Private Number Plates and Age of bike *UPDATE*
rizo-sri200
PostPosted: 23:20 - 04 Sep 2004    Post subject: Private Number Plates and Age of bike [HELP!] *UPDATE* Reply with quote
Right my bike is on a G plate but was only imported in september 2002 from japan and im wondering if i can put an R plate on it as it is a 1996/7 plate but your not allowed to make the bike look newer
bike first registered in 2002 so does that mean i could put it on??
Just that my parents are thinking about getting me a personal plate for my b-day
Thanks
swift kick to the wing mirror puts em straight..
98' Bandit 600 with Slip on
MarsBar
PostPosted: 23:23 - 04 Sep 2004    Post subject: Reply with quote
Not sure but think this isn't allowed as the bike was initially registered as a 1989 (G reg) bike, regardless of which country it was built.
Best ask the DVLA.
rizo-sri200
PostPosted: 23:24 - 04 Sep 2004    Post subject: Reply with quote
anyways im gonna give them a ring tomorrow (if their open) and see what they say?
PostPosted: 23:52 - 04 Sep 2004    Post subject: Reply with quote
No. You cannot try to make your car appear newer than it is by changing the plates.
rizo-sri200
PostPosted: 23:54 - 04 Sep 2004    Post subject: Reply with quote
who said anything about a "car"??
I didnt.....
C'mon ste pull ya finger out Mr. Green Thumbs Up
hustler
PostPosted: 10:14 - 05 Sep 2004    Post subject: Reply with quote
Ste's right on this one, can't make it look newer than it is. Thumbs Up
As I said to that guy with the crutches and full camouflage gear, you can hide but you can't run.
Claud 14.7 to 1
PostPosted: 10:17 - 05 Sep 2004    Post subject: Reply with quote
Car or bike doesn't matter. Same rules.
rizo-sri200
PostPosted: 11:09 - 05 Sep 2004    Post subject: Reply with quote
...but on my V5 is says date of first registraitiom september 2002 so it would make it look older.. Question
carvell
Scuttler
PostPosted: 11:32 - 05 Sep 2004    Post subject: Reply with quote
That makes no difference - it's the year the vehicle was built that matters - obviously.
Yamaha TDM 850
Retro-Man
PostPosted: 11:39 - 05 Sep 2004    Post subject: Reply with quote
If you are buying a private plate then yes you can put any number, letter configuration you like on it ...as long as you have the plate registered with dvla and that combination is available.. you will receive a certificate of entitlement from dvla,, this type of plate transfer is commonly referred to as a cherished plate...
I deal with these all the time working in a landrover dealership and a lot of people do it to make their vehicle appear ageless.
do a google search on cherished plate or private plates there are tons of companys willing to sell/do the paperwork for you.
depending on the plate you can pay as little as £150 Thumbs Up
https://domharnessphotography.webs.com
PostPosted: 12:05 - 05 Sep 2004    Post subject: Reply with quote
But all plates since the mid 60s are age related, and it is these that are sold by the DVLA as cherished plates. You cannot put a plate on a vehicle that refers to a newer year. Most cherished plates are quite old though, and this is not a problem for new vehicles.
Retro-Man
PostPosted: 12:27 - 05 Sep 2004    Post subject: Reply with quote
partially right you can not put a standard plate for example "R506TYH"
simply because dvla register all possibilities of these plates before plate issue commencement however if available you can have "R6YAM" or "PIA50"
one of our rangerover customers has a plate consisting of "57TM"
all of these plates will either make the vehicle apparently ageless or in the case of R6yam make the vehicle at first glance appear to be an R plate vehicle
there is no restriction on configuration as long as that plate is not already assigned a vehicle, however as you point out dvla do pre-assign plates automatically.
Plates are assigned regionally in fact as a dealer using the new plate format on registering a new vehicle for the first time the first two letters are assigned by area designation the numbers are assigned in order of registration and as long as they have not already been assigned we can request any order of the last letters
Retro-Man
PostPosted: 12:28 - 05 Sep 2004    Post subject: Reply with quote
in fact on the rare occasion a vehicle is written off the plate will become available again after xx number of years left dormant meaning that you could have a cherished plate "R506YAH" Thumbs Up
PostPosted: 13:13 - 05 Sep 2004    Post subject: Reply with quote
You can do anything you want, but if the bike has the plate L123 ABC you can't put anything newer than an L plate on it.
hustler
PostPosted: 13:33 - 05 Sep 2004    Post subject: Reply with quote
The rule is simple if changing the plate makes it younger than you can't do it. The idea is so that it protects the rest of us from buying some we think is a 1999(T) and it turns out to be a 1988 (E).
So if your plate was "L123 ABC", you couldnt put "M1 CBR" because it would look newer. You could put "CBR 600" though as that is ageless (probably cost a fortune too).
Retro-Man
PostPosted: 16:33 - 05 Sep 2004    Post subject: Reply with quote
https://www.dvlni.gov.uk/formsfolder/v317info.pdf
page 2
rule on ageless plates just to clear this up once and for all
this rule only affects age identifier plates non age indentifier plates can be used in any configuration as in "R6YAM" Thumbs Up
M1CBR is possible because it is a non age identified plate Thumbs Up
PostPosted: 17:17 - 05 Sep 2004    Post subject: Reply with quote
I thought that stuff like "R6YAM" was just a normal R reg plate, and thus you are free to put it on a vehicle that would be R reg or newer. When they changed the order of the plates in 1983 they stopped issuing numbers below 20 regularly, but then started selling these later on. Thought all the ones that they sell are ones that were allocated for use (such as those below 20) but never issued.
PIA50 is just an old Northern Ireland plate, an Antrim one to be precise from about 20 years ago.
Adam_P
PostPosted: 18:00 - 05 Sep 2004    Post subject: Reply with quote
Not the way I see it. The R6YAM plate is an R plate, plain and simple, which means it can't go on a vehicle that it would make newer, eg: a car that was initially registered as a 'P' plate. EG: P1ABC. Becuase that is not an 'ageless' plate, it refers to an R reg, it has a specific year of introduction.
I always thought that if it was a general type of plate. As in has the letter then the number before the area letters (three usually) then its a dated plate. Plates with different number and letter configurations are ageless. As in the 57TM plate the guy with the new range rover has etc.
I've seen a Merc with 7D on it and also seen one with AP1 (Which I would really really like!) They're what I would call ageless plates. R6YAM I wouldn't.
Or am I missing something?
Colin McRae MBE 1968 - 2007 RIP Sad
Orwell Rolls in his Grave
God is imaginary
Retro-Man
PostPosted: 18:03 - 05 Sep 2004    Post subject: Reply with quote
Embarassed
I stand corrected
Embarassed
Mnementh
PostPosted: 23:01 - 05 Sep 2004    Post subject: Reply with quote
IIRC it actually goes on the date the vehicle was first registered here, ie a car/bike could have been built in say 1994 but sat in the manufacturers lot for 4 years or so (I used to work for Landrover and they have hundreds of vehicles sitting around waiting for parts), then if say for instance the vehicle has been updated a dealer can sell the 1994 car at a discount because it's the old model but it will STILL have a new registration plate because they go on when the vehicle was registered with the DVLA. So in this case the 1994 vehicle could have a 1998 plate even though it is the older model because of when it was registered.
Hope that makes sense. I don't know whether this would apply to a vehicle already registered in another country, and then re-registered over here, but it certainly applies to vehicles here.
NSR125-Kid-UK
Attention Whore
PostPosted: 10:47 - 06 Sep 2004    Post subject: Reply with quote
Kickstart wrote:
I thought that stuff like "R6YAM" was just a normal R reg plate.
R6 6YAM Is spoken for Very Happy
https://www.bikepics.com/members/nsrandy/96rs250/ My Bike!
"I'm either going to teach andy to get his knee down, or I'm going to get him killed. One of the two" - Teaman
bladerrx
PostPosted: 21:02 - 06 Sep 2004    Post subject: Reply with quote
just to put a fly in the ointment
you cannot change the registration of a PRE REGISTERED vehicle to that of a newer year.................but if like the man said it was first registered in 2002 then he can have any plate older than that,
the year of manufacture is nothing at all to do with the year of registration which is why it is a REGISTRATION plate.
just as an example of this i have a 2000 (x) plated bike which is a 1998 model
and also you can buy a brand new 03 model r1 and register it in 5 years time making it a 2008 new r1, only the model would give away the fact
sorry to go on but there is a bike shop in batley (padgetts) who had a brand new unregistered suzuki gt380 so if you bought this it would become a 04 plated bike
sorry
chris
see the world .......................... buy a television
or visit www.denholmecrew.com
hugo-a-gogo
PostPosted: 00:36 - 07 Sep 2004    Post subject: Reply with quote
yep, true. it's date of registration that counts, not date of manufacture.
you can't put a plate with a 'year letter' or number on a vehicle registered before that plate
it's a good scam that the government have going though, in conjunction with the car dealers. most other countries don't have age identifiers on the plate, and I don't know of any others that charge so much for choosing your own number
(i paid 20euro to pick a number - i only needed the 'D' for Düsseldorf at the beginning, then one or two letters and between 1 and 4 numbers)
"There are some things nobody needs in this world, and a bright-red, hunch-back, warp-speed 900cc cafe racer is one of them - but I want one anyway, and on some days I actually believe I need one. That is why they are dangerous."
Hunter S Thompson
clicky 4 bikey
rizo-sri200
PostPosted: 19:33 - 07 Sep 2004    Post subject: Reply with quote
i rang the DVLA...
and they said i cant becuase of the year of manufacter (WTF is it a called a registration Plate) Question Rolling Eyes
Can have any from Before G. Why would i when i want R15 JCR!!!
Argh!
Brookleigh
PostPosted: 12:22 - 05 Oct 2004    Post subject: Number plates - What a topic, What a minefield!! Reply with quote
I have been reading most peoples replies to the this subject, and have joined the forum to try to help out people and give some advise.
I have been making number plates, and answering peoples problems for 8 years now, I don't know all the answers, but then neither do DVLA!!! - and thats no joke.
Here are some helpful links to get the ball rolling.
https://www.dvla.gov.uk/vehicles/regmarks/reg_marks_current_requirements.htm
DVLA's Link on Number plates
Our Q & A Page https://www.craigsplates.com/QA.htm
And my email if you have any other questions we can help with [email protected]
We are designing at the moment a site just dedicated for bike plates, but at present just take a look at https://www.craigsplates.com
The last post was made 22 years, 47 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.09 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 134.5 Kb
