post subject: Reply with quote
Can't you use an old VCR as a repeater, or something?
Fortuna
PostPosted: 01:12 - 21 Mar 2011    Post subject: Reply with quote
Scart carries RGB, still widely used.
tahrey
PostPosted: 17:51 - 21 Mar 2011    Post subject: Reply with quote
I work as an AV Pro (well ... ok... so-called-pro) and RGB Scart would be a blessed upgrade for most of our installs. The majority of our non-PC video is all Composite, except for those where I've managed to sneak in some S-Video cabling.
The slight, hard to see (with video, rather than graphics) improvement is offset by the extra complexity and cable bulk/cost, and the reduced robustness. Composite travels quite well. RGB doesn't. RGB-VGA even worse. Ghosting and smearing can get quite epic over 10+ metres unless you have very good cables. Beyond 15, maybe 25 I'd generally look at getting Cat5 repeaters instead. The longest we have on stock cable I think is somewhere south of 20 metres in a lecture theatre, with seperately shielded BNC leads for each of RGBHV, and it's still not exactly pin-sharp.
Still, you may be talking about Composite Scart?
As for the number of plugs connected "in line" - do you mean how many outputs branch from the one input or something? I think it'll probably start to degrade badly after the second, maybe third at best. It's meant as a point-to-point connection. Much like VGA, you split it passively (IE without a booster / repeater / active splitter) and the voltage will drop significantly, the image may dim or even just cut.
Don't be a scrub and get a proper powered splitter. The answer then pretty much becomes "how much can you spend?"
Oh, and don't get me started on trying to kill the goddamn VCR. Tutors fuckin' HOARD VHSes for some reason, even though we've had a transfer service running for quite some time. Still, they've proven to be a bit more robust than some of our DVD players, and cetainly the tapes last better than the discs in the hands of the usual hamfisted (ab)user. And unless I have to actually go for quality and have the time/opportunity to repeatedly cue it up until everything works, it's a lot more reliable and easy to use for recording with... and a shortplay tape looks better than a longplay disc.
(PVR or iplayer/etc download FTW, above all those, however ... the former for interlaced or commercial stuff, and the latter for progressive-scan BBC material)
The last post was made 15 years, 187 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 85.87 Kb
