| bLiXeY |
 bLiXeY Scooby Slapper
| Mrjoolz |
 Mrjoolz Brolly Dolly
 Posted: 13:26 - 24 Jan 2012 Post subject: |
Mine does the same. Its a tight spot on the chain more than likely. I have just adjusted mine, and although adjusted correctly, it does seem to make this slight pull feeling. Also the chain makes noise, so perhaps a tight link also.
I'm planning to change mine this weekend mind, so if all noises and symptoms go, then I'll let you know it was the chain.  ____________________ Previous Bikes: TZR125, KMX125, RGV250, RD350YPVS, GXSR750H, GSXR600SRAD, R1 (2000), GSXR1000 (K1), ZZR600, CBR1100XX Super Blackbird
Current Bike: Suzuki GSX1300R Hyabusa..... |
| Teflon-Mike |
 Posted: 13:30 - 24 Jan 2012 Post subject: |
First of all check your chain for tight-spots; Take it off the bike, clean it, and waggle each link in turn, see if any are 'stiff'.
Then inspect your sprockets; front and rear, and look to see you still have 'lands' or flat bits on top of each tooth... if not they are shagged.
Oil the chain and put it back on; or put it back on then oil it, whichever you find easiest... with the chain on the rear sprocket try moving ONE link forwards & backwards between the teeth to check for play.
THEN tension the chain on the sprockets, and pay particular attension to getting the sprockets aligned. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Taught2BCauti... |
| junglejim |
 junglejim Banned
| bLiXeY |
 Posted: 19:06 - 24 Jan 2012 Post subject: |
| Walloper |
 Walloper Super Spammer
The last post was made 14 years, 254 days ago. Instead of replying here, would creating a new thread be more useful? |
