Oh, Mr Hyosung, you so craaaazy
PostPosted: 21:00 - 14 Apr 2012    Post subject: Oh, Mr Hyosung, you so craaaazy Reply with quote
So we piled into chumrade's GT125R today mob handed. It turns out that it had one of the ACME E-Z-Corrode swing arms, so a new one had been obtained and needed dropped in. But to get the swing arm off, the exhaust (I was assured, since I turned up late) had to come off. Weird, but there we go, shouldn't take... aaah.
Well, OK, that's the rear pipe off, but the front was solid in the head and oops, there goes a stud. After some tugging and twisting, double oops, that's us got two bits of exhaust. While Team A drilled and chiselled the seized remains of what appeared to be anti-tamper bolts off of the pipe-to-can join, Team B wrestled with the stub of the exhaust in the head. Would it come out? Would it buggery.
Anyway, Tef-story-short, three hours later we have a box of bolts - including the bonus secret hidden ones holding the head and barrel on - and the front cylinder head off, with only one exhaust stud snapped off short. After some extended drilling, cutting and eventually HULK SMASH chiselling, the pipe collar eventually gave up the struggle, taking a (hopefully non fatal) chunk of the head with it when it went.
Break for tea, ordering new exhaust pipes, and taking the head away to rebuild with chemical metal, and drilling and tapping for a new stud.
And all that to change the swing arm on a 125.
I'd like the meet the chap who designed this bike and shake him warmly by the throat. It almost feels as though hostility is engineered right into it. Brick Wall
pepperami
PostPosted: 21:16 - 14 Apr 2012    Post subject: Reply with quote
Sad I hope my 250 is not going to be as stubourn when I have to do "stuff" to it Question
Sload
PostPosted: 21:17 - 14 Apr 2012    Post subject: Reply with quote
Much in the way of expletives uttered? Laughing
PostPosted: 21:47 - 14 Apr 2012    Post subject: Reply with quote
Loads of neighbourhood waifs hanging around asking why the nice red bike was now a rapidly spreading pile of red and rust coloured bits, so we tried to stick to Radio Edits. Wink
Kwaks
I'm not a fast rider
PostPosted: 21:58 - 14 Apr 2012    Post subject: Reply with quote
Maybe the exhaust is designed to be the backup swingarm when the first rots away? Wink
www.cliqueycuntsmcc.co.uk
Cheeseybeaner
PostPosted: 22:39 - 14 Apr 2012    Post subject: Reply with quote
Its always fun when a simple maintenance job turns into a mammoth task with bits failing left right and centre following their disturbance!
PostPosted: 22:42 - 14 Apr 2012    Post subject: Reply with quote
Sounds plausible. It might also explain why I can't find any bugger selling Hyosung pipes in the UK. Maybe I should check under suspension components? Wink
Hmm, bag on Chinese-branded bikes all you like, at least parts are easy enough to get now.
junglejim This post is not being displayed because the poster is banned. Unhide this post / all posts.
Quornholio This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
Werny
PostPosted: 00:14 - 15 Apr 2012    Post subject: Reply with quote
This ^^^
Everything I ever try to do happens like this
CaNsA
PostPosted: 00:17 - 15 Apr 2012    Post subject: Reply with quote
Rog, dude.... no pics?
pits
PostPosted: 01:02 - 15 Apr 2012    Post subject: Reply with quote
Why didn't you get a blow torch out and heat the head/studs/bolts up? These days it is the first thing I do before going near exhaust studs and nuts, been there done that with VW's
Cheeseybeaner
PostPosted: 08:23 - 15 Apr 2012    Post subject: Reply with quote
This ^^^
You sometimes come to the conclusion that it might have been better not to touch it!
pepperami
PostPosted: 10:19 - 15 Apr 2012    Post subject: Reply with quote
Wheelfit Motorcycles in Ely maybe able to point you in the right direction regarding exhausts?
When they did a bit of work for me, we chatted about aftermarket exhausts and cans for Hyosungs.
PostPosted: 10:21 - 15 Apr 2012    Post subject: Reply with quote
Cheers, we'll give them a try. I think it's going to be a telephone search - I'd just got so used to being able to type and click and have stuff turn up.
junglejim wrote:
Unfortunately, there are people who blame everything and everyone but themselves.
This whole scenario could have been avoided with a little bit of common sense
I should have made it clearer that the damage was done by the time that I arrived and got fired in. Wink
The culprits are both professional motor engineers, by the way, so of course they're not going to show any common sense. My penetrating oil and their torch were sitting unused behind them, next to their cups of tea with six sugars. Very Happy
The nub of my gist is that it's a disappointingly (over) engineered bike. 2 cylinders, 4 cams, 8 valves, but not a lot, as you say, of common sense.
pepperami
PostPosted: 10:32 - 15 Apr 2012    Post subject: Reply with quote
Wheelfit Motorcycles LTD : 01223 440087.
They seemed like a decent bunch Thumbs Up .
I bought the bike from Fastline Superbikes LTD in preston : 01772 902600, they maybe able to point you in the right direction?
Kwaks
PostPosted: 12:24 - 15 Apr 2012    Post subject: Re: Oh, Mr Hyosung, you so craaaazy Reply with quote
Wasn't me bagging on chinese bikes Wink
BTW what penetrating oil do you use? Best I have found is kroil (kano oil)
PostPosted: 16:20 - 15 Apr 2012    Post subject: Re: Oh, Mr Hyosung, you so craaaazy Reply with quote
I'm currently trying "3-in-1 oil pro penetrating spray" because it was the best they had at B&Q, but I'm not loving it. I'll be going back to Plusgas, or if I can find any, Rustola penetrating oil in a proper squeezy-can.
Mikey3
PostPosted: 16:56 - 15 Apr 2012    Post subject: Reply with quote
To get the swing arm out the SV the exhaust had to come off. The rear downpipe goes through the swingarm just aft of the pivot, then bends itself silly to join onto the front downpipe and into the 1 silencer.
I know the hyo GT650 is practically an SV engine, so I wonder if the 125 takes any similar design fetures, also being a twin and all that.
Mike
'04 Yamaha WR450F
'99 SV650 Streetfighter Project - mid build
'Motorcycling is about what you do; not about what you own, or how much you spend on it'
lihp
PostPosted: 17:10 - 15 Apr 2012    Post subject: Reply with quote
I was going past Preston other week, and I've bought from them in the past, and was surprised to see that the shop was closed up!
pepperami
PostPosted: 20:32 - 15 Apr 2012    Post subject: Reply with quote
They`ve moved to new premises.
lihp
PostPosted: 21:03 - 15 Apr 2012    Post subject: Reply with quote
Never knew that, where are they now?
PostPosted: 21:51 - 15 Apr 2012    Post subject: Reply with quote
Sounds about right, the GT125R is a GS500 frame with a V-twin, so let's put the blame on Suzuki-san. Still fraking mental though.
The last post was made 14 years, 154 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.19 Sec - Server Load: 1.34 - MySQL Queries: 13 - Page Size: 132.44 Kb
