nsr 125 fucked
Finney2003uk
PostPosted: 23:41 - 16 Sep 2004    Post subject: nsr 125 fucked Reply with quote
ayup lads just wondering if u could help me earlyer today may nsr 125 just stopped just fucked up over heated and started smoking just wondering how much on advreage does it cost to sort it out
also whats wrong with it
Frost
PostPosted: 00:03 - 17 Sep 2004    Post subject: Reply with quote
did it seize? as in engine lock solid? or did it just overheat?
alains
PostPosted: 02:08 - 17 Sep 2004    Post subject: Reply with quote
i think you've got a hole in the piston , i do not know price repair in the UK and i hope the barrel have no damage .
alains
PostPosted: 02:16 - 17 Sep 2004    Post subject: Reply with quote
here in france barrel=£100 , piston+rings £80 , seals £20 , plus 3 hours labour at about £25 each , total £300 approx. and i presume it's about the same in UK
PostPosted: 01:44 - 19 Sep 2004    Post subject: Reply with quote
Doubt it has holed the piston. Overheating followed by "smoking" would suggest to me that the head gasket has failed. Check the level of the coolant in the engine / radiator.
However if this is the case then the parts needed are likely to be the same as for a holed piston, just that you might need to replace the head (or get it skimmed flat again) as well.
Finney2003uk
PostPosted: 23:53 - 20 Sep 2004    Post subject: Reply with quote
there was no water in the radator well about 1/8 th of a pint
alains
PostPosted: 00:10 - 21 Sep 2004    Post subject: Reply with quote
take off the thermostat , fill the circuit with distilled water and drive for a while . then check water level , if no overheating then change thermostat (obviously if your engine is not down)
Finney2003uk
PostPosted: 14:09 - 21 Sep 2004    Post subject: Reply with quote
cant start me bike at all its fucked
alains
PostPosted: 16:22 - 21 Sep 2004    Post subject: Reply with quote
so , now you've some work to do . take off barrel , inspect precautionly & eventually change it with the piston . it will take 4-5 hours work .
Finney2003uk
PostPosted: 22:39 - 21 Sep 2004    Post subject: Reply with quote
so take off the barrel check 4 damage in side and check the piston
Finney2003uk
PostPosted: 22:42 - 21 Sep 2004    Post subject: Reply with quote
what about just puting a 180 piston and barrel on would that work and also i would have to sort out the timing would it fit
PostPosted: 22:51 - 21 Sep 2004    Post subject: Reply with quote
You could stick one of the Malossi kits on. Think they pretty much bolt straight on but might well need the jetting playing with. Cost more than a standard barrel from David Silver Spares.
Finney2003uk
PostPosted: 23:25 - 21 Sep 2004    Post subject: Reply with quote
how much more tho lol cnd where could i find 1
alains
PostPosted: 02:48 - 22 Sep 2004    Post subject: Reply with quote
i wont recommand to put a big bore , better to put new barrel+piston kit
Finney2003uk
PostPosted: 00:45 - 23 Sep 2004    Post subject: Reply with quote
y wouldent u recomend it
mr jamez
PostPosted: 01:04 - 23 Sep 2004    Post subject: Reply with quote
Because it will go bang Smile doubt the money spent is worth the tiny increase in power anyway Confused
Just go with a normal top end Smile
Barrel and piston
Piston rings
small end bearing
Head and exhaust studs
head gasket
base gasket
2 circlips
RC valve seal
Think that is everything you need Smile
The last post was made 21 years, 358 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 85.65 Kb
