Removing Superglue From Plastic Hugger
WannaBeDude
PostPosted: 11:00 - 04 Aug 2011    Post subject: Removing Superglue From Plastic Hugger Reply with quote
Leave mayonaise on for a few hours or any other bright spark method ? Karma
UnknownStuntm...
PostPosted: 11:14 - 04 Aug 2011    Post subject: Reply with quote
Wouldn't have thought that will work. Superglue has super powers (hence the name) and eats into most plastic, making it mushy and allowing it to stick to other plastic.
Best thing to do is let it dry then sand flat and paint.
DrDonnyBrago
PostPosted: 11:34 - 04 Aug 2011    Post subject: Re: Removing Superglue From Plastic Hugger Reply with quote
Acetone will get it off, but it might take some of the paint with it. If you were careful and did a test patch on a non visible bit first it'd probably be ok. Alternative is to sand it off using increasingly fine wet and dry and then T cut the area afterwards to blend it in, this largely depends on the thickness of paint in the area.
Acetone is found in nail varnish remover. Don't buy the eco friendly all natural vitamin enriched nourishing type, get the cheap harsh smelling types that come in a bottle and have a chemical list that either says ACETONE or KETONE.
stirlinggaz
PostPosted: 16:07 - 04 Aug 2011    Post subject: Reply with quote
hi,
i've used this stuff https://www.ebay.co.uk/itm/Superglue-Removal-Super-Glue-Remover-Cleaner-/280635706422?pt=UK_Crafts_Cardmaking_Scrapbooking_Glue_Tape_EH&hash=item4157310c36#ht_1010wt_1139
(or certainly something very similar) to remove the mess that the liquid superglue makes.
i now use the superglue gel, as the liquid is far too thin & it gets everywhere, (including my fingers normally,lol) except for where you want most contact.
used it on a fairing that someone had bodged with cheap superglue & when used gently, it doesnt remove the clearcoat. (done at your own risk though,lol)
cheers,
GAZ
LongJohn22
PostPosted: 21:19 - 04 Aug 2011    Post subject: Reply with quote
Super glue is a fairly ordinary acrylic adhesive, the only super part is the speed at which it sets, it certainly doesn't eat into anything, or make plastic mushy. If it sets on a hard, glossy surface, excess can often be removed with no more than a fingernail. It's generally pretty useless on bike related applications as it is highly susceptible to the effects of damp, and will degrade over time.
Johnser
PostPosted: 21:29 - 04 Aug 2011    Post subject: Reply with quote
superglue isnt normal plastic glue, main components are isocyanates (sp?) curing is sped up by moisture - which is why it loves to stick so much to your fingers/eyes
not much help now but try masking areas with sellotape - wont stick to that. cover fingers with tape to stop gumming them up too
Frost
PostPosted: 21:42 - 04 Aug 2011    Post subject: Reply with quote
You can get glue remove products, but i think that anything that will remove dried on glue will likely also remove dried on paint Laughing
You could always carefully sand it off then polish up the laquer?
WannaBeDude
PostPosted: 21:43 - 04 Aug 2011    Post subject: Reply with quote
Will ' fuck it up ' moro Cool Thumbs Up
WannaBeDude
PostPosted: 10:18 - 06 Aug 2011    Post subject: Reply with quote
It's in the garden caked in mayo, the hugger is painted gloss black, and being replaced in a few months as it cost 20 quid and looks it 2 ! Rolling Eyes
WannaBeDude
PostPosted: 10:26 - 06 Aug 2011    Post subject: Reply with quote
Will find out soon ? Shocked Very Happy
WannaBeDude
PostPosted: 10:45 - 06 Aug 2011    Post subject: Reply with quote
After the kectchup and shampoo, the fridge is fucking empty ! Embarassed
WannaBeDude
PostPosted: 11:21 - 06 Aug 2011    Post subject: Reply with quote
Nevermind my dinner dressings and shower ' stuff ' wtf you doing with gold again, Karma is given, we can't be having you on gold again. Idea Very Happy
WannaBeDude
PostPosted: 14:20 - 06 Aug 2011    Post subject: Reply with quote
That clique are awesome, whether they are after the results of my current carb thread is another thing !! Laughing
WannaBeDude
PostPosted: 14:32 - 06 Aug 2011    Post subject: Reply with quote
I don't know, i don't care, any fuc .. good person who helps me out, is in my deluded clik !! except for Teabag Mike. Cool
Biker Alex
PostPosted: 12:24 - 07 Aug 2011    Post subject: Reply with quote
tried for ages getting L plate gunk off. In the end WD40 & a rag worked.
Possibly degreaser may be more effective.
May not work for the type of glue you have, but for 15 seconds work its worth a try.
PostPosted: 16:08 - 07 Aug 2011    Post subject: Reply with quote
Nail polish remover will soften it, though it'll likely attack the laquer. There used to be a product called Z7 Debonder which was specifically for removing it, I bet that's just re-labeled nail polish remover....
WannaBeDude
PostPosted: 16:12 - 07 Aug 2011    Post subject: Reply with quote
The mayonaise worked about 70 % .. will wd40 the rest Very Happy
The last post was made 15 years, 64 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 93.35 Kb
