Bike wont start, put diesel in ( IT LIVES!!!)
EXC-Rider
PostPosted: 12:35 - 06 Feb 2012    Post subject: Bike wont start, put diesel in ( IT LIVES!!!) Reply with quote
I just took my bike to get some petrol brimmed as usual, got half way down the road and it started to loose power, i kept giving it throttle but nothing.
I came to a stop and the bike cut out. I tryed starting it again but as soon and it starts up i give it throttle and then just dies.
i dont know why its doing this but it started fine when i got it out my shed to get petrol but soon as i filled it up it dont seem to be having none of it
any ideas ?
owned bikes: DR50, Thumpsta 110 , Honda CR85, Speedfight 100, Yamaha XT125X, Honda CRF450, Honda Hornet '07
current bikes: KTM EXC525 AKA the wheelie machine
A friend in need is a friend indeed but a friend with weed is better!
PostPosted: 12:38 - 06 Feb 2012    Post subject: Reply with quote
Defo petrol not biodiesel/diesel?
Might be worth a quick carb clean, might have disturbed some shit in the tank. Check the fuel filter Thumbs Up
snikks
PostPosted: 13:10 - 06 Feb 2012    Post subject: Reply with quote
Definitely first thoughts is petrol issues as right after a fillup - might also be worth double-checking the air-intake is clear, as that was the issue when I had a similar problem on my bike.
- CBT: 02/01/11 Theory: 26/04/11 Mod 1: 19/05/11 Mod 2: 19/08/11
- 2007 Honda XL125V Varadero (Sold), 1999 Yamaha FZS600 Fazer (Sold), 2001 CBR600F
PostPosted: 14:13 - 06 Feb 2012    Post subject: Reply with quote
Brimmed it? Open the filler cap, see if it runs.
UrbanRacer
PostPosted: 14:20 - 06 Feb 2012    Post subject: Reply with quote
Yea, why brim it? that'll get you another 100yds.
EXC-Rider
PostPosted: 14:47 - 06 Feb 2012    Post subject: Reply with quote
Im going to get flamed for this but i think i may have put diesel in my tank :/ Just done a quick test and the diesel dont evaporate and its abit thicker Sad
FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K FU@K
PostPosted: 14:50 - 06 Feb 2012    Post subject: Reply with quote
It's fine, just take the tank off, empty the diesel into a container and fill with petrol.
Might take some serious starting but it might fire up Laughing Also, I don't mind you giving me the diesel.. new car is diesel and its expensive. Laughing
I think they smell different personally... got diesel on hands this morning and it smells different to when I splash petrol on myself.
DrDonnyBrago
PostPosted: 14:59 - 06 Feb 2012    Post subject: Reply with quote
Diesel is also very oily, dip a finger in and rub it between two fingers, if it is greasy and oily it is diesel. If it is thin and makes your fingers cold as it evaporates it is petrol.
I'd drain the tank, drain the carb and refill with petrol. Should start eventually and you should get away without having damaged anything, will be a bit smokey at first.
0l0dom0l0
PostPosted: 15:13 - 06 Feb 2012    Post subject: Reply with quote
Diesel in a petrol is no big deal.
As others have said, drain and re fill.
It'll go eventually.
MaybeGuy
PostPosted: 15:15 - 06 Feb 2012    Post subject: Reply with quote
Drain the carb and clean the plug too
EXC-Rider
PostPosted: 15:17 - 06 Feb 2012    Post subject: Reply with quote
yeah i went on the wonderful world on the internet can found out ways you can compare and its defo diesel.
might have to wait until i get a ride to the garage to get PETROL. oh well mistakes are made
oh and paddy if u want it ill send it it in the post. may get a bit soggy XD
PostPosted: 15:20 - 06 Feb 2012    Post subject: Reply with quote
Nah, ride down Laughing
Im-a-Ridah
PostPosted: 17:59 - 06 Feb 2012    Post subject: Reply with quote
My mum filled up her Scooby with diesel on the way to NEC bike show Laughing
m1tch
PostPosted: 18:24 - 06 Feb 2012    Post subject: Reply with quote
On the up side you don't have fuel injection so it can't mess up injectors, will just need to clean the carb and just drain it out Smile
EXC-Rider
PostPosted: 18:29 - 06 Feb 2012    Post subject: Reply with quote
drained all the diesel out now have a half a tank of petrol, been trying to start it for the past hour or so, my leg kills from kicking it over every 10 seconds. No luck so far will be giving it another bash now.
PostPosted: 18:32 - 06 Feb 2012    Post subject: Reply with quote
What bike?
dsb79
PostPosted: 18:36 - 06 Feb 2012    Post subject: Reply with quote
A good mate put diesel in his VFR, drained the tank, as much as we could, and fired her up, smoked real bad but it went in the end, dont kick to start the bike kick it to prime it, try get as much diesel out as you can.
Maybe take the plugs out and clean them.
If you have a fuel filter bin it and get a new one.
There should be no lasting effects once it gets going.
EXC-Rider
PostPosted: 18:53 - 06 Feb 2012    Post subject: Reply with quote
##Paddy## wrote:
What bike?
XT125X
EXC-Rider
PostPosted: 18:55 - 06 Feb 2012    Post subject: Reply with quote
the battery runs flat every time because it dont start up on the first push, so kick starting it atm is my only choice :/
PostPosted: 18:58 - 06 Feb 2012    Post subject: Reply with quote
Car battery and jump leads, keep cranking for a few seconds.. stop to let it cool down and retry.
PostPosted: 19:04 - 06 Feb 2012    Post subject: Reply with quote
Drain the float bowl if you haven't already done so. Let it run until petrol comes out. Take out the plug and get the earth strap (tip) glowing red hot on your gas stove. Then it should start.
UrbanRacer
Car battery might be too much for the bike, could do some real damage.
Rubbish. 12V is 12V, no matter what size the battery.
bLiXeY
PostPosted: 19:35 - 06 Feb 2012    Post subject: Reply with quote
Is that a new hobby, or something you've been doing for a while? You know you could just collect stamps...it's less combustible, but you won't have to wash your clothes as often. Very Happy
The last post was made 14 years, 267 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.43 - MySQL Queries: 13 - Page Size: 126.16 Kb
