Bit of delay...Or lag?
sandman1976
PostPosted: 16:36 - 27 Apr 2011    Post subject: Bit of delay...Or lag? Reply with quote
Hey chaps!
CG125,.....bit of delay picking up, then takes off like a looney!
Q is, whats causing the lag?
Thanks Smile
lozza
PostPosted: 16:51 - 27 Apr 2011    Post subject: Reply with quote
depends what it is youre talking about.....
rrrring ding ding ding
PostPosted: 17:07 - 27 Apr 2011    Post subject: Reply with quote
Sounds sort of like you're describing a CG125 apart from the 'takes off like a looney' bit...
Paxovasa
PostPosted: 17:10 - 27 Apr 2011    Post subject: Reply with quote
You need to change the powerband for a green one Thumbs Up
Nexus Icon
PostPosted: 17:29 - 27 Apr 2011    Post subject: Reply with quote
Sounds like you've fitted a bigger turbo than standard, tbh.
Greetings from Shitsville!
Teflon-Mike
tl;dr
PostPosted: 17:39 - 27 Apr 2011    Post subject: Reply with quote
Well my bet is that the wings are on upside down......
sandman1976
PostPosted: 20:16 - 27 Apr 2011    Post subject: Reply with quote
rob yarrr wrote:
i'm guessing that you are wacking the throttle open,bogging it down untill it picks up again
see if your excellerator pump still works if your cg's old
Yea its kind of bogging down, Is that the pump on the split of the throttle cable? on one side of the carb?
ZRX61
Victor Meldrew
PostPosted: 05:53 - 28 Apr 2011    Post subject: Re: Bit of delay...Or lag? Reply with quote
Thanks Smile
Buffering Wink
They're not one night stands, they're auditions.
Teflon-Mike
tl;dr
PostPosted: 09:15 - 28 Apr 2011    Post subject: Re: Bit of delay...Or lag? Reply with quote
ZRX61 wrote:
Thanks Smile
Buffering Wink
Hadn't thought about that..... it'll be the engine management micro processor, wont it. Doesn't that happen, when you have fitted the red power band, and at about 120, it starts logging fault codes from the ABS sensor, filling the fault code store?
sandman1976
PostPosted: 11:25 - 28 Apr 2011    Post subject: Re: Bit of delay...Or lag? Reply with quote
Buffering Wink[/quote]
Hadn't thought about that..... it'll be the engine management micro processor, wont it. Doesn't that happen, when you have fitted the red power band, and at about 120, it starts logging fault codes from the ABS sensor, filling the fault code store?[/quote]
Yea well i reckon its the big end flim flam myself, Might be the turbo system from the cossie i fitted with stickyback plastic and superglue but i highly doubt it as i dont buy cheap superglue Laughing Wink
A++ For sarcasm lads! Thumbs Up Thumbs Up Thumbs Up Mr. Green
prawny1
PostPosted: 12:04 - 28 Apr 2011    Post subject: Reply with quote
The accelerator pump was fitted so honda could jet the bike leaner without having it bog down when the throttle is quickly cracked open.
So it might well be whats causing the issue that or a serious air leak somewhere
hellkat wrote:
The last post was made 14 years, 280 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 80.12 Kb
