Clutch is heavier than last time.
PostPosted: 11:51 - 20 Oct 2011    Post subject: Clutch is heavier than last time. Reply with quote
Right I have had enough issues with this bike now Laughing
The clutch is an absolute ball ache to pull in, so much so I have not used the clutch today. Thought I'd ride it in and see if it frees up. Come to a set of lights and needed 2 hands to pull it in.
The lever isn't bolted too tight, its got plenty of movement and bits of grease in the gaps. The cable is free, totally free, not trapped anywhere and pulls in and out smooth when not connected.
Clutch is slipping when I rev the bike high still.. im guessing backing off the adjuster on the left hand casing is my next step for that bit... but it still shouldn't be the cause for the clutch being heavier than a bowling ball.
If anyone local fancies a look, please let me know, i'll ride over as it is really doing my tits in now... I can barely ride the bike due to it. Thumbs Down
I have just replaced part that broke (cable attaches to it and it pushes against the clutch pushrod) thinking it was that.. it was broken anyway, but thought it was so worn that could be the reason...it wasn't
Happy to travel around Kent this evening to get it sorted, that way I can get a VFR back to Woking for Shereen... and get on using my bike Laughing
PostPosted: 12:01 - 20 Oct 2011    Post subject: Reply with quote
Is there an adjuster on the engine end?
If so the angle the cable makes when it reaches it makes a big difference
PostPosted: 12:07 - 20 Oct 2011    Post subject: Reply with quote
Yep, 2 adjusters, one on bar and one at engine. They are all lined up straight, slotted in the gaps etc. I cleaned all the grime away (was LOADS behind the front sprocket cover) and still its a right nugget to use.
PostPosted: 12:28 - 20 Oct 2011    Post subject: Reply with quote
Should be about a 90 degree angle between the cable and the lever it operates.
PostPosted: 12:43 - 20 Oct 2011    Post subject: Reply with quote
Where are we talking about here? I'll grab photo at lunch... although... I cant remove panels at lunch. So flash and zoom will be my friends Laughing
PostPosted: 12:52 - 20 Oct 2011    Post subject: Reply with quote
Might well be hidden (like on the 600 Bandit where the cable goes into something which looks a bit like a slave cylinder). With these you generally have an adjustment process where you back the adjuster right off (with the cable adjuster backed off as well), then tighten it until it just makes contact with the clutch push rod, then slacken it back a touch before tightening the lock nut. The adjust the cable.
If the adjuster is wrong then the cable is trying to pull round the lever at an odd angle. Sorry, can't explain it very well, but imagine taking the top end off an engine and pulling the con rod up. When the crank is around the half way mark the vertical pull easily rotates the crank. If the crank is close to zero degree from the tdc position then most of your force is wasted pulling against the engine rather than rotating the crank.
PostPosted: 13:07 - 20 Oct 2011    Post subject: Reply with quote
I half understand... this probably means more dismantling Laughing
Anyway I grabbed a quick snap of the lever end and managed to get a shot of the pushrod.
Behind that rubber centre is the adjustment + locknut.
If you could tell me how to adjust it to get it right, I'll be very grateful Cool
Off topic, my speedo is intermittent. Assume its front sprocket driven as there is a sensor there... anything to look at? I know rough speed/rpm/gear so its not all bad.
https://i53.tinypic.com/sw331h.jpg
https://i51.tinypic.com/vw31l.jpg
https://i53.tinypic.com/98y4r4.jpg
As she stands...
https://i56.tinypic.com/2nu0hth.jpg
PostPosted: 13:13 - 20 Oct 2011    Post subject: Reply with quote
Not certain with your clutch, but an educated guess would be slacken the adjuster off at the lever (just so it doesn't interfere). Take the cap off the adjuster on the sprocket cover. Slacken off the lock nut. Loosen the adjuster right off and then gently tighten until you feel resistance. Then back off half a turn, hold the adjuster and do up the lock nut. Put the cap back on the adjuster then adjust the cable adjuster on the bars.
As to speedo, I presume it works off a crown piece on the front sprocket nut. Firs thing is probably to check it isn't damaged.
PostPosted: 13:16 - 20 Oct 2011    Post subject: Reply with quote
I can adjust the cable at both ends... if I take the plastic off.
Can I just back off the lever adjustment, adjust the locknut then fiddle with the lever adjustment again.
Sorry to be a pain Laughing
PostPosted: 13:36 - 20 Oct 2011    Post subject: Reply with quote
Don't think it matters what end you adjust the cable (both ends just change the length of the outer relative to the inner). Only reason to slacken it right off is to stop it affecting what you feel when adjusting the main adjuster on the sprocket cover. If you can't slacken it off enough for that then you will need to use bother cable adjusters (orr just unhook the cable from the clutch lever).
PostPosted: 13:41 - 20 Oct 2011    Post subject: Reply with quote
I'll have a fiddle later. Could ask some mechanics here to do it over lunch Laughing
Thanks Keith.
Mrjoolz
PostPosted: 16:22 - 20 Oct 2011    Post subject: Reply with quote
Did you manage to get it sorted ?
Previous Bikes: TZR125, KMX125, RGV250, RD350YPVS, GXSR750H, GSXR600SRAD, R1 (2000), GSXR1000 (K1), ZZR600, CBR1100XX Super Blackbird
Current Bike: Suzuki GSX1300R Hyabusa.....
PostPosted: 16:45 - 20 Oct 2011    Post subject: Reply with quote
Nope. Looks like a ride home with the heaviest clutch in the world. I'll find a screwdriver later and slacken it off.
Mrjoolz
PostPosted: 16:47 - 20 Oct 2011    Post subject: Reply with quote
you not got the tool kit under seat/sponge ?
PostPosted: 16:52 - 20 Oct 2011    Post subject: Reply with quote
Laughing Nope, never carry stuff under there anymore. Especially tools. Sure I can sort it sometime this evening.
Mrjoolz
Have you tried spraying some WD40 or something in there (perhaps some grease to lube the cable. Could the lever mounting be bent, so its not travelling freely, and hence the stiffness (Ooo errr)
PostPosted: 16:55 - 20 Oct 2011    Post subject: Reply with quote
Nah lever/cable are all fine.
I had this side of the clutch stuff dismantled and all cleaned and greased up.
Getting sick of fixing things now..
Mrjoolz
PostPosted: 17:03 - 20 Oct 2011    Post subject: Reply with quote
hope its not internal to clutch then ? Crying or Very sad
PostPosted: 17:06 - 20 Oct 2011    Post subject: Reply with quote
Get it over here and I'll take a look at it.
PostPosted: 17:12 - 20 Oct 2011    Post subject: Reply with quote
Really? I could possibly run it there after work tomorrow, closer to you then.
PostPosted: 17:17 - 20 Oct 2011    Post subject: Reply with quote
Working in Brighton tomorrow so you better ring before you come over, coz it's a bad journey on a Friday.
PostPosted: 17:22 - 20 Oct 2011    Post subject: Reply with quote
PM me your number mate Thumbs Up
I finish around 6, could also just drop me a text when you are home/close as im only 20 minutes away. Mr. Green
Fizzer Thou
PostPosted: 22:46 - 20 Oct 2011    Post subject: Reply with quote
I am away for my birthday tomorrow Paddy.But I aim to be home on Saturday morning as I have several other bikes to fix before a possible rideout in the afternoon.If you bring Terry over I have full workshop facilities to try and sort out your problems.You have my mobile number that I sent you via PM previously.
Always have a 'Plan B'
PostPosted: 09:30 - 21 Oct 2011    Post subject: Reply with quote
Hi Fizzer thanks for the offer Smile
I'm aiming to ride with BCF tomorrow but if Pete. is unable to sort it (he is a genius though Laughing ) then I shall drop you a call.
Should come to our ride out, doing 10 till 4 roughly Laughing
The last post was made 14 years, 165 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.76 - MySQL Queries: 13 - Page Size: 123.62 Kb
