Pre heating coolant before startup in the winter?
ilduce
PostPosted: 04:30 - 20 Oct 2011    Post subject: Pre heating coolant before startup in the winter? Reply with quote
I hate the idea of starting a combustion engine that is -15 degrees C with stone hard oil etc.
I would like to build in a micro water pump. I imagine a 12v pump (or one for the wall plug would also be ok) that i can insert in the middle of a hose, and it will pump the water through the system, while i heat up the radiator.
Maybe i could some 12V Peltier elements to heat up the radiator?
Maybe a pump like this: https://www.campingshop.dk/produkt/vandpumpe-12v-comet-elegant-8-ltr.aspx
temeluchus
PostPosted: 05:57 - 20 Oct 2011    Post subject: Reply with quote
I've seen them for cars and bigger but not for bikes, I'd imagine it would take a fair amount of current to drive a pump and an adequate heater.....
You could just point a fan heater at the bike for a while?
0ddball
PostPosted: 06:28 - 20 Oct 2011    Post subject: Reply with quote
I think the most popular was made by Kenlowe. But tbh its a waste of time on a bike.
ZXR750L
iooi
PostPosted: 06:30 - 20 Oct 2011    Post subject: Re: Pre heating coolant before startup in the winter? Reply with quote
And just how many -15 C days a year do we get......
Oil is still pretty fluid even @ that temp.
Don't think that a bike battery will have enough power to do what you want, as it would take a lot to get the temp upto say zero......
doggone
PostPosted: 08:47 - 20 Oct 2011    Post subject: Reply with quote
I don't follow the logic of heating the radiator to avoid cold thick oil.
Surely you'd want to warm the sump if anything?
In a dry but unheated garage you could do that with a low wattage heater or even a light bulb under the bike.
Much easier if you really had to ride it the two mornings we get below -10C
Bezzer
PostPosted: 10:43 - 20 Oct 2011    Post subject: Reply with quote
Exactly, I remember from donkeys years ago those dome shaped mini paraffin heaters you used to be able to buy to leave under car sumps overnight to help with the same problem. Mind you 20-50 was the most "exotic" and thinnest oil you could buy then Mr. Green
There's one thing possibly wrong with the original idea of pumping and heating the radiator, don't forget you've got a thermostat in most systems that block the radiator off from the flow until a decent temperature is reached, it would take some serious heating and time before you got a full sytem circulation.
ilduce
PostPosted: 18:50 - 20 Oct 2011    Post subject: Reply with quote
We have about 70 of those days? Then what about a peltier element on the oil pan maybe?
Heater is no go, since i do not have a garage.
jimspeed
PostPosted: 19:00 - 20 Oct 2011    Post subject: Reply with quote
a lot of modern diesels now use a pipe with 3 glow plugs screwed into it maybe you could use something like that?
I'll be using me car when its -15 tho personally as I'm a wimp Laughing
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
ilduce
PostPosted: 19:02 - 20 Oct 2011    Post subject: Reply with quote
Hehe, yeah i could use something like that, but it sounds expensive?
weasley
PostPosted: 19:03 - 20 Oct 2011    Post subject: Reply with quote
In cold countries it's quite common to have a sump heater on a car or truck, which is plugged in to the mains via a weatherproof socket. Could easily just be stuck on the outside of the sump but would need mains supply rather than from the battery.
jimspeed
like this
https://www.ebay.co.uk/itm/Peugeot-206-Fuel-heater-2-0-Hdi-diesel-pre-heater-Dw10-/330557047716?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4cf6bc43a4
not sure how often you would need to recharge a good sized car battery or maybe a leasure battery?
The Artist
PostPosted: 19:07 - 20 Oct 2011    Post subject: Reply with quote
You are better off just sticking an electric heater under the sump so long as it is exposed and not covered by a belly pan or something.
10w40 oil is designed to work down to well below freezing. I cba searching but there is a chart which tells you what weight oils work in what temperatures.
PostPosted: 19:13 - 20 Oct 2011    Post subject: Reply with quote
https://www.fluidmasters.com.au/images/saeviscosity.gif
Given that we are largely UK based, our info may not be as specific as could be - what do other bikers in Denmark with no garages do?
tatters
Exxon Valdez
Blow torch under the sump to heat the oil up before starting, Widely used in Russia etc during the winter mostly on large diesal trucks.
just keep it away from rubber seals/cables etc.
PostPosted: 19:58 - 20 Oct 2011    Post subject: Reply with quote
Use mobil 1 oil. Stays runny even at stupidly sub-zero temperatures.
Older urals used to have an ash pan to put under the sump.
Teflon-Mike
tl;dr
PostPosted: 20:58 - 20 Oct 2011    Post subject: Reply with quote
Well the odd one or two I have ever met, and they were 'odd', reckoned that come winter, you put the bike away, got the coals stoked up in the sauna and found a big titted blond to share it....
If they had the energy over, after, or the BTB had a headache, they'd go build another hard-tale, or restore a Nimbus!
PostPosted: 21:02 - 20 Oct 2011    Post subject: Reply with quote
This.
When I went to Canada their cars were all plugged in overnight.
+1 to it makes more sense to heat the oil rather than the coolant as well.
orac
PostPosted: 23:04 - 20 Oct 2011    Post subject: Reply with quote
use this before you pull off each morning, should get the whole thing warmed up real nice
https://www.machinemart.co.uk/shop/product/details/little-devil-propane-fired-space-heater?da=1&TC=SRC-propane heater
you can get bigger ones too
Teflon-Mike
tl;dr
PostPosted: 23:50 - 20 Oct 2011    Post subject: Reply with quote
Big_Ham wrote:
This.When I went to Canada their cars were all plugged in overnight.
Yup; some places they do, more than others. They even used (when I was a kid there... long time ago!) to have parking meters with electric hook up!
More in the provincial towns and suburbs though; in the city they had heated underground car-parks.
Canadian Tyre... rather like Kwik-Fit meets Halfords, meets Army-Navy, meets Argos...... you could buy tyres, rifle rounds, shotguns! (curiouse attitudes they had out there; you could walk into a store and buy .22 amunition, more easily than a bottle of wine!) Christmas tree lights; garden furnature, push-bikes, fishing equipment, boats, canooes, ski's, all manner of outdoor wear, and a few motoring accessories...... used to be my Dads 'one stop' solution to any new outdoor interest that took his fancy, and precursor to yet another holiday desaster... sorry, 'adventure'....
He had the wonderful idea of trying white water rafting one summer...... bought a canoo..... we got grounded on a rock in the middle of the Bow River..... he's not exactly 'slim'...... He got out to see what the problem was, boat shot off like a rocket, and I was rather worried I'd end up over Niagra! Typical, he had the ruddy padle! Always leaving me up the creek without one of them!
Cross-Country Skiing was another brilliant idea he had. Ended up setting fire to a holiday cabin in White-Fish..... he got 'cold'!
Water Skiing in Kawlona was less fraught; after hiring three boats to find one powerful enough to tug him along...... and after too many people asking for a ride on the 'inflatable whale'... we used him as 'ballast'!
Sorry; I digress into childhood reminiscences! Sorry! My old man, might NOT have given me much, but did fill my childhood with memorable anecdotes! A thirty stone, University Proffessor; sort of cross between Quentin Crisp and Stan Laurel... with proffesor Remus hair, there was always SOME fine mess for him to be getting me into! Especially if it gained him Petro-Can points and could be claimed off his frequent flier miles!
Anyway, remember seeing 'outdoor parking' kits.... looked like a small emersion heater element, screwed in the sump in place of the sump-plug... came with numerouse adaptors for different cars, and in a couple of different sizes for little european 'compacts' up to big block Yank 'trucks'..... a few lengths of wire and caravan connectors, and a metal spike with a socket on for you to cement into your drive, to plug it in.
Only been back once, and that over ten years ago, since my old man moved to Vancouver, where despite it snowing when I visited, I was told it was the first time they had snow in Victoria for thirty years, I am assured its a lot more 'temperate' and no sign of electric hook-up for parked cars!
The old man 'celebrated' by treating himself to a convertible SAAB..... I declined riding it in..... He'd nearly caused a multiple pile up on the M40, playing with the electric Sun-Roof of my Grans Hyundi Coupe, taking him (greatfully!) to the air-port.... fiddling with buttons for the sake of it, opened it, causing a draft, (that sucked my hair into the hole!) and then 'CLOSING' it again.....
I was, doing about 70mph in the outside lane of the motorway, in busy traffic, in my Gan's, almost brand new pride and joy.... my nose pressed against the winscreen, the rear view mirror wedged in my jaw, yelling at him to STOP...... completely obliviouse of my rather curiouse driving possition, let alone my obviouse discomfort, har tangled in sun-roof mechanism..... he was jibbering at me "Why?! Its Cold!"
Fat man.... hates cold..... emigrates to Canada.... yup... THAT is my Dad.... more degrees than a thermomenter, but couldn't put stick two lego-bricks together if his life depended on it, and you gave him a full colour diagram, and instructional video!
ilduce
PostPosted: 05:41 - 21 Oct 2011    Post subject: Reply with quote
Thank you guys, but i think that the peltier elements will win the fight. They let the oil pan become the heater.
The idea was to make bearings etc. get warm before start. They wont get worm just by heating up the oil Smile
Mike: Overshare Very Happy
temeluchus
PostPosted: 06:19 - 21 Oct 2011    Post subject: Reply with quote
Peltiers are very current hungry.
By the time you faff aroud with them you may as well point a blow heater at the bike for fifteen minutes.
Teflon-Mike
tl;dr
PostPosted: 06:46 - 21 Oct 2011    Post subject: Reply with quote
I think the sauna & BTB is a better bet....
Though I guess you could stick bike in sauna to get bearings up to temp and offer to help BTB get warm and work up a sweat in other ways.....
Gazdaman
I did a trackday!!!
PostPosted: 09:53 - 21 Oct 2011    Post subject: Reply with quote
If it's cold enough out to make me worry that the oil might be thick and goopy, am I fuck riding the bike to work.
Gaz
The last post was made 14 years, 331 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 138.83 Kb
