Honda CG Back Brake
BikeNewbie
PostPosted: 14:29 - 29 Feb 2012    Post subject: Honda CG Back Brake Reply with quote
Hello,
My back brake pedal is really stiff, If I push it down, It will just stay down, I have tried adjusting the brake at the back will and still nothing.
Any ideas?
FirebladeRuss
PostPosted: 14:32 - 29 Feb 2012    Post subject: Reply with quote
Would imagine the cable's stuffed.
On my GZ the rear brake would not fully release. Mainly due to cable becoming sticky over time and there not being enough "spring" in the rear drum mechanism or pedal to shove the cable back once the pedal has been released.
When I had a new tyre fitted, I had a play with the drum mechanism and it was fine - lovely and smooth. Hence cable was shown to be up goosed.
Twitter is for people who can't STFU even when they're by themselves
FBSF
Grease.
WAIT - not the shoes Wink
The spindle that the brake lever spins around may need greasing, as may the pivot inbetween the brake shoes (but be careful - any grease on the shoe linings will render the brake useless).
That normally does the trick. It could also be the spindle for the actuator arm (the bit the brake rod goes through)
If it's an old CG, be careful when taking the shoes & plate out - old shoe lining material used to contain asbestos...
BikeNewbie
PostPosted: 14:43 - 29 Feb 2012    Post subject: Reply with quote
Well i'm not quite sure what to do. Haha.
FirebladeRuss
PostPosted: 14:50 - 29 Feb 2012    Post subject: Reply with quote
Erm...no offence, but if you don't know what to do or where to start based on the responses above, wouldn't you be better off taking it to someone who does?
When I discovered mine was sticking, I took stuff apart to have a look and pinpoint which bit was causing the problem.
BikeNewbie
PostPosted: 14:56 - 29 Feb 2012    Post subject: Reply with quote
It's fine mate, I don't know much about Bikes still. A Bike shop near to me said he will do it for £25.
Not sure whether its good or not? He said it sounds like it's some muck build up and needs cleaning out.
Thanks.
FirebladeRuss
PostPosted: 15:09 - 29 Feb 2012    Post subject: Reply with quote
Could be a build of dust in the rear drum, could be the cable, could be the pedal spring.
Worst case, a new cable is likely to be £20 ish + fitting (which is not hard), anything else is just his labour time.
Andy_Pagin
PostPosted: 15:13 - 29 Feb 2012    Post subject: Reply with quote
Thanks.
Can't see anyone doing anything to a bike for less than that. My guess (based on Landrover drum brakes) is they'll pull everything to bits and just put it all back together minus any crud, which usually does the trick with drums.
johnsmith222
PostPosted: 15:18 - 29 Feb 2012    Post subject: Reply with quote
I've not seen a CG with a rear brake cable. Maybe the older ones have it?
PostPosted: 15:27 - 29 Feb 2012    Post subject: Reply with quote
Thanks.
That's a bargain.
Order some new brake shoes and get him to bung them in there while it's apart. They cost less than a fiver last time I looked.
PostPosted: 15:28 - 29 Feb 2012    Post subject: Reply with quote
dp
tp
johnsmith222
PostPosted: 15:32 - 29 Feb 2012    Post subject: Reply with quote
This has got me thinking, will my 1992 RXS100 have aspestos shoes?
Might just bung it into a garage to sort my brakes the first time even though I have done that job countless times on my CG.
It's done 500 miles so likely to be original shoes.
BikeNewbie
PostPosted: 15:58 - 29 Feb 2012    Post subject: Reply with quote
Okay, Thanks for the replies! Smile
I will take it to the Bike Shop tomorrow and get it sorted. Smile
Thanks.
PostPosted: 16:01 - 29 Feb 2012    Post subject: Reply with quote
AFAIK Asbestos was outlawed well before 1992 in brake shoes.
blurredman
PostPosted: 16:04 - 29 Feb 2012    Post subject: Reply with quote
FBSF wrote:
asbestos...
Get real, it would only be harmful with years of direct contact, leave alone touching it for a second Laughing
FBSF
PostPosted: 17:37 - 29 Feb 2012    Post subject: Reply with quote
I am real. Google asbestosis.
It's not touching it that's the problem. It's inhaling the dust - one particle in the wrong place is all it takes.
Granted, the longer the exposure the higher the risk, but if someone isn't aware of the risk and starts blowing the dust out of the drum, and then breathes in a cloud of it...
von1papen
PostPosted: 17:44 - 29 Feb 2012    Post subject: Reply with quote
Your rear brake pedal isn't returning? First thing springs to mind is the actual return spring! May be stretched and worn, few quid off ebay to replace. May have nothing to do with the Drum brakes themselves
Also why are people talking about a rear brake cable? There is no cable........ its a metal rod from the pedal to the brake arm!!! Not a cable!
however its a piss easy job to remove the wheel, give the brakes and hub a sand to break any glaze, bung some brake cleaner in there too! grease up the brake arm spindle as well would improve matters.
I suggest getting a haynes manual and learning yourself, otherwise every time some little niggle appears you'll be running to mechanic instead of "oh yeah, thats easy to fix I've done that before".
I've had a Honda CG for well over a year now and servicing the rear drum brakes would probably take me half an hour at most.
BikeNewbie
PostPosted: 18:03 - 29 Feb 2012    Post subject: Reply with quote
Okay, I have just looked at the Bike again. It seems that the Brake only gets stiff when it is on the Centre Stand.
But when I move the Bike it is fine.
von1papen
PostPosted: 18:43 - 29 Feb 2012    Post subject: Reply with quote
I wouldn't worry too much then, as long as the brake goes on when you need it to on the road! However as I suggested I'd invest some time in reading the manual and learning how to do these jobs yerself!
PostPosted: 18:58 - 29 Feb 2012    Post subject: Reply with quote
Or you could always look at my little howto I did a while back.
Although I notice I didn't mention greasing cleaning and the pivots at the pedal end. I reckon you can work that out for yourself though.
https://www.bikechatforums.com/viewtopic.php?t=174773
von1papen
PostPosted: 19:01 - 29 Feb 2012    Post subject: Reply with quote
Haha I used that article myself! Better than the haynes because its in colour (and is actually explained reasonably well too)
You'll need to know this especially if yours is a front drum brake model
darthbuttchin
PostPosted: 19:45 - 01 Mar 2012    Post subject: Reply with quote
It is a metal rod that attaches to the pedal. The only cable involved with the back brake is the one attached to a long spring which activates the rear light when the pedal is depressed.
Just do some basic cleaning really. If you want the haynes manual in pdf form, PM me and I'll send it to you.
The Drum Brakes are pretty easy to sort out, just dont get grease on the pads!
Mine's from '78 - we weren't sure about asbestos or not, but with me being asthmatic, Dad advised me not to blow any of the dust out that was in there anyway.
db
CG125-K1 (1978) - 35 years old and (mostly) going strong! (Restored and rebuilt by my own fair hands).
Call me Tomsk - I am the Flying Womble after all.
The last post was made 14 years, 195 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 120.78 Kb
