| salty21 |
 salty21 World Chat Champion
 Posted: 20:22 - 09 Aug 2011 Post subject: valve clearance advice |
just a quick one. Am currently doing the valve clearences on the sp-1 but cant get the timing hole cover or crankshaft covers off. I've got the plugs out so can easily turn the engine over using the back wheel. So what i want to know is, because i cant get the timing cover off, can i just measure the clearances with the cam lobes pointing up to put the valves in the closed position, or do they need to be in an exact position? ____________________ 04 NSR 125(sold) ---- 03 CBR 600rr(sold) ----90 pan euro ST1100 ' ' ----02 CG 125
94 CB400 Super Four ---- 2000 VTR SP1 (sold) ---- 08 ninja p8f(sold, meh) ----05 CBR600rr  |
| MickC |
 MickC Spanner Monkey
 Posted: 21:15 - 09 Aug 2011 Post subject: |
On my 81 Honda, so long as the lobes are pointing away you can measure the clearance so i would think it will be the same for you.
Hope thats of some use ____________________ XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1 |
| whitedevil |
 whitedevil World Chat Champion
| Dr. Quack |
 Dr. Quack Could Be A Chat Bot
| yen_powell |
 yen_powell World Chat Champion
| salty21 |
 Posted: 23:04 - 09 Aug 2011 Post subject: |
| yen_powell |
| BigGeeking |
 BigGeeking Scooby Slapper
| salty21 |
 Posted: 16:58 - 10 Aug 2011 Post subject: |
| yen_powell wrote: | | salty21 wrote: |
yeah, both of the covers are allen key types, i've not rounded either off yet but they feel like they would if i put more force onto them, i mighnt pop into halfords tomorrow and pick up some proper allen sockets rather than the 'L' type ones im using before i use the hammer  . I need to change 1 exhaust shim on each cylinder so the cam's are gonna have to come out so would rather have the timing cover off to be sure it's all in the right place when it comes to rebuilding.
Cheers for the help guys  | Tippex is your friend if you are removing and refitting camshafts. Mark the camchain and sprockets to aid refitting with the correct timing. |
camchain?
real men dont have camchains.
just about finished now, just treated the cylinders as two seperate engines, lined the marks up on the rear cylinders cam sprockets to be flush with the casing, facing away from each other, then stripped that and replaced the shim. Put it all back together and moved onto the front cylinder doing the same thing.
This bike is amazingly easy to work on for a sports bike, everything seems to be put together really thoughtfully which makes working on it really enjoyable, HRC and honda need to make more bikes like this, CBR800 maybe, that would be mega. ____________________ 04 NSR 125(sold) ---- 03 CBR 600rr(sold) ----90 pan euro ST1100 ' ' ----02 CG 125
The last post was made 15 years, 33 days ago. Instead of replying here, would creating a new thread be more useful? |
