brake probs on my mito!
Biker_Dene
PostPosted: 21:20 - 31 Aug 2004    Post subject: brake probs on my mito! Reply with quote
ok
on my mito evo 2
after my crash i got the bike home and i realised that the brake lever had 2 be pressed in all the way for the brake to do anything and even then it wasn't very good
so today i bled the brake and now it does do anything
all my cables and wires are there and fine no holes or anything the brake fluid botels bracket is snapped but the bottel is fine and is full!
anyone got any ideas why my brake isn't working ?
"RIDE LIKE A KNOB AND YOU'LL DIE"
K9 Suzuki Hayabusa
mr jamez
PostPosted: 21:33 - 31 Aug 2004    Post subject: Reply with quote
Perhaps the brake resevoir is knackerd or blocked. If the system is bled and has the correct amount of fluid then there must be nothing getting to the caliper. When you bled the brakes did the fluid squirt out or just weep out of the top of the bleeder bolt?
Biker_Dene
PostPosted: 21:35 - 31 Aug 2004    Post subject: Reply with quote
well i didnt have the tool for bleeding the brakes so i undud the bold and the liquid just weped out for a few seconds then stoped but the bottle is still full
K9 Suzuki Hayabusa
Retro-Man
PostPosted: 21:37 - 31 Aug 2004    Post subject: Reply with quote
exactly whatmethod did you use to bleed brakes Question
I would echo above post, could be damaged res/cyl
did fluid squirt out or trickle
https://domharnessphotography.webs.com
Retro-Man
PostPosted: 21:39 - 31 Aug 2004    Post subject: Reply with quote
in that case you have let more air in than out
Biker_Dene
well the mito has brembo brakes and there is a little thing that i just undid on the caliper and b-4 i got it all the way out the liquid started squirting everywhere and then stoped after a few seconds then i put the little nut thing back in and the brake still not working
the front brake was working fine b-4 my crash
K9 Suzuki Hayabusa
Biker_Dene
PostPosted: 21:40 - 31 Aug 2004    Post subject: Reply with quote
so what do i do then to let some air out ?
K9 Suzuki Hayabusa
Retro-Man
PostPosted: 21:43 - 31 Aug 2004    Post subject: Reply with quote
correct bleeding kit will cost a fiver from any motorist shop and consists of a piece of rubber tube leadin into a bottle
1. attach tool to bleed nipple
2. fill res to max
3. open niplle an squease brake lever fully in slowly several times
4. keep eye on res level and watch air bubble in tube
5. whe air stops squezze and hold brake lever and close nipple
now you should have a good brake Thumbs Up
PostPosted: 22:13 - 31 Aug 2004    Post subject: Reply with quote
Do as above, but what you have already done will have let loads of air into the system and it will probably take quite a while to get them bled through again.
swampy
PostPosted: 23:40 - 31 Aug 2004    Post subject: Reply with quote
I just had to bleed the brakes on my NSR and it took ages to get the air out ( i did swap hoses though). I used a one man bleeding kit with a one way valve on it. i've used this in the past on all sorts of vehicles and its pretty fool proof to operate, to echo everyone else, just remember to keep the reservoir topped up or you will undo all the work in a second. Hope this helps Thumbs Up
The last post was made 22 years, 41 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.6 - MySQL Queries: 13 - Page Size: 64.35 Kb
