V8 coffee table - Finished
Tim..
PostPosted: 13:31 - 25 Jun 2011    Post subject: V8 coffee table - Finished Reply with quote
Wasn't sure which topic to put this in so feel free to move this thread mods.
Have always wanted the engine block table that they have on Top Gear and the other month after a related discussion at work my calibration engineer said his old man had one lying around in the garden. I said how much, his said 'dunno, 20 quid?'. Result!!
A few days later he brought it to work.
After a long time on the media blaster, the block was cleaned up, measured, marked, drilled and tapped. After some fettling the pistons were level enough to mount the glass.
The pistons and rods were then blasted and everything brought home for painting.
Pictures to follow shortly and everything will make sense Wink .
www.marshallracing.co.uk
Tim..
PostPosted: 14:06 - 25 Jun 2011    Post subject: Reply with quote
Pics as promised.
How I got the block.
https://i475.photobucket.com/albums/rr119/Timon1983/V8%20Coffee%20Table/Photo025.jpg
All stripped apart.
https://i475.photobucket.com/albums/rr119/Timon1983/V8%20Coffee%20Table/Photo027.jpg
The scrap.
https://i475.photobucket.com/albums/rr119/Timon1983/V8%20Coffee%20Table/Photo030.jpg
All blasted clean.
https://i475.photobucket.com/albums/rr119/Timon1983/V8%20Coffee%20Table/Photo003.jpg
Marked and drilled.
https://i475.photobucket.com/albums/rr119/Timon1983/V8%20Coffee%20Table/Photo004.jpg
Dry build.
https://i475.photobucket.com/albums/rr119/Timon1983/V8%20Coffee%20Table/Photo001.jpg
All done, ready for paint.
https://i475.photobucket.com/albums/rr119/Timon1983/V8%20Coffee%20Table/Photo006.jpg
Pistons and rods blasted and laquered.
https://i475.photobucket.com/albums/rr119/Timon1983/V8%20Coffee%20Table/Photo010.jpg
Undercoated block.
https://i475.photobucket.com/albums/rr119/Timon1983/V8%20Coffee%20Table/Photo0044.jpg
All painted and ready for glass (which I need to measure and order).
https://i475.photobucket.com/albums/rr119/Timon1983/V8%20Coffee%20Table/Photo002.jpg
kerr
PostPosted: 14:58 - 25 Jun 2011    Post subject: Reply with quote
want Shocked thats going to be awesome Thumbs Up
aprilia 125 Af1 Futura >> Suzuki gsxr 600 srad >> J1 zx6r >> cbr 600rr >> Speed Triple
waffles
PostPosted: 15:08 - 25 Jun 2011    Post subject: Reply with quote
Wow, not a bad table for £20 so far! Thumbs Up
fezza612
PostPosted: 15:26 - 25 Jun 2011    Post subject: Reply with quote
it's identical to this https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=330577406511&clk_rvr_id=243470193237&item=330577406511&lgeo=1&vectorid=229508
i say sell it Thumbs Up
Previous: '02 Honda CG125, '03 yamaha enticer
Current: '98 Kawasaki GPZ500S
HoggyF
PostPosted: 15:29 - 25 Jun 2011    Post subject: Reply with quote
Use all 8 pistons & rods - it'd be rude not to! Very Happy
Charlie
PostPosted: 16:05 - 25 Jun 2011    Post subject: Reply with quote
I have to agree.... It is a v8 after all!
Tim..
PostPosted: 16:10 - 25 Jun 2011    Post subject: Reply with quote
Block only came with one bank of pistons.
I'm quite happy with the way it has turned out tbh.
Charlie
PostPosted: 16:11 - 25 Jun 2011    Post subject: Reply with quote
Definitely think it looks good, but just feel a v8 should have 8 pistons on show. I'd be very happy if I could make something like that Thumbs Up
CarlosCBR
PostPosted: 16:52 - 25 Jun 2011    Post subject: Reply with quote
Awesome. Me and a mate have just made a small table from an old 4 cylinder Golf engine, wanted to do a V8 but could only find old Land Rover engines.
Tim..
PostPosted: 17:02 - 25 Jun 2011    Post subject: Reply with quote
Pics?
Teflon-Mike
tl;dr
PostPosted: 17:09 - 25 Jun 2011    Post subject: Reply with quote
https://i178.photobucket.com/albums/w269/teflons-torque/tear/13650006.jpg
This very nearly bacame a coffee table.....
It had lived inside a Range Rover, until the ex missus killed it! So I took it out to 'Do the Heads'....
https://i178.photobucket.com/albums/w269/teflons-torque/tear/13670013.jpg
The rocker covers were a bit 'Scabby'
https://i178.photobucket.com/albums/w269/teflons-torque/072_B_001_Tear/13660026.jpg
I had the thunk, that a V8 is a bit 'Special' so ought to LOOK a bit special, especially since I was spending an awful lot of money reconditioning it's insides.... Becouse at this point, 'doing the Cylinder Heads' had become doing a complete engine overhaul, and I was a bit 'stuck' while the block was at the M/C shop being bored and the crank ground and 'stuff'... so I decided the rocker covers ought to be polished.... then I decided they still looked crap, so I'd paint them.... but that ribbing ought to be blocked out..... and THEN I got a bit 'carried away'!
https://i178.photobucket.com/albums/w269/teflons-torque/072_B_001_Tear/13680006.jpg
And painted the sump pan... and inlet manifold... and since the carb overhaul kit arrived before the engine block was 'done'... I did the carb bodies!
https://i178.photobucket.com/albums/w269/teflons-torque/tear/13680005.jpg
Only trouble was, the more bits I 'Did' the more it showed up the bits I HADN'T done.... so I ended up colour matching the fan, the distributor cap, every bludy thing!
Apart from the dip stick and oil filler... which I painted BRIGHT YELLOW... in the hope that the idiot woman MIGHT actually be able to find them and check the oil....
https://i178.photobucket.com/albums/w269/teflons-torque/tear/13680070.jpg
Looked so stunning by the time I was done, I REALLY didn't want to stick it back under the bonnet of a Range Rover!
Blogged, I actually had a bloke offer to buy it to stick in a Hot-rod, where it would have been seen.... but in the end.... wound up hidden away back under the bonnet of the Blue Rangie it came out of.....
https://i178.photobucket.com/albums/w269/teflons-torque/tear/13680076.jpg
Missus fucked off in that car six weeks later..... still miss the car......
Teflon-Mike
tl;dr
PostPosted: 17:15 - 25 Jun 2011    Post subject: Re: V8 coffee table Reply with quote
Of course, that's the undominable Buic 213 sub-small block alloy V8 you have coffee tabled, like the 3.5 lump that was in my old Rangie.
The Top Gear V8 Coffee table, is I believe a Porshe 928 block.
If you remember, in one of the Top Gear Challenges, the three were set the task of buying a Porshe for under £2K or something, and then had to do whatever to them...... Hamster bought a 924, I think, cant remember what Cpt Slow bought, The curley one bought a 928, and pipped them with the final challenge, selling the thing to recoup costs... and he sold his as 'spares'.....
Aparently he'd had the idea from buying the coffee table in the first place and taking to the chap that made 'Designer' Auto-Furniture.....
Tim..
PostPosted: 17:30 - 25 Jun 2011    Post subject: Reply with quote
Correct, mine is an old rover lump.
I wasn't majorly fussed about getting an exact same engine as TG, more that I just wanted to build a V8 table and pi55 the gf off by having it in the front room.
CHR15
Turbo nutter bastard
PostPosted: 18:10 - 25 Jun 2011    Post subject: Reply with quote
make sure you get rounded corners and bevelled edges on the glass.
Ditto
PostPosted: 18:45 - 25 Jun 2011    Post subject: Reply with quote
Top gear coffee table is a Jaguar V12.
https://www.record-designs.co.uk/
Doesn't use the pistons either.
CG 125 > Bandit 600 > CBR 600 FY > Street Triple R
Dazbo666
PostPosted: 18:56 - 25 Jun 2011    Post subject: Reply with quote
Would loooove to make up one of these tables myself too.
My son's a bigger petrol-head that I am (studying automotive and aeronautical engineering ATM), so I'm sure I could recruit his help too Thumbs Up
Word of the day : DILLIGAF
Billing
PostPosted: 19:43 - 25 Jun 2011    Post subject: Reply with quote
Good inspiration mate, might have to crack on with my half size V4 night stand using an old VFR lump Razz
Tim..
PostPosted: 00:16 - 26 Jun 2011    Post subject: Reply with quote
Now there's an idea! I have my old nc30 engine under the work bench. Could make a matching night stand Thumbs Up
Billing
PostPosted: 00:25 - 26 Jun 2011    Post subject: Reply with quote
I was going to try and get one that had dropped a valve or cracked a head, then cut it in half so you could see the valves and pistons working Smile
Also the VFR has a very useful way of mounting the glass top, which I think you already know about, but PM me if you want me to share with you Thumbs Up
bikerguy
PostPosted: 17:27 - 26 Jun 2011    Post subject: Reply with quote
cool table Very Happy
HoggyF
PostPosted: 12:38 - 27 Jun 2011    Post subject: Reply with quote
Just had a thought, I've got a pitbike engine in bits on my bench at the mo - Could it be made into a footstool???? pmsl;-p
Andy_Pagin
PostPosted: 12:59 - 27 Jun 2011    Post subject: Reply with quote
Dunno where you are in the country Tim, but if you're even vaguely near north London these guys can make absolutely anything you can imagine out of glass - https://www.instrumentglasses.com/
They're one of those little family type businesses based in some run down looking 1930s factory units, no job's too small and they're not expensive.
Maybe a photo of your bike etched into the glass, or a bike shaped glass top?
Tim..
PostPosted: 16:16 - 27 Jun 2011    Post subject: Reply with quote
I'll have alook at them, cheers.
I got a quote for the glass at a local place to my work.
Wanted £80 for 6mm and £120 for 10mm Shocked
Fairies attack This post is not being displayed because the poster is banned. Unhide this post / all posts.
The last post was made 15 years, 125 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 141.03 Kb
