Loss of power (SV650)
Jestered1
PostPosted: 08:15 - 15 Jun 2011    Post subject: Loss of power (SV650) Reply with quote
Hi people
Was riding my SV yesterday, was in 3rd gear giving it a handfull then changed to 4th and the power just went. When I tried to give it some throttle it would just splutter a bit. I didn't get any bad noises or smoke.
It got me home at low revs and generally seems ok (tickover is fine etc). It just revs to about 3-4000 and then starts to splutter.
Any ideas on where to start and what to check will be much appreciated?
Jestered
Chriss
PostPosted: 10:34 - 15 Jun 2011    Post subject: Reply with quote
Hi,
What year is it? Have you checked obvious things like making sure there's enough oil (I doubt this would be the prbolem)? Checked the fuel filter? Any errors show up on the dash? Any warning lights?
TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old.
PostPosted: 12:04 - 15 Jun 2011    Post subject: Reply with quote
If that happened on a car, I'd suspect the ECU may have gone into "limp home" mode due to not getting information from (e.g.) the lamda sensor.
I'm not suggesting that's what happened to your bike, I'm just floating a balloon. https://forums.sv650.org will be able to give more specific advice.
nowhere.elysium
The Pork Lord
PostPosted: 12:21 - 15 Jun 2011    Post subject: Reply with quote
However, there's every chance that the OP is riding a Mk 1 SV, in which case this advice would be rendered invalid.
OP: as a starting point, what year is the SV?
Jestered1
PostPosted: 12:29 - 15 Jun 2011    Post subject: Reply with quote
It's a 2000 model. Sorry probably should have mentioned that. Embarassed
Oil level fine, no lights on the clocks. Not had a chance to give it a proper check, thats what I'm after really. Where would you guys start?
PostPosted: 12:39 - 15 Jun 2011    Post subject: Reply with quote
When where the plugs last changed?
Chriss
PostPosted: 13:14 - 15 Jun 2011    Post subject: Reply with quote
As above, spark plugs is a good start.
I'd be looking at the fuelling then as a start. If it runs fine low in the revs, something might be stopping it from getting enough fuel for high revs. Fuel filter might be blocked, so I'd replace that. After that is the carbs, so whilst the air box is off (if I recall correctly), check the state of your air filter and then take the carbs off and clean those.
nowhere.elysium
The Pork Lord
PostPosted: 14:35 - 15 Jun 2011    Post subject: Reply with quote
Make sure the airbox is properly connected to the carbs, and check the state of the plugs and leads. I don't reckon that it'd be electrical, given that it's specific to a rev range.
If the airbox is seated properly (you can check by spraying WD40 on the carb rubbers while it's running: if the idle changes speed, then you've got an air leak), then you may want to be looking at cleaning the jets.
PostPosted: 15:19 - 15 Jun 2011    Post subject: Reply with quote
If plugs are on there way out they often get to a point where you can't push above a rev range under load.
nowhere.elysium
The Pork Lord
PostPosted: 15:30 - 15 Jun 2011    Post subject: Reply with quote
Learn something new every day.
Willson
PostPosted: 15:43 - 15 Jun 2011    Post subject: Reply with quote
If the fuel system is shitted up you could try some Redex fuel system cleaner in there.
Willson
Benson: Wouldn't life be easier if we were all turtles?
Me: Pig on bread = The way forward.
Riding: '00 Suzuki SV650S. Previous: '99 Kawasaki ER5 - sold, '02 Suzuki GZ125 Marauder - sold
P.
PostPosted: 17:35 - 15 Jun 2011    Post subject: Reply with quote
Willson
You are aware redex does pretty much shit all? If the fuelsystem gets that bad on a bike, whip the carbs off and find the ofending junk rather than pour some coloured piss in the tank?
OP, pull the plugs out... it costs like £4 for 2 new ones, pop them in and see how the bike runs then.
The last post was made 14 years, 192 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 76.15 Kb
