Hiding bad welds - wrap?
grant965
PostPosted: 17:54 - 19 Apr 2012    Post subject: Hiding bad welds - wrap? Reply with quote
Hi, made a dual exhaust link pipe for my bike, Tacked it myself but got a mate, who said he could weld !!, to weld it for me. Its come back in hell of a state, massive welds on every seal. Its never going to look clean so im going to need something to cover it, what would you guys recommend that is cheap and looks OK/better/
thanks, Grant
Ex bikes: 05 Suzuki En 125, '98 Yamaha Thundercat, '08 Honda cbr125, '05 Kawasaki z750, '03 Triumph Daytona 600, '91 Kawasaki ex250, '03 Hyosung Comet 125
Current Bike: '02 Suzuki TL1000R
HD
PostPosted: 17:57 - 19 Apr 2012    Post subject: Reply with quote
Pics?
Andy_Pagin
PostPosted: 18:00 - 19 Apr 2012    Post subject: Reply with quote
I usually hide my crappy welding by grinding the worst off with a Dremel and then plastering it with spray paint.
J.M.
PostPosted: 18:05 - 19 Apr 2012    Post subject: Reply with quote
Sorry that I have nothing useful to add for hiding it, but:
https://www.bikechatforums.com/viewtopic.php?t=243160&postdays=0&postorder=asc&start=25#3153397 Whistle
2004 R1 & 2018 XSR900
grant965
PostPosted: 18:08 - 19 Apr 2012    Post subject: Reply with quote
hi, I would grind it down but it would reveal even more holes so It would take forever to get it finally sorted.
Check the pic I attached, It would take many days and discs to
smooth that out.
I was thinking something like this:
https://www.ebay.co.uk/itm/Exhaust-Manifold-Downpipe-Heat-Wrap-10-mtr-High-Quality-Ceramic-mirror-foil-Uk-/260962902378?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3cc299e16a
Or even just the dull black version.
[/img]
DrDonnyBrago
PostPosted: 18:11 - 19 Apr 2012    Post subject: Reply with quote
Exhaust wrap just traps water causing the pipes to rust, if it is mild steel it wont last long. Stainless might fare better.
The best thing to do is remake it and take it so someone who can weld properly.
grant965
PostPosted: 18:14 - 19 Apr 2012    Post subject: Reply with quote
Im just tidying it up because I will be selling it so not interested in long term affects. Its full stainless steele if it makes a difference
Nexus Icon
I can't imagine that's even gas tight.
Greetings from Shitsville!
PostPosted: 18:19 - 19 Apr 2012    Post subject: Reply with quote
I cant weld and I will freely admit that I have never tried to but I bet I could do a better job than that.
DrDonnyBrago
PostPosted: 18:20 - 19 Apr 2012    Post subject: Reply with quote
It will look shite either way. It will probably also leak and mess up the fuelling too.
What bike is it for?
Drake
PostPosted: 18:21 - 19 Apr 2012    Post subject: Reply with quote
he had too much power and wire feed on, did he put stainless wire in the welder and use pure argon?
and how much did you pay for that?
DrDonnyBrago
PostPosted: 18:23 - 19 Apr 2012    Post subject: Reply with quote
Looks like it was welded using two metal coat hangers and plug socket Laughing .
Fisty
PostPosted: 18:42 - 19 Apr 2012    Post subject: Reply with quote
Awaits warpeds 4 thou of input.......
Fatter and faster than Fret
PostPosted: 18:45 - 19 Apr 2012    Post subject: Re: Hiding bad welds - wrap? Reply with quote
You can get them ceramic coated, but doubt it'd be cheaper than getting the job done properly.
cb1rocket
PostPosted: 18:49 - 19 Apr 2012    Post subject: Reply with quote
thats just going to be a remake, should of given this job to the turbo maker aka CHR15!
HD
PostPosted: 18:53 - 19 Apr 2012    Post subject: Reply with quote
Jesus fucking christ Laughing
Rob W
PostPosted: 19:00 - 19 Apr 2012    Post subject: Reply with quote
That really is an abomination. Can also virtually guarantee that will be full of pin-holes, as he's just blobbed it up all the way round. Was anything prepped? Or did he just leave him self too big a gap and couldn't fill it? Personally, I'd of TIG'ed that.
Best thing to with that would be slit through all the joins, clean them up, and give to someone who has a clue.
cb1rocket
PostPosted: 19:04 - 19 Apr 2012    Post subject: Reply with quote
it does all looked mig'ed welded, its difficult and for that matter, even at my work place, anything that is stainless is TIG'ed welded.
I'm not saying it can't be done using a MIG welder but as the picture shows its bloody hard!
Welding mild steel using a mig is far easier, with the correct setup of course
PostPosted: 19:18 - 19 Apr 2012    Post subject: Reply with quote
Did he weld it with a potato?
kELKY
PostPosted: 20:23 - 19 Apr 2012    Post subject: Reply with quote
Looks like a bird has shat on it Smile
JonE
PostPosted: 20:28 - 19 Apr 2012    Post subject: Reply with quote
Looks like it could have been a baked potato with cheese and beans.
PostPosted: 20:36 - 19 Apr 2012    Post subject: Reply with quote
You'd be better off selling it with no exhaust. Anyone who sees that mess on there is going to assume the rest of the bike has suffered similar bodgery.
Matt578
PostPosted: 20:48 - 19 Apr 2012    Post subject: Reply with quote
On the join near where it says "2011" you can see what looks like 3 holes there. Sorry to say but i think you would be better off scrapping that Sad
Your Daddy, Everyone's Friend.
kestrel
PostPosted: 21:45 - 19 Apr 2012    Post subject: Reply with quote
Scrap it and start again, and give your mate a slap. There's no point in buying expensive stainless tubing then contaminating it with mild steel filler or cooking it like that abortion, it will rust faster than a mild steel system. Stainless exhausts should be TIG welded if they need a reasonable finish. Don't buy stainless tubing from exhaust suppliers, find a supplier of 'dairy tube' which is available in 304 or 316 grades and much cheaper, look for 1.6mm wall thickness. Take your time forming the joints, they should be a perfect fit, and do not put a prep on the ends. A good fit up can be TIG welded without filler wire (autogenous weld) and should leave a smooth weld surface requiring no dressing at all. Any welding on stainless tubing should also be done with a back purge running.
Isle of Man.........Road Racing Capital Of The World
Timmeh
PostPosted: 21:48 - 19 Apr 2012    Post subject: Reply with quote
Looks like its been attacked by a bunch of blind gorillas wielding banana-powered stick welders.
I'll give you a quid for it?
The last post was made 14 years, 161 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 125.18 Kb
