| Biker_Dene |
 Biker_Dene Crazy Courier
| mr jamez |
 mr jamez World Chat Champion
| Biker_Dene |
| Retro-Man |
 Retro-Man Traffic Copper
 Posted: 21:37 - 31 Aug 2004 Post subject: |
exactly whatmethod did you use to bleed brakes
I would echo above post, could be damaged res/cyl
did fluid squirt out or trickle ____________________ https://domharnessphotography.webs.com |
| Retro-Man |
| Biker_Dene |
| Biker_Dene |
| Retro-Man |
 Posted: 21:43 - 31 Aug 2004 Post subject: |
correct bleeding kit will cost a fiver from any motorist shop and consists of a piece of rubber tube leadin into a bottle
1. attach tool to bleed nipple
2. fill res to max
3. open niplle an squease brake lever fully in slowly several times
4. keep eye on res level and watch air bubble in tube
5. whe air stops squezze and hold brake lever and close nipple
now you should have a good brake  ____________________ https://domharnessphotography.webs.com |
| Kickstart |
 Kickstart The Oracle
| swampy |
 swampy World Chat Champion
 Posted: 23:40 - 31 Aug 2004 Post subject: |
I just had to bleed the brakes on my NSR and it took ages to get the air out ( i did swap hoses though). I used a one man bleeding kit with a one way valve on it. i've used this in the past on all sorts of vehicles and its pretty fool proof to operate, to echo everyone else, just remember to keep the reservoir topped up or you will undo all the work in a second. Hope this helps  ____________________ "I hate to advocate drugs, alcohol, violence or insanity to anyone, but they've always worked for me." Hunter S Thompson
"Faster, faster, faster, until the thrill of speed overcomes the fear of death..." Hunter S Thompson |
The last post was made 22 years, 41 days ago. Instead of replying here, would creating a new thread be more useful? |
