tell me what pc psu I need
colin1
Captain Safety
PostPosted: 22:08 - 17 Feb 2012    Post subject: tell me what pc psu I need Reply with quote
I've got an old PC which is from 2003. My PSU is on the way out. I guess that PCs have different power supplies. So if I get one off ebay, what keywords do i need to know ?atx maybe ?
andym
PostPosted: 00:05 - 18 Feb 2012    Post subject: Reply with quote
what power supply have you got in there at the moment? What connections do you need? I tended to go for a slightly higher PSU than I needed. I always go for at least 750w (think they are from about £35 upwards)
Frost
PostPosted: 00:15 - 18 Feb 2012    Post subject: Reply with quote
Yes you need an atx one. The main board connector is the same, but modern PSU's will come with some extra connectors you don't need. Check if it comes with the old style chunky hard drive power connectors and not the smaller SATA ones.
Most come with both, or converters.
https://www.playtool.com/pages/psuconnectors/satano3.jpg
carvell
Scuttler
PostPosted: 01:29 - 18 Feb 2012    Post subject: Reply with quote
colin1, it's very unlikely that you need to buy a 750w PSU.
My only advice for PSUs is to get a branded one, with a warranty. A 400w branded PSU is infinitely better than a 750w non branded one.
I've had plenty of shite ones go tits up.
Yamaha TDM 850
andym
PostPosted: 03:44 - 18 Feb 2012    Post subject: Reply with quote
My last psu was a 750w CiT, OK so it only lasted 4 years with the PC being switched off for a total of 4-5 nights in the whole 4 years, the rest of the time it was worked hard.... and that cost me about £30-40. But thanks for the advice there carvell, I'll remember in future to buy a lower powered branded one that probably wouldn't even get close to starting my system.... Rolling Eyes
Seb
PostPosted: 10:28 - 18 Feb 2012    Post subject: Reply with quote
PSU Wattage claims are pretty much up there with vast pixel counts on cheap cameras, that big shiny number doesn't actually mean it's any good. A smaller quality unit from a respected manufacturer will not only last longer, but will usually come with a better warranty just in case it doesn't.
It's also worth noting that very few PCs from 2003 will need anything close to 750w. It's likely going to be a northwood P4 or late Athlon for a machine of that vintage, a good 400w will cover that in it's sleep.
2010 Triumph 1050 Sprint ST
iMark
PostPosted: 10:34 - 18 Feb 2012    Post subject: Reply with quote
750w is overkill, unless you happen to be running SLI Graphics cards which require 300-400w minimum each.
my 8800 GTS requires 400w minimum, and you can get away with a 500w PSU with that, the rest of the system doesn't need alot.
As for the price range, you can get a cheap PSU but they're not recommended as they can have faults... I'm actually running a £15,50 750w PSU at the moment my self, because I was on a budget and my old PSU actually blew up.
Anyways back on topic.
Most PSU's now will come with several MOLEX and several SATA connection's, but some will only come with 1 or 2 sata connections max, and no 6 pin PCI-E Power supply for graphics cards, but you can find converters which takes 2 MOLEX connections and converts it into a 6 Pin PCI-E connection (For graphic cards)
K8 GSXR 1000
The Artist
PostPosted: 11:04 - 18 Feb 2012    Post subject: Reply with quote
750w is total overkill unless you have big gfx cards.
orac
PostPosted: 12:40 - 18 Feb 2012    Post subject: Reply with quote
i am running a corsair cx 400w with an ati 3870 and a stock clock phenom 9950. i would think if its a pre-built machine it will only have a 350w PSU in anyway.
that PSU was £33 2 years ago from OCuk. i havent been in the market for a PSU in a while so cant tell you how much something like that would cost.
on a side note, i have seen cheap PSUs take out motherboards as well, granted its very rare for that to happen but bare that in mind before you spend next to nothing on a PSU
Alpha-9
PostPosted: 13:54 - 18 Feb 2012    Post subject: Reply with quote
Pretty sure mines like 800w
and is also unbranded
And has lasted 3 years+ now
Bitch please Thumbs Up
Try novatech.co.uk
Fzr-600 1999
Frost
PostPosted: 15:00 - 18 Feb 2012    Post subject: Reply with quote
https://www.overclockers.co.uk/showproduct.php?prodid=CA-062-OP
https://www.overclockers.co.uk/pimg/CA-062-OP_200.jpg
500W V2 Silent Power Supply
£18.98 inc VAT
Job done. 500w is way more than you'll ever need. If you're running a PC from 2003 then even if you do upgrade chances are you'll buy something low spec in which case you can reuse that power supply in your new system. Or you'll probably just buy some pre-made system in which case it doesn't matter
Scythe
PostPosted: 15:05 - 18 Feb 2012    Post subject: Reply with quote
£18.98 inc VAT
It's just cheap crap though.
I have a brand new OCZ ZS 550W PSU (still sealed - was a replacement). Still has warranty and receipt etc.
PM me if you're interested.
2009 Yamaha YBR125 -> 2000 SV650S -> 2005 Kawasaki ZX6R 636
Frost
PostPosted: 17:35 - 18 Feb 2012    Post subject: Reply with quote
Yes clearly his 9 year old PC needs one of these or he will be laughed at where ever he goes.
https://www.overclockers.co.uk/pimg/CA-009-XF_200.jpg
£245.99
orac
PostPosted: 19:39 - 18 Feb 2012    Post subject: Reply with quote
i got me one of these in my mian rig
https://www.overclockers.co.uk/showproduct.php?prodid=CA-029-CS&groupid=701&catid=123&subcat=1084
you have to run at least 2 of these in a 9 year old PC seeing as they they need power per flops of processing power, so putting a big PSU in it you can make even more powerful
Jenks
PostPosted: 19:51 - 18 Feb 2012    Post subject: Reply with quote
good topic!
im running two 8500GT 1024mb cards, quad core intell (13.4effective), 4gb ram..
how big do i need?
1978 MZ TS 250 1 Supa 5
1992 yamaha fzr1000 exup
1998 aprilia af1 sintesi
Diddylord
PostPosted: 20:20 - 18 Feb 2012    Post subject: Reply with quote
I have always found this very good
I noticed that it is currently down for maintanance but it allows you to calculate what PSU you need.
[/url]https://extreme.outervision.com/psucalculatorlite.jsp[url]
I am running a 550W antec which i have found very good can;t remeber what i paid for it was couple of years ago now. [/url]
orac
PostPosted: 21:20 - 21 Feb 2012    Post subject: Reply with quote
who the fuck keeps making people do that shit. multiplying the clock by number of cores is complete bollocks. if you are running a single threaded app (whcih a suprising amount of stuff is still) it doesnt run it at 13.4ghz, its runs it 3.3 or whatever the clock is.
and mulit threaded apps will run more than one thread at 3.3, not 6.6 is its a 2 threaded app, who ever started this shit should be shot in face.
Seb
PostPosted: 17:24 - 22 Feb 2012    Post subject: Reply with quote
It was an eBay thing as far as I can tell, and yes, totally agreed with the whole shooting their faces off thing. I had to grit my teeth many a time when people commented on that at work Neutral
Diddylord
PostPosted: 23:23 - 23 Feb 2012    Post subject: Reply with quote
While i know what you mean i don't get what my post has to do with it ?
Scythe
PostPosted: 01:49 - 24 Feb 2012    Post subject: Reply with quote
Too true! That's even if you do not have Intel Speedstep or the AMD equivalent activated. My 2500k runs at 1.6Ghz most of the time for general tasks, then boosts up to full speed if an app needs it.
Saves electricity and lowers heat, win win.
The last post was made 14 years, 207 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.71 - MySQL Queries: 13 - Page Size: 107.71 Kb
