resto of a cb550 k3
retrobiker
PostPosted: 23:46 - 13 May 2011    Post subject: resto of a cb550 k3 Reply with quote
hi all
thought i would share this with you... getting back into biking, just took my cbt and preparing for my big bike test
this was the same bike my old man had so thought it would make a nice link
https://i156.photobucket.com/albums/t6/mike070868/side1.jpg
bike when i started
https://i156.photobucket.com/albums/t6/mike070868/side2.jpg
retrobiker
PostPosted: 23:48 - 13 May 2011    Post subject: Reply with quote
will be stripped down and cleaned and sprayed and powdercoated where needed
https://i156.photobucket.com/albums/t6/mike070868/Picture062.jpg
https://i156.photobucket.com/albums/t6/mike070868/Picture067.jpg
https://i156.photobucket.com/albums/t6/mike070868/Picture033-1.jpg
retrobiker
PostPosted: 23:50 - 13 May 2011    Post subject: Reply with quote
frame powdercoated in silver... not going to be original just a very nice version of it
https://i156.photobucket.com/albums/t6/mike070868/caseygoingtoparty030-1.jpg
yokes , caliper etc
https://i156.photobucket.com/albums/t6/mike070868/caseygoingtoparty028.jpg
retrobiker
PostPosted: 23:51 - 13 May 2011    Post subject: Reply with quote
guards rechromed in look a like chrome , not to bad a finish but not real chrome as such
https://i156.photobucket.com/albums/t6/mike070868/HPIM1761.jpg
https://i156.photobucket.com/albums/t6/mike070868/HPIM1763.jpg
retrobiker
PostPosted: 23:52 - 13 May 2011    Post subject: Reply with quote
headset and bearings back in
https://i156.photobucket.com/albums/t6/mike070868/HPIM1805.jpg
https://i156.photobucket.com/albums/t6/mike070868/HPIM1767.jpg
retrobiker
PostPosted: 23:55 - 13 May 2011    Post subject: Reply with quote
engine was stripped to base , pistons and rings were pretty good and ok to go back in ... had this checked by an ex 70's honda mechanic and gave me the green light
https://i156.photobucket.com/albums/t6/mike070868/cylinderhead001.jpg
https://i156.photobucket.com/albums/t6/mike070868/cylinderhead003.jpg
https://i156.photobucket.com/albums/t6/mike070868/gasket2.jpg
retrobiker
PostPosted: 23:57 - 13 May 2011    Post subject: Reply with quote
paint this time.. high temp paint
https://i156.photobucket.com/albums/t6/mike070868/engine016.jpg
https://i156.photobucket.com/albums/t6/mike070868/engine017.jpg
top cover back on
https://i156.photobucket.com/albums/t6/mike070868/camc1.jpg
retrobiker
PostPosted: 23:58 - 13 May 2011    Post subject: Reply with quote
pesky carb cleaning
https://i156.photobucket.com/albums/t6/mike070868/tachodrive004.jpg
retrobiker
PostPosted: 00:00 - 14 May 2011    Post subject: Reply with quote
wheels.. both wheels got new bearings
https://i156.photobucket.com/albums/t6/mike070868/rearhubemptyhub.jpg
retrobiker
PostPosted: 00:02 - 14 May 2011    Post subject: Reply with quote
engine is back in frame, done the frame over engine trick
front wheel has just had a new rim and spokes
off to get some new tyres soon
will continue to post if any interest
cheers guys Smile
fiveus
PostPosted: 01:15 - 14 May 2011    Post subject: Reply with quote
looking good buddy Thumbs Up
will be following this one.Can't wait to see the finished result Very Happy
PostPosted: 06:00 - 14 May 2011    Post subject: Reply with quote
Looking good, but I would have taken the dipstick out before spraying the engine, that's going to flake when you undo it Smile
retrobiker
PostPosted: 11:05 - 14 May 2011    Post subject: Reply with quote
yeah your probably right about dipstick .. i will find out later Laughing
could always do it in black
nearly at the stage now a rolling chassis
i am not a mechanic , its all been done from books, forums like this and an ex honda mechanic i bumped into
more pics later in week when i get these tyres back
Tim..
PostPosted: 11:54 - 14 May 2011    Post subject: Reply with quote
Keep posting, look like a good build so far Thumbs Up Karma
Did you put new headstock bearings in? Its something I normally do on a full build.
www.marshallracing.co.uk
retrobiker
PostPosted: 12:10 - 14 May 2011    Post subject: Reply with quote
yes mate i did... david silvers is loving me at the moment
if i recall bearings were loose.. now got the new tapered roller bearings.. feels much better
trying to keep it looking original as i can but if there are better safer items i am going to use them
learning as i go and you get to know the bike better as well
Gazdaman
I did a trackday!!!
PostPosted: 12:17 - 14 May 2011    Post subject: Reply with quote
Moar photos needed.
And I assume it's a mistake in your post where you said the ex-Honda mechanic gave you the "red light" on your engine.
Gaz
retrobiker
PostPosted: 12:30 - 14 May 2011    Post subject: Reply with quote
Embarassed
yeah good spot , of course i meant green light ,he gave it a good look over
not entirely sure what he was looking for, engines on these seem pretty tough and well built, it had good compression but did have a couple of leaks
stem seals were one of the items he suggested changing, he had a good look at pistons and they seemed fine
main problem was getting out the oil filter bolt
basically all i have done is change all gaskets down to base gasket
cam chain was also fine
not sure how long this is going to take as new to this.. but been fun and learning a lot
Gazdaman
I did a trackday!!!
PostPosted: 12:33 - 14 May 2011    Post subject: Reply with quote
Looks like it's well on the way to being finished! Depends if the bodywork needs painting or not.
Gaz
retrobiker
PostPosted: 12:37 - 14 May 2011    Post subject: Reply with quote
i have some questions as well to ask
want to do some upgrades if possible, one being the new headstock bearings and tyres spring to mind
4 into 4 exhaust now unavailable, i have the exhausts but there like dust inside
david silvers only list a motad 4 into 1, £250 good value? any downsides in going 4 into 1 ?
https://i156.photobucket.com/albums/t6/mike070868/taper1-1.jpg
headstock going on
retrobiker
PostPosted: 12:40 - 14 May 2011    Post subject: Reply with quote
cheers , i have been working hard on it
the amount of crud on it though was pretty bad
to give you an idea
https://i156.photobucket.com/albums/t6/mike070868/Picture071.jpg
after
https://i156.photobucket.com/albums/t6/mike070868/HPIM1963.jpg
still got the wiring to do which i am dreading
Gazdaman
I did a trackday!!!
PostPosted: 12:45 - 14 May 2011    Post subject: Reply with quote
Mmm, that last photo is porn.
On the tyre front, for a bike like that it would depend on sizes. I would suspect that Bridgestone BT45s would be a good choice, assuming it has similar sizes to the usual commuter bikes.
Head bearings are head bearings pretty much. Fit the new ones, they'll be smooth and not have play in them. Sorted, that's all you need.
Exhaust wise, 4-1 is fine. Although the Motad one I had on my old XJ600 wasn't of the best quality, and didn't look fantastic. £250 is a fair amount of money, but if it's for a full system you won't find a lot cheaper.
Gaz
Teflon-Mike
tl;dr
PostPosted: 13:56 - 14 May 2011    Post subject: Reply with quote
I would try and hunt out replica four pipes.
4-1 was common 'in the day', but now, they are more atractive / desirable, with original four pipes.
Dave Silvers are good, but they are a Super Market for all things Honda, they dont always have the niggly bits a restorer wants.
There are plenty of specialists making replica chrome pipes, and even if you cant get a full system, you almost certainly will be able to get something more 'sympathetic' by way of pattern silencers, some one can bend some headers to, for you to get chromed.
Bit of research needed I reckon.
Given what you must be spending on this bike... its those 'little' things that make the difference between achieving the 'restored' look you want, or merely another tarted old up old bike.
Other wise, keep an eye on the oil seals, particularly the sprocket and gearbox shaft seals, one or other is particularly prone to popping, and I 'think' its the gear selectorshaft seal that can inadvertantly be fitted backwards!
CHR15
Turbo nutter bastard
PostPosted: 16:29 - 14 May 2011    Post subject: Reply with quote
id get the exhaust system sand blasted.
see what its like after that, if its good, get it ceramic coated, you keep the 4>4 and it looks nice.
paddlesat16
PostPosted: 18:46 - 15 May 2011    Post subject: Reply with quote
Avon Roadriders for the tyres, most classic hondas etc run em and there pretty grippy and not overly expensive.
https://www.avon-tyres.co.uk/motorcycle/roadrider
I once saw a bloke shagging a donkey.... in Saudi arabia. Theory Test Passed 26/10/09 Mod 1 Passed 26/4/10, Mod 2 Passed 7/6/10 Current Bikes Suzuki GSX1400 K5, Aprillia Pegaso 650, Suzuki DR350T.
Frost
PostPosted: 20:47 - 15 May 2011    Post subject: Reply with quote
4-1 tends to give more mid range, but less top end power, also looks wise the 4 pipes are very very nice.
The last post was made 15 years, 188 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 130.56 Kb
