Restricting a CBR 600F(Fi)
speedysi
PostPosted: 14:49 - 07 Aug 2011    Post subject: Restricting a CBR 600F(Fi) Reply with quote
Can anybody tell me what kind if costs are involved in restricting a Fi CBR 600F?
Thanks
pits
PostPosted: 16:01 - 07 Aug 2011    Post subject: Reply with quote
Problem is getting the power level over 9,000
PostPosted: 16:07 - 07 Aug 2011    Post subject: Reply with quote
Couple of hundred pounds for an FI International kit. A few pence if you know the measurements of the inlet washers you need.
spanners
PostPosted: 17:53 - 07 Aug 2011    Post subject: Reply with quote
The dimensions for the washers are in this thread, the bike is the same model but a few years older i think.
https://www.bikechatforums.com/viewtopic.php?t=146442
"Insert profound quote here"
Benson_JV
PostPosted: 21:21 - 07 Aug 2011    Post subject: Re: Restricting a CBR 600F(Fi) Reply with quote
speedysi wrote:
Fi CBR 600F?
Am I missing something?
Thinking
PostPosted: 21:29 - 07 Aug 2011    Post subject: Re: Restricting a CBR 600F(Fi) Reply with quote
Benson_JV wrote:
speedysi wrote:
Fi CBR 600F?
Thinking
Inlet washers still work on FI bikes.
My Mille had them.
Benson_JV
PostPosted: 22:05 - 07 Aug 2011    Post subject: Reply with quote
But how? I thought inlet washers = carbs? Confused
I'm genuinely intruiged!
serlant
PostPosted: 22:58 - 07 Aug 2011    Post subject: Reply with quote
Why? engine needs fuel/air to burn to produce power, if you cannot get as much fuel/air into the cylinder you get less power, hence restricting washers, they restrict the air and consequently fuel flow, wether its through a carb or a throttle body its still less fuel/air to burn to less power.
04 CBR1000RR, 1995 Husqvarna TE410, 1998 VTR1000(Sold), 1990 XJ600(sold), 1996 KH125(dead and sold)
Benson_JV
PostPosted: 23:24 - 07 Aug 2011    Post subject: Reply with quote
I thought they mixed air/fuel via another way, I guess I don't really know, some alien way! I know how the restrictors worked, I just thought as above.
HD
PostPosted: 23:30 - 07 Aug 2011    Post subject: Reply with quote
I'm with Benson here, its confusing haha.
How does FI actually work? Surely if you restrict the air the same amount of fuel goes through? I know google is my friend but how does the fuel get from the tank into the combustion chamber(s)?
I saw some restrictors for an sv on ebay the other day and it had washers and a throttle stop...
HD
PostPosted: 11:54 - 08 Aug 2011    Post subject: Reply with quote
I thought it just injected fuel. Learn something new everyday!
Benson_JV
PostPosted: 13:25 - 08 Aug 2011    Post subject: Reply with quote
I thought you couldn't restrict FI like that, indeed you do learn something new everyday Thumbs Up
PostPosted: 13:34 - 08 Aug 2011    Post subject: Reply with quote
See I used the right hand restriction on my 2 year period... Laughing
DrDonnyBrago
PostPosted: 13:51 - 08 Aug 2011    Post subject: Reply with quote
I suspect that inlet washers on an FI bike without a throttle stop would work poorly as the amount of fuel and air is controlled separately in an FI bike. If it was just inlet washers then the air would be limited but fuel is controlled by the ECU based on a few things (i.e. the throttle position sensor) so would be pumped in at a normal rate = uber rich and probably not running.
A throttle stop and inlet washers is how it is achieved in overpriced kits for this bike although I do recall a thread somewhere where someone was trying to remove an ECU restriction, I think this was a factory 33bhp restriction rather than aftermarket though.
This thread:
https://www.bikechatforums.com/viewtopic.php?t=177613
The last post was made 15 years, 3 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.66 - MySQL Queries: 13 - Page Size: 86.87 Kb
