Rear Shock - Preload Adjustment - Slight Problem
robbieguy2003
PostPosted: 13:15 - 07 Aug 2011    Post subject: Rear Shock - Preload Adjustment - Slight Problem Reply with quote
Hi All,
I'm trying to adjust the preload on the 600rr. This has followed on from me adjusting the front pre-load (harder) and getting a much better ride with what seems to be better feel from the front.
I'm now trying to do the same for the rear, I think the rear is ok when riding Solo but could do with more when I have a pillion, so i'm trying to find a happy medium.
With this in mind, I set out to the garage with the C Spanner tool from the kit and looked for what i need to adjust. Having found it I cant get it to move at all, it kinda nearly starts to move and then the C Spanner or me give up.
I've attached pictures of the shock and the tool i'm using.
https://www.bikechatforums.com/files/tool_small.jpg
https://www.bikechatforums.com/files/shock_small.jpg
I know it's a bit messy under there so i'm wondering if the adjuster has seized? Do I need to man up and seriously twist this? is it fucked? is the OEM tool shite?
After some ideas really, the front was nice and easy, this bit isn't and the general area is shitted up so wouldn't be surprised if it needs some TLC before I can move on.
Any thoughts from someone familiar with rear shocks would be appreciated.
The reason I'm doing this now is because I'm more plump than when I bought the bike, the handling has been going off over time and most of it seems to be down to the pies!
[/img]
Current Bikes: Honda CBR 600RR - '07, Suzuki GSX1250 FA ST '11
Old Bikes: Suzuki Intruder 125 LC - '2001, Honda CBR 600F - '92, Honda CBR 600RR - '03
andys675
PostPosted: 14:12 - 07 Aug 2011    Post subject: Reply with quote
you need more leverage on the tool, stick a pole on the end of it
(i don't mean east european type)
PostPosted: 15:50 - 07 Aug 2011    Post subject: Reply with quote
They are a pain when near the end of adjustment. Make sure it's flat to the body of the shock and wrap a rag around your hand (or an old glove) easy to not give it enough pull if you're feared of bashing your knuckles.
I've never needed to use an extension on my C-Spanners.
Slightly off topic, but have you measured the sag, as adding more rear preload may require a change to the front to keep the bike balanced.
Acemastr
PostPosted: 15:52 - 07 Aug 2011    Post subject: Reply with quote
Mine adjusts fine on a paddock stand, it's rather tight but it does go.
2016 Toyota Tacoma Limited
BigGeeking
PostPosted: 16:56 - 07 Aug 2011    Post subject: Reply with quote
i have a fight with mine in the end i put wd40 on had a coffee then it was easy just put a rag round to catch the spray off and drips Thumbs Up
Bendy "Flip front. I can filter down the M4 while shoving a Twix in my face."
honda CG 125 2001 SOLD-- current Bandit 400--SOLD. current SV650s 2000
MOD 1 ON 20/7/2011**passed** MOD 2 ON 17/10/2011***passed***,,
robbieguy2003
PostPosted: 19:32 - 07 Aug 2011    Post subject: Reply with quote
Cheers for the tips. I popped upto the Honda Shop (Gedges) in Ore. The guys there done 3 clicks and 1.5 turns harder as they couldnt get it to go either. Apparantly that'd compensate a bit which it seems to have done.
They said either pop back and leave it with them or WD40 it and keep playing and it'll go.
I'd went through quite a few suspension guides before deciding to piss around with it. I think either Big Ham or Marjay posted a zip file recently with a guide. I followed that, plus a magazine guide, plus some others online.
I spent ages with a measuring tape and got all the original settings first. I've got a ~45 mile test run that I do with each change, it's got a nice mix of 30mph all the way upto 70mph dual carriageway with lots of NSL lanes in the middle. So far the changes have been good but i'm doing one at a time then will go back if it feels odd or try and understand whats going on.
PostPosted: 21:15 - 07 Aug 2011    Post subject: Reply with quote
I also have to run my bikes in a compromised state. Sad
I'm still kicking myself for not setting the duc properly. I'd set the rebound and compression to spec but hadn't set the sag. Bike handled ok if a little reluctant to tip in(hindsight eh).
All set now and i've lessened the compression. The bike is different. It drops into corners and stays there. Front follows the roads surface better.
I've got 1 setting for 2up riding.I'll have to get a setting for solo on these bumpy roads i use.
I've been practising bouncing the bike whilst stood beside it. Hand on the headstock hand on the seat (above top mount). I can see how fast the suspension pops back up and how quick or slow it takes to compress..Get the front and rear to mirror each other..The rest is Black Magic.
Fizzer Thou
PostPosted: 22:13 - 07 Aug 2011    Post subject: Reply with quote
That standard tool is so useless it is not worth using.I would recommend a full service of the rear of the bike as it could otherwise hide all sorts of problems which will only get worse and then let you down big time and expensively.
Always have a 'Plan B'
robbieguy2003
PostPosted: 22:35 - 07 Aug 2011    Post subject: Reply with quote
Yeah i know what you mean. I've had this bike from new, got it setup once but crucially I think my weight and riding style have both changed since I got it. Changing the settings so far have brought it forward a hell of a lot. I'd expect anything else to be minor now. I'll check the balance on front and rear though, thats a decent tip! Mostly i've been going off how it feels. As long as it felt better and didnt do anything dangerous I've been happy.
I'm tempted to get a better tool. I don't think it's just the tool but it's by no means the best made tool.
I spent a lot of time on the front end this year. I done the brake calipers myself (new pads, seals, pins, steel lines) and a PROPER cleanup. I also had the forks rebuild with new stantions because of some pitting. Turns out upside down forks didnt like 3 years of living on the seafront!
I'm putting ~£1-1.5K aside to sort out the bike over this winter. I'm thinking of getting the shock rebuilt as part of this as well as doing a full stripdown and clean. That's the plan anyway, as long as nothing bites me i'll get it done.
The last post was made 15 years, 53 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 66.38 Kb
