Brake light not working?
GREENI3
PostPosted: 14:16 - 19 Apr 2011    Post subject: Brake light not working? Reply with quote
My brake light doesn't seem to be working.
It's always on, but when I pull in either brake levers it doesn't get brighter.
Put in a new battery the other week, so it can't be that.
Any ideas?
Thanks Thumbs Up
Chriss
PostPosted: 14:26 - 19 Apr 2011    Post subject: Reply with quote
Hi, have you checked the micro switches for operation? You should be able to hear a little click when you pull the lever in.
Fingers crossed it's just the one side that's stuck in (by the sounds of it) and won't click (since it's already in) and you know where the fault lies.
TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old.
PostPosted: 14:28 - 19 Apr 2011    Post subject: Reply with quote
In addition to what Chriss says, first thing to check is whether it is stuck on or not.
When you say the light is always on, is just just the tail light or is it the brake light?
stirlinggaz
PostPosted: 14:35 - 19 Apr 2011    Post subject: Reply with quote
dual filament bulb? & 1 of thems had it....new bulb?
cheers,
GAZ
devojunior
PostPosted: 14:55 - 19 Apr 2011    Post subject: Reply with quote
ha as if it took that long before somone said the obviouse lol good luck.
GREENI3
PostPosted: 19:04 - 19 Apr 2011    Post subject: Reply with quote
Ah sorry about that, it's the tail light that's always on.
ozzy r6
PostPosted: 22:47 - 19 Apr 2011    Post subject: Reply with quote
as been said have you check that the bulb is not at fault
yamaha r6 5sl
PostPosted: 23:04 - 19 Apr 2011    Post subject: Reply with quote
In which case first thing to check is the bulb definitely.
The Tot
PostPosted: 08:10 - 20 Apr 2011    Post subject: Reply with quote
It was a common problem on my blade with a faulty brake light switch. It's usually mounted under your handlebar. Remove the switch and run a multimeter across the terminals on the loom. If you get continuity, you're fine. Then do the same check on the contacts on the switch. If it's giving a nil reading, then get yourself onto www.wemoto.com and order yourself a new brake light switch! They deliver within 2-3 working days. It happened twice on my bike. So when I popped off the switch to investigate, I saw lots of green copper oxide inside the mechanism so I instantly knew why it wouldn't work. It's very easy for water to get into the switch. The rear brake light switch is usually protected by a rubber boot so doesn't succumb to it as much.
Never argue with autism
Chriss
PostPosted: 10:04 - 20 Apr 2011    Post subject: Reply with quote
Not on a moped (I had to Google what sort of bike it was first to be fair.)
GREENI3
PostPosted: 11:18 - 20 Apr 2011    Post subject: Reply with quote
The bulb seems to be stuck inside the socket.
Before being able to take the bulb out, you have to line up these two bits on the bulb with the two holes on the socket. Well, it won't move whatever I do.
This happened to one of my indicators and I ended up snapping half the bulb off.
Any ideas on how to get the bulb out?
Chriss
PostPosted: 11:20 - 20 Apr 2011    Post subject: Reply with quote
Do you have a picture of it? I would have expected it to be a bayonet connector.
Is this it here? If so, push gently and twist. Also, have you changed the bulb recently? I once managed to put one in the wrong way, and so the brake light was permanently lit.
The last post was made 15 years, 194 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 72.91 Kb
