| GREENI3 |
 GREENI3 World Chat Champion
 Posted: 14:16 - 19 Apr 2011 Post subject: Brake light not working? |
My brake light doesn't seem to be working.
It's always on, but when I pull in either brake levers it doesn't get brighter.
Put in a new battery the other week, so it can't be that.
Any ideas?
Thanks  |
| Chriss |
 Chriss World Chat Champion
| stirlinggaz |
| devojunior |
 devojunior Brolly Dolly
| GREENI3 |
| ozzy r6 |
 ozzy r6 Renault 5 Driver
| The Tot |
 The Tot World Chat Champion
 Posted: 08:10 - 20 Apr 2011 Post subject: |
It was a common problem on my blade with a faulty brake light switch. It's usually mounted under your handlebar. Remove the switch and run a multimeter across the terminals on the loom. If you get continuity, you're fine. Then do the same check on the contacts on the switch. If it's giving a nil reading, then get yourself onto www.wemoto.com and order yourself a new brake light switch! They deliver within 2-3 working days. It happened twice on my bike. So when I popped off the switch to investigate, I saw lots of green copper oxide inside the mechanism so I instantly knew why it wouldn't work. It's very easy for water to get into the switch. The rear brake light switch is usually protected by a rubber boot so doesn't succumb to it as much. ____________________ The Tot 2019 Z1000SX - 2007 R1
Never argue with autism |
| Chriss |
| GREENI3 |
| Chriss |
 Posted: 11:20 - 20 Apr 2011 Post subject: |
Do you have a picture of it? I would have expected it to be a bayonet connector.
Is this it here? If so, push gently and twist. Also, have you changed the bulb recently? I once managed to put one in the wrong way, and so the brake light was permanently lit. ____________________ TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old. |
The last post was made 15 years, 195 days ago. Instead of replying here, would creating a new thread be more useful? |
