few probles
wardy941
PostPosted: 18:53 - 10 Aug 2011    Post subject: few probles Reply with quote
my ts 50 has been playing up a lot
it now pushes forward in gear
you can push the bike forward without the clutch pulled in and it just rolls easily - the engine does turn over when pushing - is this because of the piston and rings
also i have snapped a stud, the 4 long studs from the bottom end which the barrel and head go on - 1 has snapped, how can i get it out it was really tight is there a tool i can use
thanks
wardy941
PostPosted: 20:36 - 10 Aug 2011    Post subject: Reply with quote
what?
wardy941
PostPosted: 20:37 - 10 Aug 2011    Post subject: Reply with quote
what?
st3v3
PostPosted: 00:16 - 11 Aug 2011    Post subject: Re: few probles Reply with quote
thanks
You sounds like a young lad that doens't know ANYTHING about bikes, tbh I don't trust giving you advice to fix it yourself, go see a garage.
Frost
PostPosted: 01:04 - 11 Aug 2011    Post subject: Reply with quote
Get 2 nuts and put them on the stud. Undo the bottom one and do up the top one biting the two onto each other really hard. You can then use the bottom one to undo the stud.
If in gear the engine should turn over when pushed.
Drake
PostPosted: 07:53 - 11 Aug 2011    Post subject: Reply with quote
ready for the " it fired up and ran off thread" after pushing it in gear
Carlosaurus
PostPosted: 11:02 - 11 Aug 2011    Post subject: Reply with quote
Think he means it rolls quite easily in gear, as if theres no resistance or compression at all.
In which case, don't look at it yourself mate. You don't sound qualified to use a keyboard let alone touch the engine Thumbs Up
2008 TMEC 125CC SM.
st3v3
PostPosted: 11:13 - 11 Aug 2011    Post subject: Reply with quote
The fact it can be pushyed in gear and not 'stop' is worrying. I'd guess something simple like the insides of the engine being damaged. Get it to a garage.
@ Frost, you mean in a bump-start fashion yeah?
PostPosted: 11:14 - 11 Aug 2011    Post subject: Reply with quote
Wardy mate there are a lot of people here can help you but you but it sounds like you're really struggling with basic mechainical principles.
Firstly - the broken cylinder stud. Put up a photo of it. DON'T try to turn it with pliers or mole grips or anything else.
The problem of being able to push the bike forward in gear is probably linked to the broken stud. With the stud broken you're probably losing compression from your cylinder head.
Where are you? It might be there's someone nearby who can take pity on you and pop round for a look but you don't list your location in your profile.
wardy941
PostPosted: 12:14 - 11 Aug 2011    Post subject: Reply with quote
the stud has completly snapped right at the bottom so there is no were to wind a nut on or even grab with pliers
and when i say it pushes and turns over i mean it easily pushes no resistance at all as if the head wasnt on
st3v3
PostPosted: 12:22 - 11 Aug 2011    Post subject: Reply with quote
Question
Frost
PostPosted: 13:22 - 11 Aug 2011    Post subject: Reply with quote
So when you say it's snapped off flush, is that flush with the head or the crank case? Basically how much came off it when it snapped? In inch or so, or 6 inches or so?
PostPosted: 13:39 - 11 Aug 2011    Post subject: Reply with quote
It'll be at the cases. Sod's law always applies in these events.
Frost
PostPosted: 14:00 - 11 Aug 2011    Post subject: Reply with quote
Well he's saying it pushes like the head isn't on, which makes me think he's baffled because the head is on, in which case the barrel is too, so the stud might be snapped flush with that.
I'd be tempted to buy an engine off ebay rather than pay a mechanic to sort it all out at the bloody rates they charge!
0ddball
PostPosted: 14:39 - 11 Aug 2011    Post subject: Reply with quote
Considering he was having trouble with the clutch
https://www.bikechatforums.com/viewtopic.php?t=225966
it sounds possible, despite what he says, that even though the clutch lever is out the clutch might not be engaging.
You obviously don't know much about engines. Post some pics so people can help.
ZXR750L
st3v3
PostPosted: 01:42 - 12 Aug 2011    Post subject: Reply with quote
He clearly has no mechanical knowledge tho. Neutral
The last post was made 15 years, 79 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.03 - MySQL Queries: 13 - Page Size: 100.19 Kb
