Making a manometer to balance carbs
alan0259
PostPosted: 19:40 - 27 Sep 2011    Post subject: Making a manometer to balance carbs Reply with quote
I've seen different methods, some people use two bottles and link them together, some people take four bottles, and link all four together, and some people just take 2 or 4 bottles and just link them directly to the carbs.
What are the pro's and con's?
This looks the easiest method...
https://uploads.turbosport.co.uk/getrempic3.php?url=https://homepage.ntlworld.com/frank.cooper1/images/balancer.jpg
PostPosted: 19:43 - 27 Sep 2011    Post subject: Reply with quote
Easiest is just a tube of liquid - no bottles required.
https://www.bikechatforums.com/viewtopic.php?t=218217
alan0259
PostPosted: 19:57 - 27 Sep 2011    Post subject: Reply with quote
So you mean 4 individual tubes capped at the bottom?
That link you posted, it looks like he is just using one tube for two carbs, does his bike have 2 cylinders or 4?
EDIT: just thought, if it was capped would you have the same suction as if it was in a bottle? Or did you mean to just use one tube and bend it like the other guy?
The reason I want to do four at the same time is so I can see all the levels at the same time
PostPosted: 20:21 - 27 Sep 2011    Post subject: Reply with quote
Just one tube between 2 carbs. Depending how your 4 carbs are set up, you can either balance 1v2 together, then 3v4 together, then balance 1&2 against 3&4 (as 1v3, 1v4, 2v3 or 2v4) or one of your carbs has no adjustment and the other 3 do, so you balance 1v2, 1v3, 1v4.
herulach
PostPosted: 20:30 - 27 Sep 2011    Post subject: Reply with quote
cross post, but don't suppose you know the correct ID off the top of your head>?
YBR 125>FZS600
PostPosted: 22:42 - 27 Sep 2011    Post subject: Reply with quote
If linked at the bottom then the levels should even out without the engine running.
Remember that water is light enough to be pulled up a fairly large distance by intake vacuum. Hence decent kits used mercury (not easy to find these days).
Tiff
PostPosted: 23:51 - 27 Sep 2011    Post subject: Reply with quote
I use ATF, aquarium pipe from Homebase and a bit of wood. ATF is bright red so easy to see, and wont do any harm if sucked into the engine.
1996 Kawasaki GPZ1100s,1996 VFR750,1980 BMW R80,1982 Kwak Z250B,1992 ZZR1100C,1996 BMW K1100LT,1994 Kwak ZZR600E,1993 BMW R1100RS,1992 ZZR 600D,1988 BMW K100LT,1998 Aprilia Pegaso 650,1994 Suzuki RF900,1991 Yamaha XJ600, 1988 Honda Dominator,1992 Kwak KMX125,1987 Yamaha RD50MX,1984 Honda MBX50.1984 Honda Superdream 125
PostPosted: 00:24 - 28 Sep 2011    Post subject: Reply with quote
Guy on the Speed Four forum built this and used engine oil as the fluid.
https://inlinethumb21.webshots.com/35668/2064552080071146843S600x600Q85.jpg
alan0259
PostPosted: 10:02 - 28 Sep 2011    Post subject: Reply with quote
Just found out that I need something else as well, not sure where to buy it from either!
There is a rubber plug screwed into cylinder 1, I need an adapter to screw into this which I can then plug my hose on to.
Anyone know the proper name for these or where to buy them from?
cb1rocket
PostPosted: 13:58 - 28 Sep 2011    Post subject: Reply with quote
https://www.airlines-pneumatics.co.uk/webcat/Detprod.asp?ProductCode=S010144
alan0259
PostPosted: 14:47 - 29 Sep 2011    Post subject: Reply with quote
Thanks, managed to get some from the morgan carbtune site for £5 Very Happy
So, still undecided whether to connect all four hoses together, or just do two at a time.
What would you lot do? Surely the 4 way is best but why do most people do two at a same? Just pure lazy? lol
DrDonnyBrago
PostPosted: 15:05 - 29 Sep 2011    Post subject: Reply with quote
4 way is best, cost is probably why they aren't more common (when bought, not made).
Connecting them together at the bottom makes it simpler to set up. If they are not connected you will need to add exactly the right amount of oil to each tube or mess about with a ruler if they are not the same - if they are connected you just add oil to one of the tubes and it levels itself out.
I would have them all connected at the bottom. If your fluid was heavy enough you might get away with just 4 tubes into a bowl of oil.
alan0259
PostPosted: 15:26 - 29 Sep 2011    Post subject: Reply with quote
Looking at this pic, the amount of liquid in the 1st and 4th tube is more than 2 and 3.
Would this affect the reading at all? Or the fact that those tubes have bends in them?
PostPosted: 16:21 - 29 Sep 2011    Post subject: Reply with quote
Doesn't matter how much liquid is perceived in each tube, the important bit is that they are all level - they effectively have the same reservoir, and all equally are effected by gravity, so the only contributing factor to a varying level would be the pressure (or lack of) above the fluid, which is what you're measuring.
cb1rocket
PostPosted: 20:37 - 29 Sep 2011    Post subject: Reply with quote
just make sure that if you do the 2 carbs at a time test, make sure your doing it from the base carb ie the carb with no adjustment
PostPosted: 20:45 - 29 Sep 2011    Post subject: Reply with quote
Unless the carbs are of the type where you balance 1 to 2, then 3 to 4, then 1 and 2 to 3 and 4.
The last post was made 14 years, 350 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.27 - MySQL Queries: 13 - Page Size: 88.31 Kb
