'91 cbr600 starter clutch
awj72
PostPosted: 23:03 - 11 Sep 2004    Post subject: [WANTED] '91 cbr600 starter clutch [WANTED] Reply with quote
Thread title says it all really, my baby's poorly Mad Mad Mad , had it looked at, & apparently the stsrter clutch is the problem. Going to try and keep off it because bump starting it can't be good for it, plus it's bloody heavy!! Crying or Very sad
Any help greatly appreciated.
thanks guys
Woe to you, o earth & sea, for the devil sends the beast with wrath............
(my ebay clearout...... https://search.ebay.co.uk/_W0QQsassZawj72QQhtZ-1 )
Ant
PostPosted: 22:00 - 12 Sep 2004    Post subject: Reply with quote
Starter clutch? or the starter relay?
i had the relay go in mine (92) and wouldn't really look at second hand unless your short of cash because all the others may be on there way out too!
Mine was about £90 too
04 ZX10R ~
awj72
PostPosted: 22:37 - 12 Sep 2004    Post subject: Reply with quote
I'll fully admit to not being the most mechanical headed fellow just yet, but it was definitely the starter clutch I was told to look for. If you don't recommend 2nd hand mate, have you a link to anywhere I can get a new one from? Cheers again for your help. Very Happy
Ant
PostPosted: 20:06 - 13 Sep 2004    Post subject: Reply with quote
No, because i'm (also not been to technical) not too sure on what a starter clutch is!
Anyone?
04 ZX10R ~
awj72
PostPosted: 20:12 - 13 Sep 2004    Post subject: Reply with quote
bollocks!!!!! Confused Confused Confused
HHHEEEELLLLPPPPPPPPPP!!!!!
awj72
PostPosted: 20:22 - 15 Sep 2004    Post subject: Reply with quote
come on guys, pretty please, getting witdrawal symptoms here, cant find one anywhere Crying or Very sad Crying or Very sad Crying or Very sad Crying or Very sad
Laura
Playboy Bunny
PostPosted: 20:28 - 15 Sep 2004    Post subject: Reply with quote
I have never heard of a starter clutch you sure you got the name right.
Good girls ride motorcycles bad girls thrash them.
awj72
PostPosted: 21:13 - 15 Sep 2004    Post subject: Reply with quote
thats what i thought, but it's deffo what i was told to look out for, got everyone i know on lookout, might have to bite the bullet and go "new" part if can source one
Confused
Laura
Playboy Bunny
PostPosted: 19:25 - 16 Sep 2004    Post subject: Reply with quote
But if you have the neme wrong then you will not find one I have the model before your's and never heard of a stater clutch I am afraid.
PostPosted: 20:06 - 16 Sep 2004    Post subject: Reply with quote
A starter clutch is the bit that engages the starter motor to the main engine. At a guess it's a centrifugal clutch; so if the starter motor doesn't have enough power to turn it or the engine is already spinning then it won't do 'owt bad.
PostPosted: 20:15 - 16 Sep 2004    Post subject: Reply with quote
Have had a poke around Google and have found an link to an old eBay auction for a starter clutch for a CBR600 so they are real parts, might be best to talk to a Honda dealer to find out firstly how much they cost new and if they are normally called starter clutch just tell him that you've been told you need one and havn't ever heard of them before. Think it might be the bit that engine connects to the starter motor to start the bike.
awj72
PostPosted: 21:03 - 16 Sep 2004    Post subject: Reply with quote
Cheers for all the help & advice guys, will keep you posted, missing the bike already, only been a week!! Crying or Very sad
PostPosted: 21:55 - 16 Sep 2004    Post subject: Reply with quote
Don't see that bump starting it should be too much of a problem.
Apparantly it can fry the electrics on a few newer bikes, but I can't see that happening. Most of the bike's I've had I have bump started at some point, never had a problem with it.
In the end you're basically doing the same thing as the starter. Should be pretty easy on the CBR, 600cc 4's usually only need 10 meters push or so.
Sparks!
Sir Tart-a-lot
PostPosted: 22:00 - 16 Sep 2004    Post subject: Reply with quote
By centrifugal clutch do you mean one, that doesn't require use of the clutch? These are commonly used in MX/supermoto/trail etc but not heard of them on sports bikes?
If by centrifugal, that is what you mean, then surely you can't bump start it very easily??? I know the XR650 my mate was racing, would be impossible to bump start without a tractor pulling it Laughing that had a centrifugal clutch..
PostPosted: 22:18 - 16 Sep 2004    Post subject: Reply with quote
Centrifugal clutches are automatic clutches, as the clutch rotates faster the clutch pads spin out further (they are held inwards by springs) and grip the clutch drum and provide the power like a normal clutch then. Have a read of this guide to centrifugal clutches if you want to know more, it is about minimoto ones but centrifugal clutches are the still the same on any bike which has one.
A centrifugal clutch just for the startor.
Minimotos use them, as do scooters. As the revs rise the clutch plates move out against springs. The faster it goes the higher the centrifugal force, so the more they 'grip' as such.
As you can't control what revs they engage manually I've never heard of a big bike using them... I suppose you could have a way to manually engage it, but I suspect it would be pretty heavy if it was cable operated; you would have to fight against varying centrifugal force.
Sparks!
Sir Tart-a-lot
PostPosted: 22:33 - 16 Sep 2004    Post subject: Reply with quote
Yeah I know how they work, that's why I was confused about a CBR600 using one, but now you've cleared it up, it's the starter clutch Doh!
MX/supermoto's commonly use these, my mate races an XR650 which has a centrifugal clutch, not sure how it works really with engaging it etc, he just gets on and rides off, no clutch! Laughing
Seen quite a few KTM's running these too.
PostPosted: 23:12 - 16 Sep 2004    Post subject: Reply with quote
Presumably it's not too bad on a bike with a big spread of torque; where you don't need to slip the clutch.
I presume you can't stall it either, which would have definite advantages for motocross I suspect Smile. It seems the clutch is pulled in by the foot pedal as you chance gear?
Sparks!
Sir Tart-a-lot
PostPosted: 23:24 - 16 Sep 2004    Post subject: Reply with quote
I'm not too sure how it works.
Had a quick search on google and found this, it isn't exactly what I'm thinking about but seems another way of not using the clutch;
https://www.pro-supermoto.com/catalog/product_info.php/products_id/278
But the thing I am thinking about is a normal centrifugal clutch that doesn't require use of the lever.
PostPosted: 00:39 - 17 Sep 2004    Post subject: Reply with quote
That sounds like a normal centrifugal clutch to me Confused.
Sparks!
Sir Tart-a-lot
PostPosted: 10:44 - 17 Sep 2004    Post subject: Reply with quote
Shhhhhhh I didn't read the full description of the link, have realised it is a centrifugal clutch Laughing when it said Zstart I thought it was just a device for pulling away quicker without using the clutch - having read it, then yes that's what I'm on about - a centrigual MX clutch Very Happy
awj72
PostPosted: 22:41 - 23 Sep 2004    Post subject: Reply with quote
https://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=2490974622&category=35595 pretty pleasse, will this fit a '91???????????????
PostPosted: 00:36 - 24 Sep 2004    Post subject: Reply with quote
Seeing that the advert specifies several other years, by year, I doubt it.
awj72
PostPosted: 00:57 - 24 Sep 2004    Post subject: Reply with quote
x-ed my mind as well, worth a try though, as a wise man once said.............bollocks!!!! The search continues, thanks again fellas Thumbs Up
The last post was made 22 years, 16 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 129.8 Kb
