valve clearance advice
salty21
PostPosted: 20:22 - 09 Aug 2011    Post subject: valve clearance advice Reply with quote
just a quick one. Am currently doing the valve clearences on the sp-1 but cant get the timing hole cover or crankshaft covers off. I've got the plugs out so can easily turn the engine over using the back wheel. So what i want to know is, because i cant get the timing cover off, can i just measure the clearances with the cam lobes pointing up to put the valves in the closed position, or do they need to be in an exact position?
MickC
PostPosted: 21:15 - 09 Aug 2011    Post subject: Reply with quote
On my 81 Honda, so long as the lobes are pointing away you can measure the clearance so i would think it will be the same for you.
Hope thats of some use
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
whitedevil
PostPosted: 22:24 - 09 Aug 2011    Post subject: Reply with quote
As said make sure the lobes are facing away, also you can rest something on the top of the piston so when you rotate the crank you can see when each piston is at tdc on each stroke
GPZ500 sold ~ CBR600FS-2 sold ~ ZX6R sold ~ Street Triple R
Dr. Quack This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
yen_powell
PostPosted: 22:53 - 09 Aug 2011    Post subject: Reply with quote
Are they the round covers with the allen key slot that rounds out when you try and undo it?
If they are you can remove them using a punch and a hammer. It sounds more brutal than it actually is, you don't have to smash away with the hammer, just on the oustide edge of the cover in an anti clockwise direction so it undoes.
XT1200Z and a DR350 in bits
salty21
PostPosted: 23:04 - 09 Aug 2011    Post subject: Reply with quote
yeah, both of the covers are allen key types, i've not rounded either off yet but they feel like they would if i put more force onto them, i mighnt pop into halfords tomorrow and pick up some proper allen sockets rather than the 'L' type ones im using before i use the hammer Laughing . I need to change 1 exhaust shim on each cylinder so the cam's are gonna have to come out so would rather have the timing cover off to be sure it's all in the right place when it comes to rebuilding.
Cheers for the help guys Thumbs Up
yen_powell
PostPosted: 23:52 - 09 Aug 2011    Post subject: Reply with quote
Tippex is your friend if you are removing and refitting camshafts. Mark the camchain and sprockets to aid refitting with the correct timing.
BigGeeking
PostPosted: 09:17 - 10 Aug 2011    Post subject: Reply with quote
like your thinking Thumbs Up i'll remember that one Karma
Bendy "Flip front. I can filter down the M4 while shoving a Twix in my face."
honda CG 125 2001 SOLD-- current Bandit 400--SOLD. current SV650s 2000
MOD 1 ON 20/7/2011**passed** MOD 2 ON 17/10/2011***passed***,,
salty21
PostPosted: 16:58 - 10 Aug 2011    Post subject: Reply with quote
camchain? Laughing
real men dont have camchains.
just about finished now, just treated the cylinders as two seperate engines, lined the marks up on the rear cylinders cam sprockets to be flush with the casing, facing away from each other, then stripped that and replaced the shim. Put it all back together and moved onto the front cylinder doing the same thing.
This bike is amazingly easy to work on for a sports bike, everything seems to be put together really thoughtfully which makes working on it really enjoyable, HRC and honda need to make more bikes like this, CBR800 maybe, that would be mega.
The last post was made 15 years, 32 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 65.86 Kb
