Recommend me a Data-logging system.
0l0dom0l0
PostPosted: 11:29 - 16 Mar 2012    Post subject: Recommend me a Data-logging system. Reply with quote
Ok,
So seeing as there are hardly any Maps for the Daytona 600, I want to use the Triumph after-market one as a starting point and modify it to suit my exhaust.
Now to do this I was going to use a data-logging system. I need to log the following:
AFR
MAP
Throttle Position
RPM
At a minimum.
Anyone got any suggestions?
I found this:
https://www.ebay.co.uk/itm/Innovate-LM-2-WIDEBAND-A-F-Ratio-Gauge-Kit-BASIC-3837-/310275983118?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item483de3c70e#ht_3357wt_952
What do you think? Will it do what I want to do?
Also, how do I tap into the sensors on the bike? Does anyone know if I can connect this to the OBD II connector on the bike and the ecu will talk to it directly?
Any help would be greatly appreciated. Karma
PostPosted: 11:38 - 16 Mar 2012    Post subject: Reply with quote
Why do you want data logging gear?
Use TuneECU
https://www.bikechatforums.com/viewtopic.php?t=222439
Just get the bike dyno'd it should tell you what you need to know too tune it.
0l0dom0l0
PostPosted: 11:44 - 16 Mar 2012    Post subject: Reply with quote
I am using tune ecu to tune the bike.
But how do I know where the bike is running rich/lean etc?
Dyno's are fine, for W0T stuff but it's the rest of it I want to look at. No good if you're running lean at WOT and rich on part throttles for cruising.
Plus the £30 for a dyno run would go towards the logger quite nicely.
PostPosted: 11:49 - 16 Mar 2012    Post subject: Reply with quote
Most dyno runs will do part Throttle run the place I went to said they would for £35 do 3 runs 1/4 1/2 and full throttle.
lihp
PostPosted: 01:35 - 17 Mar 2012    Post subject: Reply with quote
You won't be able to get an AFR anyway, unless it is fitted with a wideband lambda sensor.
I'm unsure what the daytona is fitted with, but even most cars are only fitted with Narrowband sensors.
The last post was made 14 years, 188 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 45.13 Kb
