What does it feel like when your chains knackered?
bLiXeY
PostPosted: 12:20 - 24 Jan 2012    Post subject: What does it feel like when your chains knackered? Reply with quote
Just wondering because when I'm hitting the heady speeds of 40 mph on my moped (I know, I'm just a speed crazy animal on the road...no mobility scooters are safe when I'm about) the bike sort of lurches slightly on what is obviously a rotation of something.
Could this be my chain about to go? I have an intermittent slight sticky pad on my front disk too, so that's confusing the issue for me.
EDIT: Oh, and I noticed that sometimes my chain seems slacker/tighter by how close it gets to chain runners on the bike...is this what happens? They stretch in places?
Mrjoolz
PostPosted: 12:26 - 24 Jan 2012    Post subject: Reply with quote
Mine does the same. Its a tight spot on the chain more than likely. I have just adjusted mine, and although adjusted correctly, it does seem to make this slight pull feeling. Also the chain makes noise, so perhaps a tight link also.
I'm planning to change mine this weekend mind, so if all noises and symptoms go, then I'll let you know it was the chain. Thumbs Up Thumbs Up
Previous Bikes: TZR125, KMX125, RGV250, RD350YPVS, GXSR750H, GSXR600SRAD, R1 (2000), GSXR1000 (K1), ZZR600, CBR1100XX Super Blackbird
Current Bike: Suzuki GSX1300R Hyabusa.....
Teflon-Mike
tl;dr
PostPosted: 12:30 - 24 Jan 2012    Post subject: Reply with quote
First of all check your chain for tight-spots; Take it off the bike, clean it, and waggle each link in turn, see if any are 'stiff'.
Then inspect your sprockets; front and rear, and look to see you still have 'lands' or flat bits on top of each tooth... if not they are shagged.
Oil the chain and put it back on; or put it back on then oil it, whichever you find easiest... with the chain on the rear sprocket try moving ONE link forwards & backwards between the teeth to check for play.
THEN tension the chain on the sprockets, and pay particular attension to getting the sprockets aligned.
Taught2BCauti...
PostPosted: 12:36 - 24 Jan 2012    Post subject: Reply with quote
If you are planning to keep the machine, it wouldn't hurt to get a new chain and sprocket set - so you can make comparisons and change them if necessary.
As for how it feels - quite painful if the chain snaps when you are doing 40 and it takes the skin off your ankle!
junglejim This post is not being displayed because the poster is banned. Unhide this post / all posts.
bLiXeY
PostPosted: 18:06 - 24 Jan 2012    Post subject: Reply with quote
Cheers bud, let me know what happens. Btw, when you say your chain makes 'noise' what do you mean? Mine occasionally make a noise, like its taking up slack, but it doesn't do it all the time.
Oh, and thanks mike and every one else, I'm deciding weather to keep this bike until summer, if I do I'll take the chain off and start testing/cleaning it.
Cheers Thumbs Up
Walloper
PostPosted: 20:48 - 24 Jan 2012    Post subject: Reply with quote
If it's an o-ring/x-ring (rubber seal) chain and you have stiff links it most likely means the lubricant has escaped and the pin/bush is probably damaged.
It won't last long and could snap without warning under load.
New Chain and Sprockets.
The last post was made 14 years, 300 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 54.33 Kb
