2000 derbi gpr 50 wiring
garyshannon19...
PostPosted: 11:58 - 01 Jan 2012    Post subject: 2000 derbi gpr 50 wiring Reply with quote
i have done a full nut and bolt strip/rebuild on my derbi gpr 50 evrything was gouing great untill i had to reconnect the electrics i found that the wiring diagram i have is different to whats there maimly the wiring for the coil/cdi also the lights will only work and starter motor turn the correct direction when you connect the battery positive to negative and vice versa all the earth cables ect are in the correct places.
if anybody can help i'd be forever in there debt
glshannon
HD
PostPosted: 13:27 - 01 Jan 2012    Post subject: Reply with quote
1. Post in the workshop.
2. What are you actually asking?
pits
PostPosted: 13:42 - 01 Jan 2012    Post subject: Reply with quote
3. Learn to spell and punctuate, find where the comma is.
garyshannon19...
PostPosted: 14:34 - 01 Jan 2012    Post subject: Reply with quote
if anyone can help with the wiring or if they have a better wiring diagram than the one i downloaded is not very useful due to there being two different layouts to do with the ignition coil and rectifier i have a 3 pin rectifier and the diagram i have is for a 5 pin
glshannon
nowhere.elysium
The Pork Lord
PostPosted: 15:23 - 01 Jan 2012    Post subject: Re: 2000 derbi gpr 50 wiring Reply with quote
Derp.
garyshannon1981 almost wrote:
I have done a full nut and bolt strip/rebuild on my derbi gpr 50.
Everything was going great, until I had to reconnect the electrics. I found that the wiring diagram I have is different to what's there; mainly the wiring for the coil/cdi.
Also, the lights will only work and starter motor turn the correct direction when you connect the battery positive to negative and vice versa. all the earth cables ect are in the correct places.
If anybody can help I'd be forever in their debt
Mentioning the actual problem helps, by the way:
I have a 3 pin rectifier and the diagram I have is for a 5 pin
Right. I had a look through the wiring diagrams thread, and managed to burn half an hour looking for wiring diagrams for this bike that include a 3-pin rectifier. I found this manual, which seems to cover a few bikes. Page 58 has got the closest to a coherent diagram depicting a 3-pin one that I could find. Hope it's of some help, because this has eaten a surprising amount of time Laughing
HD
PostPosted: 17:14 - 01 Jan 2012    Post subject: Reply with quote
I have some wiring diagrams for the GPR. Haven't got access to a scanner but I can take photos if you want, although they will probably be shit Laughing
garyshannon19...
PostPosted: 10:47 - 02 Jan 2012    Post subject: Reply with quote
the main problem i have now is the bike starts and runs now but only if i connect the positive lead to the negative terminal on the battery and vice versa.
i think im going to have to go the expensive option and take her in to a bike dealers.
thank you anyway for your offer
glshannon
HD
PostPosted: 13:30 - 02 Jan 2012    Post subject: Reply with quote
Just strip all of the electrics off and start again!
The last post was made 14 years, 319 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 1.31 - MySQL Queries: 13 - Page Size: 57.33 Kb
