SV650 S 2008
msmallc
PostPosted: 18:27 - 24 Aug 2011    Post subject: SV650 S 2008 Reply with quote
Hi there my battery keeps going flat on my sv650...I have charged the battery and put a meter on it and it reads 12.8v but when the bikes running the meter reads 11.8v does anyone know what the problem might be?
Villers
PostPosted: 20:10 - 24 Aug 2011    Post subject: Reply with quote
Any good with a meter? Try this...
msmallc
PostPosted: 20:23 - 24 Aug 2011    Post subject: Sv650 s Reply with quote
Thanks for the info lads.....also forgot to say when I rev'ed up the bike the voltage didn't move up at all stayed around 11volts....
Villers
PostPosted: 20:35 - 24 Aug 2011    Post subject: Reply with quote
So its likely to be either the reg/rec or the alternator. That pdf should hep you a fair bit and if its something more bizarre like a bad connection it will help you also.
Good luck! Laughing
msmallc
PostPosted: 20:49 - 24 Aug 2011    Post subject: SV650s Reply with quote
Ok nice one....don't suppose you know where the reg/rec is on the SV do ya......
Villers
PostPosted: 20:55 - 24 Aug 2011    Post subject: Reply with quote
To be honest mate I don't know. Going from experience its normally located somewhere in the tail unit, perhaps on the left hand side bolted to the frame.
Check SV650.org for expert advice on that one bud!
stonesie
PostPosted: 22:45 - 24 Aug 2011    Post subject: Reply with quote
Mine is on the right hand side of the bike at the front of the frame, above the front cylinder and behind the radiator.
Using a 1/4" drive ratchet and 10mm socket you can reach through the frame and unbolt it without lifting the tank Thumbs Up
The last post was made 15 years, 41 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.33 - MySQL Queries: 13 - Page Size: 54.09 Kb
