can i sand alli?
hadden
PostPosted: 22:26 - 12 Nov 2011    Post subject: can i sand alli? Reply with quote
im currently polishing my rs 125 frame up and its going well.im going to do the top yoke to as my keys have worn some of the paint of too.im wondering if i sand it down will i be able to get the tiny scuffs out left by the sand paper and will it polish out?thinking of using 180 grit first then use some wet and dry.then plenty of polishing with a drill and buffer wheel style thingy majiggy.will this bring out the mirror effect of alli?
PostPosted: 22:38 - 12 Nov 2011    Post subject: Reply with quote
Yes you can sand it no problem.
stirlinggaz
PostPosted: 22:40 - 12 Nov 2011    Post subject: Reply with quote
hi,
the top yoke CAN be sanded.....but its a pig of a job.
its anodised & needs to be really rough grade of wet & dry, then done with higher grades until its smooth.
looks really good if done properly, but like i said, c*nt of a job to get all the old blue finish.off.
& you really need to keep on top of the polishing (autosol ftw) or it looks crap......
easier & quicker to get a cover.(sticker type thing)
cheers,
GAZ
Suntan Sid
PostPosted: 22:41 - 12 Nov 2011    Post subject: Re: can i sand alli? Reply with quote
Yes, but start with wet and dry, 180 grade is a tad harsh, I'd be starting with 600 grade.
You could start with a plastic scouring pad, I've had good results with these.
For a good finish you will need to get some proper polishing paste, Autosol is not god enough for what you want.
hadden
PostPosted: 22:45 - 12 Nov 2011    Post subject: Reply with quote
cool well iv been using autosol on the frame and to be honest iv spent hours on it and its good put not as good as i want it.i really dont mind putting the hours in so i was just thinking of polishing with autosol till its perfect.what paste should i use for an immaculate finnish?heres the swingarm so far..
Drake
PostPosted: 23:10 - 12 Nov 2011    Post subject: Reply with quote
will be a pig but a bench grinder with mops would make it easier after you have used wet and dry
Beamexican
PostPosted: 23:38 - 12 Nov 2011    Post subject: Reply with quote
I've always found peek metal polish better than autosol comes in a similar size tube, silver with blue writing i think.
Rick
Nope.
PostPosted: 23:45 - 12 Nov 2011    Post subject: Reply with quote
I still swear by autosol.
My GSXR frame is the proof.
Just keep at it and you'll get there.
With regards to the yoke just use a buffing wheel and some proper buffing compound if you've got access to it. Thats what I did to mine and now that gleams.
Fizzer Thou
PostPosted: 11:49 - 13 Nov 2011    Post subject: Reply with quote
I only have a few polished bits on any of my bikes as I prefer the anodised finish.But parts that have looked scruffy in the past have come up nicely with emery cloth and a dab of WD40.
https://www.machinemart.co.uk/shop/search/filter/emery+cloth/type/any/page/1
I then use Duraglit type metal polish wadding to keep it looking good.
Always have a 'Plan B'
Walloper
PostPosted: 14:33 - 13 Nov 2011    Post subject: Reply with quote
Polishing is a process for removing surface layers.
The more aggressive the polish the deeper the marking it causes.
Fine polish (200 grade) still leaves microscopic marks more or less invisible to the naked eye. (Almost).
Aluminium is soft so tends to clog more than steel when polishing. For this reason you need to use coarser grits and probably lots of sheets.
Finishing is perfectly OK using Autosol.
You have to consider the fact that every grade of polish leaves it's mark. So changing grades from 80-200 etc. makes the marks less visible.
If your final polish using Autosol etc. is still not like a mirror then you have not completed the wet or dry stage yet and the little polishing marks have not been rubbed off yet.
Suntan Sid
PostPosted: 22:26 - 13 Nov 2011    Post subject: Reply with quote
Buy a polishing mop, fit it to an electric drill and buy some proper polishing paste, it will make the job so much easier.
Use wet and dry to start with, then go to the polishing pastes/sticks.
If you feel you can't resist the allure of Autosol use it as the final polish.
A word of advice, if you use Autosol with a polishing mop, buy a separate mop and use it specifically for Autosol only, the Autosol tends to saturate the mop, and will leave a residue on anything you polish with the mop.
Seriously using Autosol, as your only polishing agent, is just making more work for yourself, buy the polishing pastes/sticks, they're relatively cheap and you'll see the difference straight away.
hadden
PostPosted: 20:56 - 14 Nov 2011    Post subject: Reply with quote
right ok.well thanks to everyone again for all your input.im currently using wet and dry and it sais 400 on the back but its still leaving marks.theres is loads of tiny little nicks in the frame which are bugging me and its gettin them out sound.i dont want to sound like a donut but do you sand it dry first then wet the paper or the other way round?im going to get some proper polishing paste this weekend so ill see how i go on with that.
red bull gives you wing sting!!!
current:aprilia rs 125
previous:honda c90,honda cm 125,yamaha xt 550,2004 suzuki drz 400.(all used for off road back in the day)and a piagio zip 50cc..oooossssshhhh
kerr
PostPosted: 21:28 - 14 Nov 2011    Post subject: Reply with quote
your going to need more than 400 to finish it all, use the 400 or courser to get rid of all the nicks etc, using it dry will be fine for the first couple of grades.
You need to work up through grades, for example 400 - 600 - 800 - 1000 all the way to something like 2000 grade to finish using a contstant stream of water wile sanding.
Then get yourself polishing mops with cutting compounds, iv used a kit like this that worked very well https://www.ebay.co.uk/itm/Metal-Polishing-Kit-Polishing-mops-accesoriesdiy-polish-/250482039945?pt=UK_Motorcycle_Parts&hash=item3a51e49c89#ht_1679wt_952
then autosol to finish it off, bearing in mind your going to have to polish it fairly regularly to keep it shiny.
aprilia 125 Af1 Futura >> Suzuki gsxr 600 srad >> J1 zx6r >> cbr 600rr >> Speed Triple
Walloper
PostPosted: 22:18 - 14 Nov 2011    Post subject: Reply with quote
Using water makes it easier and the paper lasts longer.
The idea of using wet and dry is that the water washes away the material rubbed off by the grit so the grit can get to the next layer.
Google: 'Polishing Aluminium' on a computer.
PostPosted: 22:26 - 14 Nov 2011    Post subject: Reply with quote
https://www.caswellplating.com/buffs/Buffbook.pdf
hadden
PostPosted: 22:32 - 14 Nov 2011    Post subject: Reply with quote
brill.ill get that stuff for this weekend then.and ill start using wet/dry properly Smile.cheers
spyuggy
PostPosted: 22:44 - 15 Nov 2011    Post subject: Reply with quote
When using wet and dry, I always use soap rubbed into the paper, so as to smooth out any little scratches, left by the grit.
I put warm water with washing up liquid mixed, then rub washing?face soap into the grit after it is wet, works wonders for me.
Treat each day as if it was your last, because one day you will be right.
PostPosted: 23:44 - 15 Nov 2011    Post subject: Reply with quote
I also use washing up liquid with wet&dry.
Damon
PostPosted: 09:04 - 16 Nov 2011    Post subject: Reply with quote
As above, but only a small amount though Thumbs Up
Frog
PostPosted: 19:28 - 16 Nov 2011    Post subject: Reply with quote
Jumping on the bandwagon... me too!
Works really well to stop everything getting clogged up. Keep your paper reet wet.
1200 grade with autsol as a final polish (I now have shiny downpipes and a mainly whiney exhaust Smile )
CBT 23/09/10 - Theory 19/03/11 - Mod1 19/04/11 - Mod2 06/05/11
Bikes: CBF125 (sold 30/10/10-25/09/12) - CB400 24/06/11 (broken) Sad - ER6-f 25/09/2012 Very Happy
hadden
PostPosted: 21:46 - 26 Dec 2011    Post subject: Reply with quote
where am i going wrong??i have spent hours on it and you can still see tiny scratches.i went from 400-600-800-1000-1200-1500 with at least 15 minutes on all grades,just on 6 inches, with fairy liquid and warm water and still not half as shiny as i hoped.i have bought some polishing compound which is a wax like stuff.a brown lump and a blue lump.iv just ordered some new polishing mops and the old ones where extremely black.will the brown stuff get those little marks out???
Ariel Badger
PostPosted: 22:17 - 26 Dec 2011    Post subject: Reply with quote
That is polishing for you, hours and hours of tedium. You need to get absolutely every mark out from the previous grade before moving to the next and guess what? Now you have removed the anodising it will tarnish and pit at the first sign of moisture or salt.
Nope.
PostPosted: 23:12 - 26 Dec 2011    Post subject: Reply with quote
Strip, shot blast and powder coat is probably the best way if you dont want to polish.
Its not overly expensive and you should get a good finish if you go to a proper bike place.
Ichy
PostPosted: 23:31 - 26 Dec 2011    Post subject: Reply with quote
Unless you have a big mop 15 minutes isn't going to be enough. I've done a lot of polishing and it takes hours to get the finish you want. One tip is to sand it with wet and dry, wet, in an orbital fashion, as random as possible. Rubbing back and forth creates marks all going in the same direction which are harder to polish out.
You also need to ensure that all of the scratches from the lower grades of paper are removed before moving to the next level. I rarely use more than a 800 grit for major work and then a 1200 prior to polishing.
To get these fork legs to a similar shine as the stanchions took about 4 hours each side
https://i93.photobucket.com/albums/l41/marki_03/xv1000/edit4.jpg
The quality of the aluminium also causes problems. If you look at my old eliminator you can see different finishes in the fork legs, timing cover and clutch cover. This is just down to the differences in the alloy. Sometimes you just have to accept that the finish is as good as it gets.
https://i93.photobucket.com/albums/l41/marki_03/stuff/PICT1123.jpg
I've said it many times before and I'll say it again, methelated spirits helps to preserve the finish. The ethanol causes micro corrosion on the surface of the alloy in a similar, but not as effective, way to anodising. It does reduce the shine but not enough to make a difference. The only off the shelf polish that I have any confidence in is peek.
Ariel Badger
PostPosted: 23:53 - 26 Dec 2011    Post subject: Reply with quote
I would like to thank the OP for the bad Karma rating. Would it like to explain itself?
The last post was made 14 years, 248 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.17 - MySQL Queries: 13 - Page Size: 133.99 Kb
