Brake Disc life span
PostPosted: 17:15 - 02 Apr 2012    Post subject: Brake Disc life span Reply with quote
Right, how long will a set of discs last?
A couple of times now I have got it into my head that I need a new set of brake discs on the front of my bike, I even start pricing them up, but when I go to check them they are still well within spec.
My Bike has 53,??? miles on it, it is on the original discs. The min disc thickness is 4.5mm and mine are 5.2/5.3.
Now the TDM has the same brakes and discs as the R1. The brakes are VERY good, I have ALWAYS used Sintered pads.
The bike has had a hard life, 80% of the miles are through London at rush hour, my ridding is aggressive and I am very heavy on the brakes. I occasionally Clean them out and re lube the pistons but not often, maybe once between pad changes and when the pads are changed.
I just can't believe they have lasted so long, considering how often I hear people about having to change discs.
duhawkz
PostPosted: 17:18 - 02 Apr 2012    Post subject: Reply with quote
as long as they are above min thickness and are not cracked or warped then they should be good for a while longer.
PostPosted: 17:20 - 02 Apr 2012    Post subject: Reply with quote
The discs are fine, I think my mind just thinks it must be fucked by now Laughing
Kris
PostPosted: 19:21 - 02 Apr 2012    Post subject: Reply with quote
I replaced mine at roughly 60,000 miles but they were about 2mm thick at that point!
https://www.bikechatforums.com/viewtopic.php?t=200856
www.prisonplanet.com
0l0dom0l0
PostPosted: 22:52 - 02 Apr 2012    Post subject: Reply with quote
It depends.
Bishbash was still on the original brake pads on his R1 after 30k miles, including a load of trackdays (around 8 or so?)
Depends really but you might see 100k from them Thumbs Up
DrDonnyBrago
PostPosted: 10:14 - 03 Apr 2012    Post subject: Re: Brake Disc life span Reply with quote
Most people seem to warp them through shite brake maintenance well before the discs get worn thin enough to need replacing.
If they are still in spec, aren't cracked/damaged/warped/rattling around on the rivets etc etc then I'd continue to use them. Spend your cash on something else for now Thumbs Up .
garth
PostPosted: 10:54 - 03 Apr 2012    Post subject: Reply with quote
My old man has a 1200S Bandit with 40 something thousand on it, owned from a few months old.
I can not even feel a ridge or lip between the working and non working surface of the discs. Shocked
PostPosted: 10:55 - 03 Apr 2012    Post subject: Reply with quote
There is the slightest lip on mine nothing to write home about.
yen_powell
PostPosted: 14:04 - 03 Apr 2012    Post subject: Reply with quote
I got a rear disc to do 120,000 miles before it was replaced. Fronts seem to warp for me before they wear out.
XT1200Z and a DR350 in bits
Ingah
PostPosted: 16:18 - 03 Apr 2012    Post subject: Re: Brake Disc life span Reply with quote
Suspect it's this. +1 all round.
-- Ingah
The last post was made 14 years, 202 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 65.23 Kb
