Can anyone tell me where to get three of these :P
teampots
PostPosted: 15:40 - 06 Apr 2011    Post subject: Can anyone tell me where to get three of these :P Reply with quote
Its from a S1-250 Fuel tap, where the fuel pipe attaches onto the tap.
sorry for the mixed dimensions
its a push fit connection, needing new ones as 2 are very badly corroded.
Cheers in advance Smile
Current - Fazer 600
Prev - Bandit x2 (Killed) CB400 (Superfour) CBR125
Currently Restoring - Kawasaki S1 250 Triple (Slowly but surely)
Bezzer
PostPosted: 16:07 - 06 Apr 2011    Post subject: Reply with quote
Obviously the barbed end is for the tube is the plain end an interference fit in the tap body then?
If it is you'd have to send me the tap and bit and I could knock you some out in brass then it won't go again, if the plain end isn't an interference fit just the bit will do. Just cover the cost of metal and postage, say £3?
teampots
PostPosted: 16:38 - 06 Apr 2011    Post subject: Reply with quote
I believe it is an interference fit, and you would be a legend if you could make some up,
Can you PM me some details and I will get the tap and bit sent across to you Razz
Current - Fazer 600
ZRX61
Victor Meldrew
PostPosted: 00:13 - 07 Apr 2011    Post subject: Reply with quote
In the past I've cleaned em up & used 3Bond to stick em back in Smile
They're not one night stands, they're auditions.
Redoko
PostPosted: 00:31 - 07 Apr 2011    Post subject: Reply with quote
Just out of curiosity, how come you stated one in metric and the other in imperial measurements?
prawny1
PostPosted: 00:35 - 07 Apr 2011    Post subject: Reply with quote
Do you have enough material to tap the body then cut a tread on the pipe part and screw it back in with some locktight/sealer or something.
If the original pipe s too corroded you could get some tube the same diameter I should think.
hellkat wrote:
ZRX61
Victor Meldrew
PostPosted: 02:58 - 07 Apr 2011    Post subject: Reply with quote
Because pipe fittings are BSP Wink
PostPosted: 06:27 - 07 Apr 2011    Post subject: Reply with quote
How can it be BSP when it's not threaded?
teampots
PostPosted: 17:47 - 07 Apr 2011    Post subject: Reply with quote
I used those measurements as they were nearest rounded figures on the tape measure (probably wrong anyway)
1/4 inch was easier then 6.35mm and 21mm was easier than 0.82 inches
anyway tap has been sent off to Bezzer who kindly offered to do all the hard work Very Happy
Current - Fazer 600
The last post was made 15 years, 197 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 60.27 Kb
