| P.addy |
 P.addy Red Rocket
 Posted: 11:51 - 20 Oct 2011 Post subject: Clutch is heavier than last time. |
Right I have had enough issues with this bike now
The clutch is an absolute ball ache to pull in, so much so I have not used the clutch today. Thought I'd ride it in and see if it frees up. Come to a set of lights and needed 2 hands to pull it in.
The lever isn't bolted too tight, its got plenty of movement and bits of grease in the gaps. The cable is free, totally free, not trapped anywhere and pulls in and out smooth when not connected.
Clutch is slipping when I rev the bike high still.. im guessing backing off the adjuster on the left hand casing is my next step for that bit... but it still shouldn't be the cause for the clutch being heavier than a bowling ball.
If anyone local fancies a look, please let me know, i'll ride over as it is really doing my tits in now... I can barely ride the bike due to it.
I have just replaced part that broke (cable attaches to it and it pushes against the clutch pushrod) thinking it was that.. it was broken anyway, but thought it was so worn that could be the reason...it wasn't
Happy to travel around Kent this evening to get it sorted, that way I can get a VFR back to Woking for Shereen... and get on using my bike  |
| Kickstart |
 Kickstart The Oracle
| P.addy |
 P.addy Red Rocket
| Kickstart |
| P.addy |
 P.addy Red Rocket
| Kickstart |
 Posted: 12:52 - 20 Oct 2011 Post subject: |
Might well be hidden (like on the 600 Bandit where the cable goes into something which looks a bit like a slave cylinder). With these you generally have an adjustment process where you back the adjuster right off (with the cable adjuster backed off as well), then tighten it until it just makes contact with the clutch push rod, then slacken it back a touch before tightening the lock nut. The adjust the cable.
If the adjuster is wrong then the cable is trying to pull round the lever at an odd angle. Sorry, can't explain it very well, but imagine taking the top end off an engine and pulling the con rod up. When the crank is around the half way mark the vertical pull easily rotates the crank. If the crank is close to zero degree from the tdc position then most of your force is wasted pulling against the engine rather than rotating the crank.
| P.addy |
 P.addy Red Rocket
| Kickstart |
 Posted: 13:13 - 20 Oct 2011 Post subject: |
Not certain with your clutch, but an educated guess would be slacken the adjuster off at the lever (just so it doesn't interfere). Take the cap off the adjuster on the sprocket cover. Slacken off the lock nut. Loosen the adjuster right off and then gently tighten until you feel resistance. Then back off half a turn, hold the adjuster and do up the lock nut. Put the cap back on the adjuster then adjust the cable adjuster on the bars.
As to speedo, I presume it works off a crown piece on the front sprocket nut. Firs thing is probably to check it isn't damaged.
| P.addy |
 P.addy Red Rocket
 Posted: 13:16 - 20 Oct 2011 Post subject: |
I can adjust the cable at both ends... if I take the plastic off.
Can I just back off the lever adjustment, adjust the locknut then fiddle with the lever adjustment again.
Sorry to be a pain  |
| Kickstart |
 Posted: 13:36 - 20 Oct 2011 Post subject: |
Don't think it matters what end you adjust the cable (both ends just change the length of the outer relative to the inner). Only reason to slacken it right off is to stop it affecting what you feel when adjusting the main adjuster on the sprocket cover. If you can't slacken it off enough for that then you will need to use bother cable adjusters (orr just unhook the cable from the clutch lever).
| P.addy |
 P.addy Red Rocket
 Posted: 13:41 - 20 Oct 2011 Post subject: |
I'll have a fiddle later. Could ask some mechanics here to do it over lunch
Thanks Keith. |
| Mrjoolz |
 Mrjoolz Brolly Dolly
| P.addy |
 P.addy Red Rocket
| Mrjoolz |
| P.addy |
 P.addy Red Rocket
 Posted: 16:52 - 20 Oct 2011 Post subject: |
Nope, never carry stuff under there anymore. Especially tools. Sure I can sort it sometime this evening. |
| Mrjoolz |
Have you tried spraying some WD40 or something in there (perhaps some grease to lube the cable. Could the lever mounting be bent, so its not travelling freely, and hence the stiffness (Ooo errr) ____________________ Previous Bikes: TZR125, KMX125, RGV250, RD350YPVS, GXSR750H, GSXR600SRAD, R1 (2000), GSXR1000 (K1), ZZR600, CBR1100XX Super Blackbird
Current Bike: Suzuki GSX1300R Hyabusa..... |
| P.addy |
 P.addy Red Rocket
| Mrjoolz |
 Posted: 17:03 - 20 Oct 2011 Post subject: |
hope its not internal to clutch then ?  ____________________ Previous Bikes: TZR125, KMX125, RGV250, RD350YPVS, GXSR750H, GSXR600SRAD, R1 (2000), GSXR1000 (K1), ZZR600, CBR1100XX Super Blackbird
| Pete. |
 Pete. Super Spammer
 Posted: 17:06 - 20 Oct 2011 Post subject: |
Get it over here and I'll take a look at it. ____________________ a.k.a 'Geri'
| P.addy |
 P.addy Red Rocket
| Pete. |
 Pete. Super Spammer
 Posted: 17:17 - 20 Oct 2011 Post subject: |
Working in Brighton tomorrow so you better ring before you come over, coz it's a bad journey on a Friday. ____________________ a.k.a 'Geri'
| P.addy |
 P.addy Red Rocket
 Posted: 17:22 - 20 Oct 2011 Post subject: |
PM me your number mate
I finish around 6, could also just drop me a text when you are home/close as im only 20 minutes away.  |
| Fizzer Thou |
| P.addy |
 P.addy Red Rocket
 Posted: 09:30 - 21 Oct 2011 Post subject: |
Hi Fizzer thanks for the offer
I'm aiming to ride with BCF tomorrow but if Pete. is unable to sort it (he is a genius though ) then I shall drop you a call.
Should come to our ride out, doing 10 till 4 roughly  |
The last post was made 14 years, 167 days ago. Instead of replying here, would creating a new thread be more useful? |
