Gilera Stalker 50cc problem
mazzda-007
PostPosted: 15:06 - 15 Jan 2012    Post subject: Gilera Stalker 50cc problem Reply with quote
Hi guys i am still having trouble fixing up my Gilera Stalker 50cc.
I have recently done a top end rebuild on the engine after the barrel was scrached by the piston. since i have done this i have had problems starting the engine, and when it does start it will only tick over, once you try and rev it up it cuts out/stalls.
i have checked the carb, reed, spark plug, battery drive belt the works.
I just cannot work out why it wont run normally and really need some help if possible
gilera stalker 50cc going on gsxr 1000 i hope Razz
Nope.
PostPosted: 18:24 - 15 Jan 2012    Post subject: Reply with quote
Have you checked the seal on the manifold between the carb and the engine? It sounds as if you have an air leak.
To check start the engine up with the back wheel in the air (since its an automatic) and spray some wd40 around the manifold. If the engine revs up when you do this you have an airleak. This is not an entirely conclusive test but if it works then its a nice simple way to see if you have an air leak.
Clutchy
PostPosted: 18:41 - 15 Jan 2012    Post subject: Reply with quote
Making sure the air box is properly connected could be your answer, sometimes when you put them back on its easy to not do it properly :S
mazzda-007
PostPosted: 22:22 - 15 Jan 2012    Post subject: Reply with quote
the air filter is on properly i have tried it wioth the original and a sports version i brought
Nope.
PostPosted: 23:17 - 15 Jan 2012    Post subject: Reply with quote
So called "Sports" Filters are often not worth the hassle on a nearly stock moped. Put back the original airbox.
When you fitted the air filter did you upjet? If so then re-fit the original jet and return the carb to stock settings.
mazzda-007
PostPosted: 23:25 - 15 Jan 2012    Post subject: Reply with quote
i tried that i had a 60 jet in it and it worked a bit better than the 55 original. it worked fine before the barrel scrached its since i repaired it it hasnt worked.
I have got a zx exhaust & 4g rollers on and they have never caused a problem the original airbox is on it at the moment and i cant get the bike started at all
Nope.
PostPosted: 23:34 - 15 Jan 2012    Post subject: Reply with quote
Are you sure you have the basics? Oil, Spark, Fuel, Air and Compression?
If you've just done a top end rebuild then id check your compression.
Oh, and if you've got a so called "sports" exhaust then you need to fit a bigger jet anyway.
skikman
PostPosted: 23:35 - 15 Jan 2012    Post subject: Reply with quote
not being smart but have you the piston on the right way [arrow pointing towards exhaust port]
mazzda-007
PostPosted: 01:49 - 16 Jan 2012    Post subject: Reply with quote
lol yea we made sure of that ( i did do that at first but dad pointed it out and was corrected)
Clutchy
PostPosted: 08:34 - 16 Jan 2012    Post subject: Reply with quote
what colour is the tip of your plug?
mazzda-007
PostPosted: 11:15 - 16 Jan 2012    Post subject: Reply with quote
what plug? - spark? plug? that is brand new as well
The last post was made 14 years, 262 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.85 - MySQL Queries: 13 - Page Size: 71.21 Kb
