De-tune race bike
Ben.
PostPosted: 20:34 - 24 Jan 2012    Post subject: De-tune race bike Reply with quote
Class limit is 130bhp and I've got 145bhp from the motor.
Spoke to my local tuner and he said he can over fuel it to get to the power limit but it will make it jerky and horrible to ride.
Any other suggestions from the BCF lot? how can i de-tune the motor but still get a nice ride without flat spots etc.
follow my racing season
Race bike - R6
Road bike - sv650
lihp
PostPosted: 20:39 - 24 Jan 2012    Post subject: Reply with quote
Do you have different camshafts available to you?
Barry_M2
PostPosted: 20:45 - 24 Jan 2012    Post subject: Reply with quote
I'll be in rookie 1000's this year too Ben
ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
robocog
PostPosted: 20:46 - 24 Jan 2012    Post subject: Reply with quote
adjust the throttle stop whilst on the dyno?
If thats too temporary (could be adjusted on track and then reset) or cannot be lockwired/sealed- so you don't get accused of rule breaking...washers in the inlet ? (though a nice set of alloy gas flowed restrictors would possibly be better)
Can the timing be adjusted by an ECU or rev limited perhaps?..you dont have a lot of HP to loose ...just dyno it on a hot day with an un oiled chain I bet you wouldn't be far off
Regards
Rob
Needs a bigger garage...
PostPosted: 20:48 - 24 Jan 2012    Post subject: Reply with quote
Why not just return bits to stock until you're inside the power limit, then fuel it properly.
Won't help if you're pulled off after race and your bike is dynod.
Once I got the later cams in my curvy SV, Steve Jordan added some tape over the air intake to bring it back down to the class hp limit as he'd got a bit too high setup right.
Seemed to do the job well enough.
MaybeGuy
surely if he just overfuels it at the peak RPM it'll make it just fine to ride? What bike? FI? If it's carbs, ignore.
DrDonnyBrago
PostPosted: 20:48 - 24 Jan 2012    Post subject: Re: De-tune race bike Reply with quote
How modified is it at the moment? Any stock parts you can switch back to?
Mikey3
PostPosted: 21:11 - 24 Jan 2012    Post subject: Reply with quote
G wrote:
Once I got the later cams in my curvy SV.
I've looked into this... what gains do you get from it? Seen on the SV forum people doing it and it looked interesting.
Mike
'04 Yamaha WR450F
'99 SV650 Streetfighter Project - mid build
'Motorcycling is about what you do; not about what you own, or how much you spend on it'
PostPosted: 21:13 - 24 Jan 2012    Post subject: Reply with quote
Rev limit seems like a good bet to me. Wonder if that can be set in the ECU?
Welshd1k
PostPosted: 01:02 - 25 Jan 2012    Post subject: Reply with quote
restrict the airflow ? like a normal 'restrictor'?
PostPosted: 01:12 - 25 Jan 2012    Post subject: Reply with quote
Mike
64hp up to 67.5hp set up properly on Steve Jordan's dyno stock internals, but with K&N and full M4 race system.
Forget the exact figures, but after the cams it got up to a restricted 72.8hp on his dyno, I think it was.
Personally, wouldn't bother unless you're actually racing - definitely going up from 64hp to 72hp (I had one or two races at the mid-point) was a big difference that made I had more chance of staying with others on the straight and putting a pass in under braking.
On the road or even trackdays, afraid we're in polishing turd sort of territory. If you want a faster bike, buy one. If you want to go faster on your current bike, turn the throttle earlier Smile.
PostPosted: 01:27 - 25 Jan 2012    Post subject: Reply with quote
How standard is the bike?
From the figures you have given you need to lose 10% which is a fair amount from a bodge on fueling, or anything like that. You could possible knock a bit off by retarding the ignition a touch. Open the valve clearances up to the wide end of the range.
Not sure on the R1 system, but can the EXUP valve be mal adjusted to stop it opening fully.
PostPosted: 02:20 - 25 Jan 2012    Post subject: Reply with quote
If it was FI, I'd definitely be looking to just limit the power at the top end, so you you've got more time at 130hp.
Unfortunately you don't have the flexibility you might have.
It may be worth working out a plan of action, then getting it set up on the dyno used in the series, presuming there is one present - that way you don't have to worry about other's over-reading etc.
Ben.
PostPosted: 15:16 - 25 Jan 2012    Post subject: Reply with quote
oo really. send me a pm. Im doing tunderbikes this year but we should be at the same meets.
Race bike - R6
Road bike - sv650
Ben.
PostPosted: 15:17 - 25 Jan 2012    Post subject: Reply with quote
that would mean replacing the engine for a stock one which would set me back £750.
Race bike - R6
Road bike - sv650
Ben.
PostPosted: 15:20 - 25 Jan 2012    Post subject: Re: De-tune race bike Reply with quote
Apparently its got a skimmed head / re-flowed.
Race bike - R6
Road bike - sv650
Ben.
PostPosted: 15:22 - 25 Jan 2012    Post subject: Reply with quote
This is what Steve Jordan suggested but he said it would be lumpy with flat spots everywhere and it would be banging and popping on the over run.
No ex-up on a race exhaust.
Race bike - R6
Road bike - sv650
PostPosted: 15:58 - 25 Jan 2012    Post subject: Reply with quote
Anything done to excess will cause issues.
However you could probably get back more than the cost of a stock engine by selling the tuned one (assuming it was done by someone competent).
Small bit of ignition retard might lose you 5% or so without any major issues. Stick on a stock exhaust to finish the job, and tweak the timing if the exhaust goes too far. Plus point is that you will probably gain a bit more mid range to help you recover when you make a mistake.
garth
PostPosted: 16:10 - 25 Jan 2012    Post subject: Reply with quote
Or just change the head, no biggy.
Mikey3
PostPosted: 20:27 - 25 Jan 2012    Post subject: Reply with quote
It did seem a big job for not much of a gain; in everyday use of course.
I'm happy on my SV Smile (except my restriction) but I think its unfair to complain about it until I am more able than the bike
Mike
'04 Yamaha WR450F
The last post was made 14 years, 273 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 113.27 Kb
