| robbieguy2003 |
 robbieguy2003 World Chat Champion
 Posted: 13:15 - 07 Aug 2011 Post subject: Rear Shock - Preload Adjustment - Slight Problem |
Hi All,
I'm trying to adjust the preload on the 600rr. This has followed on from me adjusting the front pre-load (harder) and getting a much better ride with what seems to be better feel from the front.
I'm now trying to do the same for the rear, I think the rear is ok when riding Solo but could do with more when I have a pillion, so i'm trying to find a happy medium.
With this in mind, I set out to the garage with the C Spanner tool from the kit and looked for what i need to adjust. Having found it I cant get it to move at all, it kinda nearly starts to move and then the C Spanner or me give up.
I've attached pictures of the shock and the tool i'm using.
https://www.bikechatforums.com/files/tool_small.jpg
https://www.bikechatforums.com/files/shock_small.jpg
I know it's a bit messy under there so i'm wondering if the adjuster has seized? Do I need to man up and seriously twist this? is it fucked? is the OEM tool shite?
After some ideas really, the front was nice and easy, this bit isn't and the general area is shitted up so wouldn't be surprised if it needs some TLC before I can move on.
Any thoughts from someone familiar with rear shocks would be appreciated.
The reason I'm doing this now is because I'm more plump than when I bought the bike, the handling has been going off over time and most of it seems to be down to the pies!
[/img] ____________________ Current Bikes: Honda CBR 600RR - '07, Suzuki GSX1250 FA ST '11
Old Bikes: Suzuki Intruder 125 LC - '2001, Honda CBR 600F - '92, Honda CBR 600RR - '03 |
| andys675 |
 andys675 World Chat Champion
| Howling TerrorOutOfOffice |
 Howling TerrorOutOfOffice Super Spammer
 Posted: 15:50 - 07 Aug 2011 Post subject: |
They are a pain when near the end of adjustment. Make sure it's flat to the body of the shock and wrap a rag around your hand (or an old glove) easy to not give it enough pull if you're feared of bashing your knuckles.
I've never needed to use an extension on my C-Spanners.
Slightly off topic, but have you measured the sag, as adding more rear preload may require a change to the front to keep the bike balanced. ____________________ Diabolical homemade music Bandcamp and Soundcloud
The Harry Turner Project |
| Acemastr |
 Acemastr World Chat Champion
| BigGeeking |
 BigGeeking Scooby Slapper
 Posted: 16:56 - 07 Aug 2011 Post subject: |
i have a fight with mine in the end i put wd40 on had a coffee then it was easy just put a rag round to catch the spray off and drips  ____________________ Bendy "Flip front. I can filter down the M4 while shoving a Twix in my face."
honda CG 125 2001 SOLD-- current Bandit 400--SOLD. current SV650s 2000
MOD 1 ON 20/7/2011**passed** MOD 2 ON 17/10/2011***passed***,, |
| robbieguy2003 |
 Posted: 21:15 - 07 Aug 2011 Post subject: |
I also have to run my bikes in a compromised state.
I'm still kicking myself for not setting the duc properly. I'd set the rebound and compression to spec but hadn't set the sag. Bike handled ok if a little reluctant to tip in(hindsight eh).
All set now and i've lessened the compression. The bike is different. It drops into corners and stays there. Front follows the roads surface better.
I've got 1 setting for 2up riding.I'll have to get a setting for solo on these bumpy roads i use.
I've been practising bouncing the bike whilst stood beside it. Hand on the headstock hand on the seat (above top mount). I can see how fast the suspension pops back up and how quick or slow it takes to compress..Get the front and rear to mirror each other..The rest is Black Magic. ____________________ Diabolical homemade music Bandcamp and Soundcloud
| Fizzer Thou |
| robbieguy2003 |
The last post was made 15 years, 51 days ago. Instead of replying here, would creating a new thread be more useful? |
