Why am I such a fud!
StevenF
PostPosted: 18:30 - 10 Oct 2011    Post subject: Why am I such a fud! Reply with quote
Went out to bleed my back break on my bike tonight. I noticed my calliper moved slightly from side to side when pushing the leaver down, decided to tighten the calliper and SNAP! The bolt snapped clean in two, this has happen far too many times to me!
I'll need to try drill it out or something... Not happy!
yen_powell
PostPosted: 18:37 - 10 Oct 2011    Post subject: Reply with quote
They do have a bit of side to side wobble in them if they are the sliding pin type.
XT1200Z and a DR350 in bits
StevenF
PostPosted: 18:38 - 10 Oct 2011    Post subject: Reply with quote
Ah, that would explain the wobbling then!
Tim..
PostPosted: 18:39 - 10 Oct 2011    Post subject: Reply with quote
Shocked Shocked
www.marshallracing.co.uk
kerr
PostPosted: 18:45 - 10 Oct 2011    Post subject: Reply with quote
this happens a lot? you got forearms like popeye Laughing
aprilia 125 Af1 Futura >> Suzuki gsxr 600 srad >> J1 zx6r >> cbr 600rr >> Speed Triple
Quote Me Happy
PostPosted: 18:49 - 10 Oct 2011    Post subject: Reply with quote
A torque wrench and manual should be on the Christmas list. At least now you should have a feel of what a bolt feels like before it's going to give way.
The Artist
PostPosted: 18:51 - 10 Oct 2011    Post subject: Reply with quote
Never heard of a floating calliper Laughing
mcfailberg
PostPosted: 19:32 - 10 Oct 2011    Post subject: Reply with quote
Them handlebar things shouldn't move as you should only point the bike by counter steering. Best do up the headrace nut real tight until they stop moving too.
spyuggy
PostPosted: 19:50 - 10 Oct 2011    Post subject: Reply with quote
Does this go for rotating wheels too??? Confused
Treat each day as if it was your last, because one day you will be right.
P.
PostPosted: 20:49 - 10 Oct 2011    Post subject: Reply with quote
Your wheels go round!?
PostPosted: 21:31 - 10 Oct 2011    Post subject: Reply with quote
Only ever filled it up the once - couldn't get the cap off afterwards...
temeluchus
PostPosted: 01:29 - 11 Oct 2011    Post subject: Reply with quote
never tighten bolts with your wanking hand.
Mehty
PostPosted: 07:24 - 11 Oct 2011    Post subject: Reply with quote
What if your ambidextrous? Shocked
2007 YBR 125 (sold), 2011 ER6-N (sold), LHD 1999 GSX750F (sold), ???Sad???
pepperami
PostPosted: 07:48 - 11 Oct 2011    Post subject: Reply with quote
Damm! now I know why all my bikes are so crappy! Smile
PostPosted: 09:01 - 11 Oct 2011    Post subject: Reply with quote
mcfailberg
Most modern rears do, they slide horizontally, I guess to compensate for the pads wearing down.
You shouldn't need to drill it out, just undo the other bolt pull the calliper off then get some mole grips on stud.
StevenF
PostPosted: 10:50 - 11 Oct 2011    Post subject: Reply with quote
I can't grip it at all, it sheered flush into the break
Calliper housing :/
PostPosted: 11:04 - 11 Oct 2011    Post subject: Reply with quote
Calliper housing :/
Undo the other bolt and take the caliper off the bike, you may have to take the rear wheel off although you may get away with just taking the pads out of the caliper.
The caliper does not bolt directly to the bike, the bolts will only be threaded to the caliper, not the braket.
PostPosted: 11:15 - 11 Oct 2011    Post subject: Reply with quote
https://www.bikebandit.com/houseofmotorcycles/1992-honda-cbr600f2-rear-brake-caliper/o/m2041sch7491
You have broke bolt 17 right? See it screws into the caliper but the rest of it isn't threaded it just sits in the bracket, the thing that holds the calliper on is the disc, the bolts just stop in moving front to back. You will probably have to take the wheel and brake line off but it will just pull out, then you can turn the stub in a vice or mole grips.
The Artist
PostPosted: 16:00 - 11 Oct 2011    Post subject: Reply with quote
chris-red wrote:
mcfailberg
I know, it was more a rhetorical question but I forgot the ?
The last post was made 14 years, 116 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 103.42 Kb
