Engine paint
nightshaddow
PostPosted: 15:23 - 05 Mar 2012    Post subject: Engine paint Reply with quote
once the engine has been to the engineers to drill out the mounting bolt i will be stripping and rebuilding the lump.
after 30k miles and 26 ish years of probable abuse it really could do with a new paint job too.
what would be a good paint to do it with?
can you get proper engine paint?
MickC
PostPosted: 17:57 - 05 Mar 2012    Post subject: Reply with quote
Any make of engine enamel or barbeque paint ( it can take higher temperatures )
Your local Halfords will sell it as well as most other car places.
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
SnowTigeress
PostPosted: 13:41 - 06 Mar 2012    Post subject: Reply with quote
we used pj1 on our engines but because of warning label they were taken off the shelves...as they were not EU compliant labeling
https://www.ebay.co.uk/itm/PJ1-GLOSS-BLACK-ENGINE-CASE-HIGH-TEMP-TEMPERATURE-SPRAY-PAINT-CAN-MOTORCYCLE-/280802300571?pt=UK_Motorcycle_Parts&hash=item41611f129b#ht_2182wt_982
https://www.ebay.co.uk/itm/PJ1-FLAT-MATT-BLACK-HIGH-TEMPERATURE-TEMP-EXHAUST-SPRAY-PAINT-CAN-MOTORCYCLE-/280802306045?pt=UK_Motorcycle_Parts&hash=item41611f27fd#ht_2186wt_982
but also found this but not tried it,but its cheaper
https://www.ebay.co.uk/itm/MATT-BLACK-HIGH-TEMP-ENGINE-CASE-PAINT-TECHCOTE-PJ1-6-99-POSTAGE-/200720279995?pt=UK_Motorcycle_Parts&hash=item2ebbdc69bb#ht_808wt_698
Real bikers build their own Renovated and Riding a 1986 Honda CB125TD-C called the Pup. Full Licence
13/09/2012, 1994 Moto Guzzi 750 Strada
Can-Do Girl that does spanners TOO!
TheSmiler: binning it is better than going around a roundabout the wrong way
MickC
PostPosted: 18:04 - 06 Mar 2012    Post subject: Reply with quote
Ooh! that second link says up-to 650c which is higher than barbeque paint, wonder what it would be like on exhausts Thinking
XX XXXx
Frost
PostPosted: 18:14 - 06 Mar 2012    Post subject: Reply with quote
I sprayed an exhaust with halfords very high temp paint. I let it dry properly for a few days, warmed the bike up a little more each time for a bit then went for a ride. After 20 miles my exhaust was unpainted again Laughing
That stuff might be a little better but right where the header is gets bloody hot.
MickC
PostPosted: 19:55 - 06 Mar 2012    Post subject: Reply with quote
Yeh the standard enamel ( used matt black - 400c ) is no use on the head of the pipes, I used it on a set that has inner pipes and same thing. The barbeque stuff worked better, but that first 4-6 inch still flaked off ( Its an all in one system so no chance of curing it in the oven first ).
XX XXXx
The last post was made 13 years, 327 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.19 - MySQL Queries: 13 - Page Size: 50.21 Kb
