| jpderv |
 jpderv Nitrous Nuisance
| spyuggy |
 spyuggy Nitrous Nuisance
| jpderv |
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 23:13 - 19 Oct 2011 Post subject: |
not a good idea to disconnect the battery when the engine is running.Due to the recent cold and dwindling daylight its at this time of year that knackerd batteries die.Try another battery first and if you want to check the voltage always check it across the battery terminals,with and without the engine running.
What voltage does the battery read when disconnected? ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| jpderv |
| unitynotsocri... |
 Posted: 23:23 - 19 Oct 2011 Post subject: |
it may be the battery is too knacked to hold a charge.Try another one to see,This time of year small bike electrics suffer severely if they have a knacked battery.
You should get 13.5. to 14.5 volts on a good battery.(without lights on) ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| jpderv |
| unitynotsocri... |
 Posted: 23:47 - 19 Oct 2011 Post subject: |
depends on where you testing for voltage,there's loads of ways to do it wrong.The multimeter can read O volt if they are connected to the generator coils as the power is Alertnating Current.Many systems need the battery in in order to work ,whether its knacked or not.
You might find that putting a better battery in will sort it out. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| Fizzer Thou |
| jpderv |
| MickC |
 MickC Spanner Monkey
 Posted: 07:01 - 20 Oct 2011 Post subject: |
Could be the alternator is on its way out, but as suggested check the battery first. ____________________ XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1 |
| whitedevil |
 whitedevil World Chat Champion
| Fizzer Thou |
| weewards |
 weewards Derestricted Danger
 Posted: 12:40 - 20 Oct 2011 Post subject: Battery Charger |
Hi, all the messages so far have coverered the battery testing but on a slight tangent I use an Optimate 4 charger and not only would it tell if the battery is knackerered it would also try to fix it if the battery is sulphated, just a thought  |
| jpderv |
| Bezzer |
 Bezzer World Chat Champion
| jpderv |
| unitynotsocri... |
 Posted: 19:04 - 21 Oct 2011 Post subject: |
the stator wires will have two wires to the pick up/ign trigger and should have three to the charging/lighting circuit.by finding the colour codes (compare with other similar engines/models) you can test the resistance across the coils and pick up/ign trigger to see if they are knacked or not.Sometimes the insulation gets dry and brittle .before taking the stator cover off try checking the connector block contacts are clean and a tight fit.If you get a spark you can ignore the pick up/ign trigger coil. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| jpderv |
| unitynotsocri... |
 Posted: 20:33 - 21 Oct 2011 Post subject: |
top right black box with 2 crosshead screws is your pulse trigger,the oil is no problem as the engine oil bathes the rotor,
Guess that theres a yellow and a pink wire and a green coming from your coils.black/red and green/white may be your pulse/trigger coil
it looks ok but you need to get a wiring diagram and test the resistance with the multimeter.Dont pull the wires out,you can test across the connector block.also check that theres a good earth wire to the starter and frame
On the rotor you should see a little magnet fitted.When the rotor spins the little magnet passes over the black coil/box to tell the cdi to spark ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| unitynotsocri... |
 Posted: 20:56 - 21 Oct 2011 Post subject: |
been rooting for a wiring diagram but no luck.you could try looking at alternator parts for eastern non jap bikes and see if you can find a coil set the same,making a note that one central coil is different,then,uses that as a guide to backtrack to 'resistance measurements.
many of these chinese bikes use the the same type coils.Its quite rare that charging coils break so your problem might be elsewhere,e.g. a loose wire or commectors that have been put back wrong.Sometimes when someones taken out the wiring loom to say,replace a headlamp shell they can wire up the greens wrong,mixing up the indicator earth and the lighting /switchgear earth.i'll keep looking for you. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| jpderv |
| Bezzer |
| jpderv |
| unitynotsocri... |
 Posted: 00:44 - 22 Oct 2011 Post subject: |
dont waste your money before checking your wiring out with the multimeter,although its a pain its well good for your skills.with a spec sheet it will be so much easier than replacing the electrical componenets.
check for water in indicators and loose/chaffed wire all over the loom, ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
The last post was made 14 years, 260 days ago. Instead of replying here, would creating a new thread be more useful? |
