Expensive or Blue-stripe 2-stroke?
Martay
PostPosted: 22:29 - 12 May 2011    Post subject: Expensive or Blue-stripe 2-stroke? Reply with quote
Hi,
Is there alot of difference between the expensive and dirt-cheap 2-stroke oil? (besides the price obviously!)
Ive finally got my SH50 on the road, and have been using it constantly for the past 3 days, its so fun!! Its now time to top up the oil. Its a standard ancient honda engine so is capable of being run on horse piss with soil mixed in, so will expensive oil make a lot of difference?
Also, I have turned the oil supply up as when hot it was really rattly. This has cured the problem but it now smokes heavily when cold. Im not bothered as its clean when hot, would this cause a problem?
Ta
Eat well, poo hard Very Happy
Drives: Cavalier 2.0 16v
PostPosted: 22:46 - 12 May 2011    Post subject: Reply with quote
Quality 2-stroke oil is better than cheapo oil no matter what engine you put it in. 2-strokes are marginally lubricated so you should give it the best chance you can.
As for over-oiling - carry spare plugs. It won't hurt your engine but it might foul the plug.
reggie
PostPosted: 00:04 - 13 May 2011    Post subject: Reply with quote
id run it on cheep shit tbh the cost of a barrel and piston on most 50cc bikes is so cheep
when the shit hits the fan make sure its facing the other way.
27cows
PostPosted: 05:48 - 13 May 2011    Post subject: Reply with quote
On a low performance 2 stroke motor, expensive oil is a waste of money. I've used cheapo stuff in my RXS for years and had ridiculously high mileages out of components.
Wilko and Tesco 2T is fine.
PostPosted: 05:50 - 13 May 2011    Post subject: Reply with quote
Well it's not expensive at £70 for a piston & barrel but not exactly pennies either.
PostPosted: 07:08 - 13 May 2011    Post subject: Reply with quote
This,
The RS/NSR/Mito bikes obviously run with the expensive oil, much higher state of tune engines.
You can try lower quality oil, you might get lucky Mr. Green
I owned a little KH125, which was run on "carlube" 2 stroke oil and never once let me down. Thumbs Up
Wyldkat
PostPosted: 10:00 - 13 May 2011    Post subject: Reply with quote
I agree with Paddy, I use ASDA's own (used to be Carplan...)
pound for pound, it's cheaper than Wilkies and does the same job.
27cows
PostPosted: 16:58 - 13 May 2011    Post subject: Reply with quote
Wilko's has gone up from £1.99 for 600ml to £2.39 in a matter of weeks. But I think it still works out marginally cheaper than both Tesco and Asda. £4.78 for 1.2ltr against £4.20 for Asda and £4.50 for Tesco 1ltr. Saying that, Tesco seems to be quite decent oil, relatively speaking, so that's what I mostly use.
dangerousdave
PostPosted: 19:53 - 13 May 2011    Post subject: Reply with quote
The more expensive oil smokes less.
Not sure if you'll see much difference in reliability with much more expensive oil. Just keep the oil tank topped up !
1988 Kawasaki KMX 200
Previous: Yamaha YZF1000, ZZR600, KMX200, DT50, KX80, CG125, PF50
The last post was made 15 years, 138 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.14 - MySQL Queries: 13 - Page Size: 60.51 Kb
