motorbike chains whats the best?
andyboy359
PostPosted: 19:41 - 05 Apr 2011    Post subject: motorbike chains whats the best? Reply with quote
Hello guys/girls Smile Quick question about some chains for my aprilia RS.
Been looking online but can`t tell what the best chains are. I want a chain that will be able to go for along time with no problems (with the rite lubing) Heres some I have been looking at.
1)TKR Roller Chain
2)tvh competiton chain (not sure if thats rite heres a link, https://cgi.ebay.co.uk/APRILIA-RS-50-NEW-CHAIN-SPROCKET-KIT-2006-2008-/160567091568?pt=UK_Motorcycle_Parts&hash=item25628b6170 )
But if theres any other good ones that arn`t over £50 pls do tell me.
Thanks Andrew
neil.
PostPosted: 20:04 - 05 Apr 2011    Post subject: Reply with quote
Haven't heard of those but you won't go wrong with DID although it might be more expensive, but what's it worth to avoid the risk of snapping a cheap chain?
andyboy359
PostPosted: 20:09 - 05 Apr 2011    Post subject: Reply with quote
Very ture Smile i like this one to last me 6months +. Found a cheapish DID one what do you think??
https://cgi.ebay.co.uk/APRILIA-RS50-REPLICA-06-09-DID-STD-CHAIN-SPROCKET-KIT-/170621688972?pt=UK_Motorcycle_Parts&hash=item27b9d85c8c
neil.
PostPosted: 20:14 - 05 Apr 2011    Post subject: Reply with quote
That'd be fine but bearing in mind it isn't an O ring chain, you'd need to keep up with cleaning/lubing it more regularly. Making a chain last is all about proper maintenance - cleaning, lubricating and making sure it's correctly tensioned. Blowing my own trumpet here, but my current chain has done over 16'000 miles and I'm replacing the chain/sprockets only because the front sprocket is worn (chain still has lots of adjustment left) and it's best practice to replace it as all as a set. Thumbs Up
andyboy359
PostPosted: 20:18 - 05 Apr 2011    Post subject: Reply with quote
Yeah that sounds all good Smile however what would you say to use as a lubricate and how would i go about cleaning it?? Smile
Thanks a lot m8 Smile
Frost
PostPosted: 20:39 - 05 Apr 2011    Post subject: Reply with quote
As a lube, well, chain lube is probably alright stuff to use on it Wink
You clean it with something like diesel and a scrubbing brush.
andyboy359
PostPosted: 21:17 - 05 Apr 2011    Post subject: Reply with quote
diesel!? haha and yh i ment like any good make?? Smile thank you guys Smile
andys675
PostPosted: 21:25 - 05 Apr 2011    Post subject: Reply with quote
always use DID Z chain on my 350's, heavy duty, no o rings, just need to keep on top of the lubing and cost less than £50
other brands that are good are EK, RK, tsubaki, renthal
neil.
PostPosted: 21:30 - 05 Apr 2011    Post subject: Reply with quote
Paraffin in a squirty bottle to clean, with a stiff brush like this:
https://www.thevisorshop.com/acatalog/Chain_Brush.jpg
Dry the chain with a rag.
Then get a paint brush and slop on some engine oil, any cheap 10w40 has worked well in my experience.
Then wipe off excess with a rag to avoid flingy mess.
Don't waste money on expensive cans of chain lubricant. And don't be tempted to put the bike in 1st gear to get the chain turning in order to do a quicker job - you're very likely to lose your fingers (it has happened and you can find pics if you search). Turn the back wheel by hand and clean one section of the chain at a time. Thumbs Up
serlant
PostPosted: 21:36 - 05 Apr 2011    Post subject: Reply with quote
My chain maintenance procedure goes clean with a paint brush + paraffin, wipe excess off with kitchen towel then leave to dry for 30 mins while i give the rest of the bike a quick wipe, then toothbrush + engine oil poured into the lid of the oil container and the brush dunked then smeared on the chain. finish.
Edit, as for chains not one to cheap out just went for a DID chain + sprocket set from wemoto.
04 CBR1000RR, 1995 Husqvarna TE410, 1998 VTR1000(Sold), 1990 XJ600(sold), 1996 KH125(dead and sold)
andyboy359
PostPosted: 22:37 - 05 Apr 2011    Post subject: Reply with quote
Ok I probs use a paint brush 2 put the 10w40 got loads of that shit Razz and il get some Paraffin can anyone give me a link where i can grab some pls? Smile And wat about theis chain wax?? dose that do much??
serlant
PostPosted: 22:44 - 05 Apr 2011    Post subject: Reply with quote
For paraffin I just went up B and Q and got the 4 litre bottle for like £12, its either under paraffin or fuel for some sort of oil burner(can't remember name someone enlighten)
andyboy359
PostPosted: 22:48 - 05 Apr 2011    Post subject: Reply with quote
ah ok theres a BnQ near my gfs so i can grab that when i go that way Smile
cb1rocket
PostPosted: 23:02 - 05 Apr 2011    Post subject: Reply with quote
6 - 7 quid in asda Thumbs Up
andyboy359
PostPosted: 23:11 - 05 Apr 2011    Post subject: Reply with quote
i have a look around Razz how many Ls was that?? Smile
cb1rocket
PostPosted: 23:21 - 05 Apr 2011    Post subject: Reply with quote
4 litres
ThoughtContro...
PostPosted: 23:22 - 05 Apr 2011    Post subject: Reply with quote
Has paraffin gone up again? The last 4L lot I got was about a fiver, then it went up to £7. £12 sounds outrageous.
Prize cunt
Beelzebob
PostPosted: 00:06 - 06 Apr 2011    Post subject: Reply with quote
Think paraffin was about 7 or 8 quid for 4l when I was in B n Q t'other day, was out in the garden centre bit by the bubble wrap Thumbs Up
'09 YBR 125 -> '92 XJ600 S Diversion -> '99 Hornet 600
"Stronger than your average female lifeguard"
lozzypop1
Certified MILF!
PostPosted: 00:14 - 06 Apr 2011    Post subject: Reply with quote
Greenhouse heater by any chance?
£12 is expensive, but that's B&Q for you.. try FOCUS DIY instead, just bought a 4l bottle for £6.84 Wink
neil.
PostPosted: 08:48 - 06 Apr 2011    Post subject: Reply with quote
It's sold under the name 'Parasene'. Thumbs Up
deltron
PostPosted: 11:25 - 06 Apr 2011    Post subject: Reply with quote
Sorry to jack the thread but while we're on the subject I've been cleaning my o ring chain with a wd40 type spray, is that ok?
truslack
PostPosted: 11:33 - 06 Apr 2011    Post subject: Reply with quote
No.
andys675
PostPosted: 20:29 - 13 Apr 2011    Post subject: Reply with quote
diesel is good for cleaning chains, £6 for 4 litres
potato
PostPosted: 23:05 - 13 Apr 2011    Post subject: Reply with quote
Please make sure you don't clean the chain while the bike is in gear to try and save time lol, i've seen nasty pics! Shocked Thumbs Up
woll
PostPosted: 23:28 - 13 Apr 2011    Post subject: Reply with quote
truslack wrote:
No.
Any explanation as to why?
The last post was made 15 years, 193 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 125.89 Kb
